My girlfriend wants me to install a catflap into our back door, which is a UPVC panel door. I have no idea whether the door panel is UPVC right the way through, or UPVC over board or something.
Anyway, I was thinking angle grinder with diamond disc...?
Probably just insulation in there, I'd drill a pilot hole and then use a jigsaw.
The vet will do an injection for a lot less mess.
You can get upvc door specific catflaps with a longer tunnel
I put a flap in our upvc door...as above I just drew round the template, drilled a pilot hole and then used a jigsaw.
The core of mine was just polystyrene.
We got one of those flaps with the microchip locks....sureflap, I think...
As stumpy said - our was double skin of,- can with expanded foam type,insulation between.
Template/pilot hole, jigsaw.
Sure flap here, metal faced door with polystyrene core, draw round template drill hole, used jigsaw.
I needed to get the plastic spacer because the metal interfered with the magnets or some such.
I bought a replacement panel for ours and put the catflap on that. As above, drilled a hole and used a jigsaw. Original panel is in the loft for replacement when we come into a couple of nice little rugs and the house stops smelling of fresh feline wee.
yep, drill and jigsaw for us too.
Remember that uPVC doors often have a sheet of foil down the middle which breaks those magnet catflaps. The microchip ones work fine though...
What a helpful bunch of replies.
Thank you everyone - jigsaw it is.
