Is there a risk ESP will mean manufacturers might start being a bit more relaxed about how stable their cars are knowing ESP will sort everything out?
It works for aircraft designers.
.. and the segway
All these driver aids do one thing and one thing only in my view they allow either bad or inexperienced the ability to drive faster than they really should.
The ped does have the right of way when you are turning into a side road so obviously you were prepared to give way anyway, right?!
Who said anything about a side road?
I tend to give way to anyone who walks in front of the car, regardless of whether it's on a driveway or motorway.
How exactly?
Although modern safety aids are extremely effective, they still have to obey the laws of physics and if you overcook it too much then it doesn't matter what your ESP does, you are still going to bin it. As others have mentioned above, if you are really trying to push it with ESP on it can actually become dangerous as the car try's to fight you. There is no conspiracy with these things - they are genuinely there to potentially save your life when something unexpected happens during normal driving.
Having driven a Range Rover at a reasonable speed and then throwing round some cones to simulate a car pulling out at the Gaydon test track.
I was amazed at what the ESP can do! 3 tonnes moving that fast shouldn't have been able to manoeuvre like it did. It was very clever how it braked the wheels and balanced the car. Literally defied physics!
So not for driving like a knob but the small chance you driving and a deer, dog, badger, child, car unexpectedly pulls out and is in the road and you have to emergency manoeuvre it makes up for a vast gap in skills you don't normally need.
You may never need it, you may be very glad you had it?
It does more that, it does things a driver can't actually do. I would love to see a swerve test (aka moose test) with a pro driver in the same car, with and without ESP.
2mins 50s in
Impressive video.
1) ABS is useless in snow - WRONG
2) Traction control is useless in snow - ALSO WRONG
3) ESP only helps numpties who can't drive - WRONG AGAIN
Really in what way? OK its not useless, but certainly stopping distances in snow are quicker if you dont use ABS
Traction control isnt useless in snow, but again you WILL make better forward progress not using it.
I just cannot understand this. On a public road, in a machine that kills thousands every year, why would you be 'really trying to push it' ?
maybe it's 'cos I have a mate who was a traffic cop for many years and almost daily went to the scene of crashes where people were 'pushing it' and had to mop up the blood and brains from the road.....
I just hope I don't come across these drivers when out on a nice dry country road with my kids in the car 👿
Don't agree, and neither does the video as far as I can tell. ABS maximises available traction by feathering to avoid locking up. An advanced driver would do the same thing, so would get the same result. Except he can't do each wheel individually.
Ok one example - I was in a Merc SL 350 going up a country lane, quite narrow 2nd gear driving quite sensibly. Literally just went over a damp patch on an uneven road surface as I accelerated (not even that hard). Probably in this instance the ESP kicked in before I quite reacted, but I react too buy lifting of and starting to apply opposite lock. The car then did all kinds of weird kangarooing wobbling all over the shop. It was nearly a crash moment. What I should have done is just kept going as I was and nothing would have happened except the dashboard light would have flashed.
MX5's on the whole have quite a low level of grip compared with most modern sports cars (but still fantastic handling) this means in the wet you can quite easily get the car sliding, or all 4 if you use a bit of skill 😈 All at a lot less the 60 mph limit.
mrmo - Member
What limits, in normal driving the limits you never get near, the limits you can only reach by driving like a *?So are you advocating drivers drive like
** to find the limits of the car?
I've been terrified in cars with people who think like that before.
They think nothing of braking hard on the motorway then immediately performing a fast turn into the overtaking lane while the car is still unsettled, lifting off mid-corner at 50mph in the wet, etc never knowing quite how close they came to completely losing control.
Wait a minute - you hit a damp patch and the car required corrective action? Wtf? Something's badly wrong with this picture.
Just doing some googling...
