Is cafetiere coffee...
[Closed] Is cafetiere coffee different from drip coffee?
4 Users
Is the coffee which is designed to go into cafetieres more coarse than the coffee designed for drip machines?
Posted : 03/05/2012 8:35 am
[url= http://www.passionforcoffee.com/enjoy/grinding/ ]from here[/url]
A coarse grind is needed when brewing in a percolator. A medium grind is the most popular grind, and is used by most people who grind coffee at home. A medium grind is used for the electric drip and French press* methods of brewing coffee. Most home coffeemakers are electric drip coffeemakers with flat baskets.
A fine grind is used for the vacuum and Neapolitan flip methods and in machines with cone-shaped filters. Water does not have much time to mix with coffee in a cone shaped filter, so the coffee used in these filters needs to be ground finely. This way, the water comes into contact with the maximum amount of flavor constituents. A very fine grind is only used for making espresso.
*cafetiere
so that suggests medium grind for either
Posted : 03/05/2012 8:52 am
Thought it was the same but no doubt some afficionado/barista/**** will be on soon to tell you
I'm wrong..
Posted : 03/05/2012 8:53 am
Coarsest grind = cafetiere, then filter, then espresso. You can use filter for either but you'll get more crap in your cup if you use it in a cafetiere.
Posted : 03/05/2012 8:55 am
