iPod scren replacem...
[Closed] iPod scren replacement
4 Users
My wife dropped my son’s ipod on the driveway yesterday and the screen is smashed. It’s working fine just couple of cracks and a chip on the screen.
Is screen replacement a diy job, if not can anyone recommend a company that does this? Preferably in the Glasgow area but if not then somewhere I can post to with a quick turnaround. Cheers.
Posted : 26/04/2011 9:06 am
I used this lot [url= http://www.ukipodrepairs.co.uk ]Ipod repair[/url] to sort mine out when it died. Nowhere near Glasgow, but they do have a speedy turnaround.
Posted : 26/04/2011 9:19 am
Thanks for the info. Having looked at doing this diy then sending it away looks like the only option.
Posted : 26/04/2011 11:01 am
Its pretty easy to replace the screen on an iPhone.
There are usually plenty of how to vodeos on youtube. Parts probably available from amazon.
Posted : 26/04/2011 11:05 am
This any use?
[url= http://www.youtube.com/results?search_query=ipod+screen+replacement&aq=0&oq=ipod+screen+ ]HELP?[/url]
Posted : 26/04/2011 11:06 am
Can you point me in the direction of the one you used bigyinn as everything I've read makes it sound very tricky. Its an iPod touch btw.
Posted : 26/04/2011 11:07 am
I did it on an iPhone 3gs, which is pretty similar inside to an iPod touch.
From what I remember, there are 2 screws at the docking end, you unscrew them, and then the screen pulls out using a suction cup.
Theres a couple of slightly fiddly ribbon cables to undo and that's about it.
You need to heat the existing screen with a hairdryer to soften up the old glue to remove the broken glass.
Its pretty easy, just take your time. Do the work on a table or tray to catch any screws you might drop.
the glass and digitiser's are about a tenner IIRC.
Posted : 26/04/2011 11:39 am
Posted : 26/04/2011 11:41 am
[url= http://www.irepairglasgow.com/ipod-repairs.php ]Here is a place on Argyle Street that repairs them.[/url]
Posted : 26/04/2011 11:43 am
Thanks bigyinn. From the quick look I've had I thought you had to get the back off and take all the insides out.
Posted : 26/04/2011 11:44 am
Shouldn't need to touch the back.
Getting the back replaced was a REAL PITA. I've done it, but it was rather fiddly.
Still it worked again after I put it back together again!
Posted : 26/04/2011 1:43 pm