ABS is designed to help the driver maintain control of the vehicle during emergency braking situations, not make the car stop more quickly. ABS may shorten stopping distances on wet or slippery roads and many systems will shorten stopping distances on dry roads. On very soft surfaces, such as loose gravel or unpacked snow, an ABS system may actually lengthen stopping distances.
Molgrips - Powerful rwd car 2nd gear greasy road. Very easy to loose the back end. Yes I was using too much right foot for the road condition obviously, but a less powerful fwd car wouldnt have even reacted.
all this thread is doing is re-afirming my belief that there are some c***s on the road who really shouldn't be
all this thread is doing is re-afirming my belief that there are some cs on the road who really shouldn't be
Quite probably. Are those cs the ones who have no idea how a car behaves at the limit of control or when you go passed it, the ones for whom ignorance is bliss?
It's definitely useful. I've got it on two cars but it came as standard. I've experimented with it on and off and it's proven it works. FWIW a Swiss mate of mine tried really hard to unsettle a car with ESP on an icey car park and he was very impressed.
If it was winter you were worried about a full set of winter tyres would probably be more useful. Of course the ESP is always fitted and it works in the wet or indeed the dry if you are pushing hard enough !
In the "old days" ABS was an option, now it's virtually standard. I think ESP will be the same.
FunkyDunc did you watch the video that Tiger6791 posted?
I'd be interested to know what you made of it.
I cant at work 😀
I wouldn't think twice, a definate yes from me.
I am a significantly above average driver in terms of car control and reacting to changes in a vehicle's grip levels, and I still like it being there if I need it. Even if it stops you sliding on some ice or diesel and damaging a wheel, its money in th ebank and piece of mind.
In no way doubting that
, unfortunately most people think that of themselves in a car, meaning that, generally, we are all about average, and as such every and any electronic help we can get will keep us saferI am a significantly above average driver in terms of car control and reacting to changes in a vehicle's grip levels,
I cant at work
Ah okay. It looks like it is from Fifth Gear or some such. Shows Tiff demonstrating ABS, Traction Control and ESP on a Jag on an ice and snow test track. In each case it works better with them on.
Granted the tests could be rigged, he may not be trying properly, or possibly he's just not up to the same standard of driving as some STWers - but it does suggest they are generally all good things for us mortals.
In no way doubting thatI am a significantly above average driver in terms of car control and reacting to changes in a vehicle's grip levels,
Exactly, its human (or just bloke) nature that we always think we are 20% better than we are. I can only claim to have such talents in car control etc. This is just a crossover form other areas. I cannot (and won't attempt) to claim I am overall and above average driver.
If formula one could have these things, they would. I personally thknk these systems will revolutionise road safety.
May. And I am still sceptical. Without ABS, you either lock all four wheels or you don't. I can't imagine when locking all four wheels would help you stop quicker. I think people are convinced that ABS doesn't work on snow because they brake and the car doesn't slow down very much. Well, you're on snow, aren't you? If they had ABS off and braked, and the wheels locked up, they'd see for themselves that there was naff all traction, but without any skidding it doesn't feel like anything is happening.
And it says UNPACKED snow. Pretty unusual situation, to be fair. I don't think I've ever been on a road where at least one car hasn't been on it before me.
The whole ABS/packed snow thing is mainly for places with lots of snow and few cars - e.g. Scandinavia etc.
On loose snow a locked wheel can build up a small "wedge" of snow in front of it that aids deceleration. In those conditions ABS reduces braking.
But in this country, for drivers of all ability up to professionals, these electronic aids help. That's why they are all slowly being mandated.
Nah. Risk Compensation will sort that out. Folk will just driver faster.
Early cars were capable of going quite quickly, but generally didn't because there was a high chance you'd die.
Modern cars are incredibly safe by comparison, so people are happier to drive them quickly.
Unfortunately there haven't been similar advances in pedestrians, wildlife, cyclists and other "hazards" that might be found on the road.
