Is a cracked headli...
[Closed] Is a cracked headlight an MOT failure?
11 Users
As I could do without the expense of buying a new one.
Still works fine and not water is getting in.
Ta!
Posted : 14/05/2010 11:00 am
I think so I had smashed fog light and got failed for that.
Posted : 14/05/2010 11:02 am
 WTF
Yes it is.
Ebay or local scrappy for replacement.
Posted : 14/05/2010 11:05 am
funnily enough one of my front foglights is completely smashed and it's got through 2 MOT's like that.
Posted : 14/05/2010 11:07 am
I think front fogs aren't part of the tests (rear one is)
Posted : 14/05/2010 11:08 am
[url= http://www.ukmot.com/index.asp ]Link for all things MOT.[/url]
Posted : 14/05/2010 11:19 am
yeah, not because of the lighting aspect but because of the dangerous sharp bits on the car aspect.
 Haze
Mine got through loads with a cracked headlight, finally had to get it changed on the last one as it had began letting water in.
I used the same garage everytime (if that's relevant?)
Posted : 14/05/2010 11:26 am
 hora
Ebay
Posted : 14/05/2010 11:36 am
I don't think so as long as it doesn't affect the beam pattern.
Drive to the garage where you are going to get it tested and ask the examiner to have a quick look.
Posted : 14/05/2010 11:40 am
No, as long as it doesn't effect the beam pattern.
I've mot'ed a few vehicles fine with cracked lenses. If in doubt use some thin black tape over the crack to stop it deflecting the light.
Posted : 14/05/2010 11:50 am
