Pasta for lunch today.
Absolute proof you now believe everything iDave ever wrote to be tosh. 😉
No problem with pasta, I hope it had chopped up avocat, red/green pepers, boiled egg, apple, tomatoes etc. in it.
Neither of us are physiologists. One of us has tried the iDave diet, one of us hasn't. We're both intelligent science-educated people. Who do you think would know more about the diet's effects, and why?
I have a feeling that it becomes less effecive the more times you yo-yo on and off it. My commitment to it certainly does.
Anyway - I am working away from home, so iDiet compliant food is in short supply. Low GI is the best I can hope for.
Back on topic: squatting in the gym is causing my ITB to really hurt when running, years after I sorted it out. There are two possibilities:
1) Trying to run in between two days of weights is not a good idea for some reason, or
2) The squats have strengthened some muscle and not some other, which causes imbalance and hence ITBS.
MFP doens't calculate calories burned for a gym workout. I've added a token 500cal for a workout - sound reasonable?
Yes, really hard to work out what 5x5 squats equates to. I had a good google a while back and gave up.
I just figure you have to deduce it by subtracting Basal Metabolic Rate from MFP guesstimate consumed calories when you're not gaining / loosing weight and doing the regular gym sessions...
More likely, strength training generally shortens muscle range of motion as a side effect, so you need to regularly stretch to maintain full range of motion (to be fair, doing nothing will also reduce range of motion). Also if your quad muscles get bigger, the path of the ITB will alter slightly, which may cause more friction. Strecthing / SMR would be the first suggestion.
I've started doing some [url= https://www.gymnasticbodies.com/ ]Gymnastics Bodies[/url] courses and they use the rest period between each set of strength work to perform a stretch / flexibility movement. Pretty good idea as it means the dead time is fully productive.
When I had ITBS originally, foam rolling (assume this is what you mean by SMR) fixed it instantly. It also hurt like hell. Now it doesn't hurt much at all, I can roll easily, but it doens't help.
I'm going to include standing hip abduction (if I can find a machine) for gluteus medius, and 30 degree leg extensions for vastus medialis. Both those muscles are implicated in ITBS by some people on the internet...
And of course I'll stretch as I usually do.
yep, the 'posh' name is Self Myofascial Release.
Get a harder roller! 😉
Probably try stretching, there are a load of ITB specific steretches...
NB [url= https://stretchtherapy.net/ ]Kit Laughlin[/url] gets good reviews and is supposed to be good value for money.
I've done most of the stretches for ITB, still no improvement.
Will keep on top of the regular stretching and then see if these exercises help. Hip abductor first. TBH I'm not sure it will. Lots of pages said do squats to *help* with ITBS.
Unless maybe I'm going too low? I have thighs parallel to the floor.
Unless it's not ITBS that I'm feeling...
Coud be the end of my hamstring rubbing on something?
The limit is geometry specific, some people just can't get low due to limb length ratios. Another factor is your lower back rounding out (geometry and flexibility), only go as deep so that you can keep a neutral lower back (best to get someone to watch you under load and they will see the 'but wink' when you hit your limit).
Good video here on limb lengths and squatting:
aka half squat; the minimum depth for a power lifting comp. Pretty normal to go this deep and that's the minimum most people should aim for.
No idea about your specific ITB issue, might be worth consulting a Sports Therapist who can watch you squat and give some pointers on technique. Eg do you keep your knees out or let them come in at the bottom (common fault when Quads are weaker than glutes and you're trying to recruit the quads to get out of the hole) but it puts more load on the knees..
I'd better video myself tonight 🙂
Looks like my pain might be biceps femoris tendon pain. It's actually a better fit than ITBS. This never came up in the hours of googling I did about this years ago.
Just noticed he has a video on the 'squat like a baby' miss-conception....
Me squatting. The bar looks like it's dipping to one side, but that must be an illusion - I'm sure I was all square.
Knee tracking looks pretty good, but then the weight also looks pretty easy for you, so I'd expect good form.
A side on video would be good as well....
My coach would probably say go slower and wait for the glutes to kick in at the bottom, again probably more relevant when you're near max weights.
I probably squat at half that tempo or less, even with light weights.
I wouldn't call it easy, but it's a weird thing. I'm not really tired after any of this - nothing aches, but my limit is going to be reached before long in the squats and already in the overhead press. Only just managed to get 5x5 in that and yet my arms feel like I did nothing.
