Ineos Grenadier giv...
Ineos Grenadier gives cyclists a Toot
Tooting your horn at blind corners and so on is correct usage. tooting behind cyclists is not and serves no purpose but " get out of my way pleb"
Posted : 09/07/2021 2:35 pm
wobbliscvott - damn right you get a signal of disapproval because its incorrect usage of the horn saying - get out of my way pleb
Posted : 09/07/2021 2:36 pm
Well that was the design brief but it’s suffered serious scope creep.
Has it? Seems to be pretty much what was promised when the first teaser video's came out. Sure there will be a long and expensive accessory list for people to spec it up if they really want to spend serious money...but fundamentally it's got the suspension and 4x4 set up that was promised and all the fundamental off roady stuff. They may have tarted up the interior a bit bt that's just cheap tatt and hardly 'scope creep'. Just bolt on stuff borrowed from the BMW parts bin and others. And these days people do want some niceties even in their 'work' vehicles. Seen a modern day tractor? Got A/C and kick ass stereo's and everything these days.
Posted : 09/07/2021 2:39 pm
get out of my way pleb”
If your horn said this it would be pretty impressive but also it'd be an MOT failure
Posted : 09/07/2021 2:50 pm
 poly
Not sure what the toot sounds like but if it is a polite noise it will work in same way as the polite noise my bike bell makes.
Coming up behind people walking, polite bell ring, they are then aware of me and say thank you as I pass them rather than me just riding past and catching them by surprise.
Just so you know I don't find 90% of bike bell use polite either! I live right next to a canal tow path and they are more often than not rung far too late and with exactly the same "let me past" message. Other than people with headphones in I've never found a need to ring a bell to make walkers aware of my presence except at tunnels/bridges etc - but I'm usually quite happy to hang behind people rather than blast past.
Posted : 09/07/2021 3:30 pm
sirromj
Is there anything worth reading on pages 2,3,4 of this thread
Don't worry, luket and kerley have start the same discussion up again, so you can start from page 5.
Posted : 09/07/2021 4:05 pm
Sorry, I skipped pages 2,3 and 4.
There won't be anything worth reading though as it is split between people thinking a polite warning is the same as a blast on the horn and others thinking it is just courteous.
Other than people with headphones in I’ve never found a need to ring a bell to make walkers aware of my presence except at tunnels/bridges etc – but I’m usually quite happy to hang behind people rather than blast past.
I ride on gravel roads most of the time and pretty much every ride there are people walking along not really thinking about bikes coming past so making them aware (when I am a good distance away) is polite and let's them know I am coming. Pre bell they would sometimes jump in shock when I was by the side of them.
Posted : 09/07/2021 4:20 pm
I'm surprised no one's suggested they drive one up behind their own TdF team and see if the toot helps them go a bit quicker!
Posted : 09/07/2021 4:33 pm
wobbliscott
I really struggle to see how some people are struggling with this concept? Seems a pretty good idea to me.
I think this is the whole thing... Nobody really struggles with the concept of the "polite toot" which people will use considerately and thoughtfully in a way that provides a net benefit for motorist and cyclist. It's a perfectly lovely fantasy.
But in the real world that'll happen, ooh, 1% of the time at most? In practice they've put a picture of a bike on a horn and that will mostly encourage people to honk horns at bikes. It'll be a get-out-of-my-way button way, way more often than it's a "polite toot"
Posted : 09/07/2021 4:39 pm
When you post something hinting at directional audio cables and no one cares…
Posted : 09/07/2021 4:50 pm
because this is not what horns should be used for, its dangerous and adds to the entitlement of many car drivers
There is NO such thing as a polite toot behind a cylist. You should not be doing this
Posted : 09/07/2021 5:58 pm
This is from the highway code guidence
A horn should only be used when warning someone of any danger due to another vehicle or any other kind of danger, and not to indicate your annoyance.
So you should NOT be using your horn behind a cyclist
Posted : 09/07/2021 6:11 pm
Are we back to opinion vs fact or was that another topic?
Posted : 09/07/2021 6:26 pm
Its opinion backed by the highway code. See the guidence above.
Posted : 09/07/2021 6:30 pm
Is it a horn though. Has anybody actually heard what it sounds like and how loud it is in real life, stood in front of the vehicle?
If I cycled around blowing an air horn at walkers that is very different to me clicking on my mechanical bell...
Posted : 09/07/2021 7:16 pm
It does not matter what it sounds like. the horn is there if someone is in danger and if the car driver driving properly they will not put the cyclist in danger.
Posted : 09/07/2021 7:24 pm
Well they could have avoided all this negativity by having a green button.
Posted : 09/07/2021 8:24 pm
@tjagain
Letting someone know you are behind them or approaching them IS letting them know of a potential danger.
Plenty sound a quick toot on the horn behind me and I appreciate it.
Maybe take the massive chip off your shoulder and get over the fact that not everyone hates you and some are just being polite.
And I don’t care what the Highway Code says , it’s not law and is open to interpretation, hence why it is so vague
Posted : 09/07/2021 8:36 pm
And a car coming up behind a cyclist is not a potential danger???? I think it is. So yes you should and can be using your horn to toot a cyclist...its what the advanced motoring bods teach...and most of what's in the Highway Code is not law...its the hghway CODE, not the Highway LAW. Better tooting your horn to warn a cyclist of your approach just so they know your coming rather than the way its used today i.e. as an audible way to stick a finger up at someone who's p-d you off...often sounded after the event when the danger has passed.
