Is it easy changing...
[Closed] Is it easy changing a motorcycle chain?
I haven't got a motorbike chain tool yet.
Is it the same process as the bike?
Posted : 16/02/2009 11:00 pm
What bike? Get a scottoiler and then you can ignore the chain ;o)
Posted : 16/02/2009 11:11 pm
Depends if it's got a splitlink in or not.
Posted : 16/02/2009 11:20 pm
As singlespeedstu said. Not sure that "big bikes" have split link chains, I only ever serviced bikes up to 500cc in the 70s/early 80s.
Get a Scotoiler but you can't ignore your chain. You still have to check tension and that the Scotoiler hasn't run dry.
Posted : 16/02/2009 11:28 pm
Very few modern bikes have split links. Not safe with more than a few HP. You do get chains with "softlinks" that can be riveted similarly to a bike chain so if you use one of those its fairly straightforward - use the chain tool to break the old chain and put the new one on with the correct rivet tool.
Posted : 16/02/2009 11:32 pm
Was chatting about this t'other day... apparently a decent chain tool is £90 or something. I suspect I will just get my lmbs to do it for me... that way they can (hopefully) make sure that the wheel alignment is okay at the same time!!!!
Posted : 16/02/2009 11:50 pm
I did my Honda CBR years ago with a hammer & chisel!
My old man a honda CUB 90! 😆
When I popped round to service his scooter his chain was quite loose.
I don't think my park tool would last. I have to check if it has a split pin-which would be great n easy except shortening the chain using a file and G-clamp.
£40 for a decent chain tool??!!
Posted : 17/02/2009 12:06 am