Drum brakes will do that... 😯
FunkyDunc - Memberall this thread is doing is re-afirming my belief that there are some cs on the road who really shouldn't be
neither and granted they are both just as dangerous as the ones who think its ok to drive like a c**k on speed, believing they know what they are doing.
take it to a track, learn what car control is, take a course that will demonstrate you know nothing and teach you the error of your ways and then go about your life driving sensibly knowing that you know how to drive and that the systems in the car are there to help should you need them in an emergency and aren't there to stop you crashing.
it defies belief how many people really think they know what a car is doing and is capable of. you NEVER know what is around the next bend, could be a fallen tree, road collapsed, a horse/cyclist/kid, an accident, gravel on the road, mud, ice, road closed etc.
so unless you actually have REAL ESP and genuinely know what is about to happen ahead of schedule instead of a safety feature on your car, slow down and above all else concentrate on what you are doing and think "what if??"
christ i sound old. 🙂
I think the problem is a lot of drivers (Men) think they are better than they are. We all at some point think we are Sterling Moss. I have driven like a complete tit and I can now look back and think I was more lucky than skilled.
I think I had my epiphany once when I was on a track day. I had a TVR took it to tracks and thought I was a racing god. I then got the opportunity to go out with a proper driver. It's a different world there skill levels are awesome, you think you can drive but in reality you can't.
So I now take the ABS / TC and ESP because if I need them I'll need them because I don't have the skill.
No, cos in order to do that people would have to be thinking about what they were doing. They mostly don't!
Two things everyone likes to think of themselves as above average at - sex and driving.
A criticism of either is never well received 🙂
I wouldn't mind having sex with a few of the bad drivers I see on the school run mind you
Hehe 🙂
I'd add debating and critical thought to that list, for STW at least.
I had a hire car with esp of some sort at HTN - getting out of the snowey carpark was amazing - you could feel it making the most of the grip and I was surprised
No great downside to it as far as I can see.
molgrips - Member"Nah. Risk Compensation will sort that out. Folk will just driver faster.
Thats not how it works - risk compensation is not a concious choice by and large
It makes a difference how safe people FEEL, not how safe they actually are, imo.
So if you are in a big cushy car where it feels stable and doens't look like you are going fast, people might faster. Doesn't make any difference how that car actually performs in crash safety or when taking evasive action.
Safety is one of the main arguments people in the US use in favour of big SUVs and trucks, despite them not actually being any safer overall. And in some cases much worse than average.
... but whats good about ESP is that the care feels and handles the same, it only works when you take evasive action. Risk compensation is likely to be low.
I think the risk compensation thing is overstated anyway. How else have the number of people killed dropped from 8000 to 2000 despite millions more cars on the road?
Thought this post was about 15yrs old...never not heard of a new car these days without ESP as standard. I'd get it. Having done various driving courses and seen the benefit on and off, it can save your bacon if it all gets a bit sideways...
Nope - because people take evasive action and don't lose control or even feel like they might lose control, so they learn they can drive faster. Likewise it compensate for them hitting a wet/icy/diesel patch, so they don't drive with respect for these hazards.
Safer roads (e.g. crash barriers) and better collision protection (seatbelts, airbags, roll cages, side impact bars, crumple zones, deformable bumpers).
Are you suggesting people drive much better now than they did say 20 years ago?
If I stripped out ALL the safety features in your car and put a big spike on your steering wheel pointing directly at your heart, would you drive the same as you do now?
Yes, but ESP etc are so vastly ahead of human control capabilities in the most part even the higher driving speed is likely to be negated by the additional control. Obviously up to a point.
Personally I quite like a car where I can feel it losing control and play on those boundaries, but in a normal traffic/car situation I like having the aids to give me the best possible chance.
I believe that ESP is a feature on all cars sold in Inverness. Given that no f*cker here ever uses their indicators, Extra-Sensory Perception is the only way I can see of working out which way they are going.
I think you're mixing up traction control with The Batmobile 🙂