Seriously what harm could it do if everyone realised the meaning of it and appreciated it..you never know there might be fewer cyclsits knocked off their bikes.....God forbid if we arm people with more situational awareness!!
Posted : 09/07/2021 8:38 pm
Have you never been passed by a mate when they're in a car and you're on a bike?
Pretty easy to tell a friendly toot from a mate.
Note the guidance says Danger not potential danger - and if the car is being driven properly its should not even be a potential danger
I am always astonished how anti cyclist this forum can be
Its so clearly against the guidance to use a horn in this way
Are you really saying you are a potential danger to every cyclist you pass? Jeepers you need your license taken away ASAP
Posted : 09/07/2021 8:44 pm
Rubbish . Your simply trying to justify your nonsense.
Posted : 09/07/2021 8:50 pm
Oh the ironing....
Posted : 09/07/2021 8:54 pm
Brads - highway code makes it clear the horn is only to be used if there is a danger. Now are you a danger to every cyclist you pass?
If you cannot pass a cylist safely then hand back your license. Using a horn in this way is clearly against the highway code
Posted : 09/07/2021 9:36 pm
Blimey, I came here for a bit of light relief from speaker cables.
Posted : 09/07/2021 9:47 pm
Oh the ironing
Explain
And the Highway Code is a guide.
Not one right minded person should see a problem with a considerate driver letting cyclists know they are approaching or are behind them in some situations.
Your pretty much disagreeing for the sake of it.
Posted : 09/07/2021 9:50 pm
Bollocks do they. You don't half post some shite.
Posted : 09/07/2021 9:51 pm
Anyone who toots their horn when approaching a cyclist is a bellend.
Posted : 09/07/2021 9:54 pm
Bollocks do they. You don’t half post some shite.
Seriously , stop talking pish.
Your telling me no one has ever sounded a horn just to let you know they are there?
If not maybe it’s because they know you.
Posted : 09/07/2021 9:58 pm
In 15 years of cycling 9 miles each way through Black Country traffic, it has never happened.
Perhaps it's because I'm not a ****.
Posted : 09/07/2021 10:01 pm
Never no. I have had people toot "GET OUT OF MY WAY PLEB" but never a freiendly toot no.
some of it is law, some is guidance, not following the guidence is poor driving and can lead to prosecution
Posted : 09/07/2021 10:02 pm
No considerate driver blows their horn behind a cyclist. Its dangerous.
Posted : 09/07/2021 10:03 pm
I give up.
Bullshit overload and the arrogant tits have arrived
Complain away . The worlds not listening but your echo chamber is
Perhaps it’s because I’m not a ****.
Somehow I doubt that
Posted : 09/07/2021 10:04 pm
" he's a boring troll TJ, I should know better after the last time he got upset.
Posted : 09/07/2021 10:05 pm
Actually scxc - I don't think he is. Brads is a man with a very different world view to me and the multiple world views on here make it valuable
I know from experience if you have a minority view on here then its hard not to get annoyed
Posted : 09/07/2021 10:07 pm
We'll disagree on that
He outed himself a while ago.
Posted : 09/07/2021 10:09 pm
sc xc - a troll is someone who seeks out deliberately to wind yup others. I don't see Brad doing that just expressing his view forcefully
Posted : 09/07/2021 10:29 pm
Don’t worry, luket and kerley have start the same discussion up again, so you can start from page 5.
Haven't we just?
Sorry!
Posted : 09/07/2021 10:58 pm
TJ & SCXC - I think you'll find that quite a few people on this thread disagree with your views on this issue.
Posted : 09/07/2021 11:00 pm
indeed a few do. shame they are wrong both in law and in practise 🙂
Posted : 09/07/2021 11:10 pm
I think we need to define the competency of the cyclist in question,
A lockdown noob wobbling everywhere with no awareness needs a full fog horn blast whereas a Colnago Rapha buffer needs a toot and 'STRAVA!' shouted outta the window.
Posted : 09/07/2021 11:17 pm
 aP
pedlad
I’m surprised no one’s suggested they drive one up behind their own TdF team and see if the toot helps them go a bit quicker!
About 8 years ago I was riding the Paris Roubaix ride the day before and an Astana team car turned on the sector. After about 5 minutes of sitting behind middle aged heros (yes, me) whoever was in the car put their music on through the external loudspeaker - Highway to Hell.
Bastards.
Funny though 😊
Posted : 09/07/2021 11:29 pm
Agree, but again, has anybody actually heard the toot? Is it a quite and more polite noise in comparison to a horn as presumably it is not just another horn as there is already a horn for horn stuff?
And clearly you don't need to let a cyclist know you are behind them but a case where it could be used if if you are following a group of cyclists who are spread across the whole road then you could give a polite toot to let them know you will be passing and they could organise themselves to more easily allow it as even going completely onto the other side of road means you are close to the outside rider. Just road manners from both parties and using an actual horn in that scenario would be aggressive and wrong.
Posted : 10/07/2021 8:22 am
Strange how I don't remember a driver needing to "toot" at me ever when riding a bike. Polite or not.
Posted : 10/07/2021 3:30 pm
Only dangerous drivers use a horn like that. Because a horn is only to advise of danger.
Posted : 10/07/2021 3:37 pm
Page 5 / 6
