If I cut a corner o...
[Closed] If I cut a corner off a square, how do I work out what i'm left with?
15 Users
Example:
A square has equal sides of 2860mm
I cut one corner off so that I have an opening of 1420mm
What length are the 2 now shortened sides?
Posted : 11/08/2021 3:04 pm
It depends what you mean by "an opening of 1420mm"
Posted : 11/08/2021 3:06 pm
The 1420 is the hypotenuse so the square of that, divided by 2 is the square of the length you need to deduct from 2860.
1856 is the number you asked for.
Posted : 11/08/2021 3:09 pm
What angle is the opening relative to the sides?
Posted : 11/08/2021 3:10 pm
Is there an assumption that the shortened sides are still equal in length?
If they are, the cutoff is a 45/45/90 triangle with a 1420mm hypotenuse. The ratios there are n:n:n×√2, so you can divide 1420 by the square root of 2 to find the length of the missing part of the side, then subtract that from your side length.
If the cut isn't even, you're going to need more info.
Posted : 11/08/2021 3:11 pm
 loum
1856mm
This is just basic trig, isn't it, assuming your cut off corner has 2 equal lengths.
If a^2 + B^2 = c^2 and c^2 = 1,420mm
then a & b are 1,004mm and the remaining sides of the original square are 2,860-1,004 = 1,856mm
Posted : 11/08/2021 3:12 pm
 loum
Not allowing for any thickness to your walls.
That's "external", if that makes sense.
Any thickness to your walls and the clear opening won't be 1420.
That's a different calc, depends exactly what you're trying to achieve.
Or cut the entrance at a 45 degree angle back into the square, maybe.
Posted : 11/08/2021 3:15 pm
Damn, it's amazing what you forget when you don't use it.
Thx all
Posted : 11/08/2021 3:16 pm
That’s “external”, if that makes sense.
Any thickness to your walls and the clear opening won’t be 1420.
That’s a different calc, depends exactly what you’re trying to achieve.
Good point - then the answer is probably just to buy a new bike
Posted : 11/08/2021 3:17 pm
Has someone cut the carpet too short again?
6' 1 1/16"
Posted : 11/08/2021 3:20 pm
If you cut each of the four corners off, you won't need to use Blutac in each corner to stick your poster to the wall.
Weigh it obvs.
Posted : 11/08/2021 3:34 pm
Measure it.
Posted : 11/08/2021 4:08 pm
Is no one going to ask: ‘Why? What are you making ?
Posted : 11/08/2021 5:16 pm
Well I'd be a bit suspicious if they weren't equal.
Posted : 11/08/2021 5:41 pm
This is a substantial flapjack.
Posted : 12/08/2021 8:00 am
Flatpjack is rectangular. Now millionaire shortbread...
Posted : 12/08/2021 8:11 am
How do you know the opening is 1420mm? Take whatever you used to measure that to measure the sides.
Posted : 12/08/2021 8:56 am