It's like I'm struggling to activate the muscles rather than being at the limit of what they can do. After all, this is much less work than hammering up a steep climb on the MTB and I do that loads of times in a ride!
I reckon you're leaning too far forward Molly
Just to complete the set of 'old guys in the gym', here is random vid of me squatting during rehab for my patella tendonisis. Progressively lower box squats (1cm a month). I'd guess this was about 110kg.
Without a limb length analysis you can't really tell what is normal for his build...
Well I'd fall over otherwise...?
Regarding calories, I'm doing the icf 5x5 which is stronglifts 5x5 with accessories. In mfp I allow 300 calories per workout (I'm 80kg, workout time is about 90 mins). I based this on a calculation I found somewhere, will try to find the citation.
Have to say though, I am really enjoying the lifting and the results have been great in both strength and also how I look and posture. Better for the winter though, as above in the thread it's quite difficult to combine with riding and feel like I'm making progress in both.
Ps really enjoying also the diet side of it an understanding / experimenting on how my body responds to stuff!
I was thinking of measuring my ankle to knee, knee to hip and hip to shoulder lengths and building a model to analyse my geometry as with the guy and his mechanical model. This work out what angle I would expect to lean forward for with a back squat at varying loads...
How do I know this, well learning this cost me £220 for a new Olympic Bar at my gym (I insisted on replacing it for such a school boy error). The stool was completely unmarked even with 120kg dumped on it.
Heh
I'll bet a few gym folk were put off their stroke with that racket. I squat in a rack these days - less to think about for me, allows me to focus on the move.
I hit the weight with good form on Wednesday so last Friday and Monday's semi-good mornings were probably just lack of focus and sleep. Been feeling a bit mentally knackered recently but all the stuff about lifting on this thread obviously forced me to get a grip.
bone oedema
If you don't mind being candid, what's that all about...?
Me, too. I drop all the way down - arse to the grass style and pause briefly at the bottom - but I'm super flexible.
I'd post up a vid tp show how deep I can get but I've just had a look through and all I have is an old 40kg squat from quite a while back and it'd get pulled in an instant as I'm only wearing underwear.
I don't get aching either.* I did last year but I think a good diet can sort this. That and some decent sleep - I think it all makes a massive difference to how you feel and lift. Also, I used to do shakes but only use them if I'm time poor now. That greek yogurt breakfast I listed on the other page contains almost 45g of protein and fills me much more than a shake. A few more calories but worth it. Steak is also good, topped with poached egg as suggested on that other thread.
*Injuries notwithstanding. I have a dull ache in the clavicular portion of the chest which gives a bit of gyp now and again when benching.
el_boufador » really enjoying also the diet side of it an understanding / experimenting on how my body responds to stuff!
Yeah, likewise. Even more so now I'm trying to bulk a bit and having to tuck away a fair old bit. mmmm
I can go all the way down, and I did originally cos I find it slightly easier, but some internet said that it wasn't worth going lower than parallel...
I just don't feel like it's doing much for me when I half squat. Dropping so my heels touch my arse [i]feels[/i] to me like I'm using more of my lower torso to get back up.
I was under the impression that going beyond parallel was the desired movement. I'm interested in having a read of some internet stuff if you have it to hand.
There's mountains on the internet. This seems reasonable though:
There are few exercise topics that incite as much debate as what constitutes the correct depth for a squat. One school of thought counsels you should only descend until your thighs are parallel to the floor – any deeper and the likelihood is your knees will explode. Another sneers at any squat where your hamstrings don’t cosy up to your calves.The truth is neither side is right. Forget depth. Your back is what matters. You should squat no lower than the point where your hip begins to tuck under and you lose the natural arch in your lower spine.
I can get all the way down with a straight back. So I might get back to that. I find it a little easier cos there's a little rest at the end, whereas stopping parallel I have to decelerate the weight with my muscles and then accelerate upwards again.
Well - just took a second selfie, the first was taken when I'd been at the gym for maybe 4 weeks but just as I started stronglifts. So nearly 8 weeks between pics. The difference is...
.. not there at all. I look absolutely identical in both pics 🙂
6 pack is made in the kitchen... 😉
Well it's definitely harder going lower, so if you can then so so.
The load on knees / muscles changes as the angle does:
Going lower makes your Glutes work harder as your quads are quite disadvanted below parallel and can't contribute so much.
bone oedemaIf you don't mind being candid, what's that all about...?
A novice snow boarder lost control on a Blue slope and took me out from behind. I fell onto my shoulder on icy ground and it did a fair bit of damage. 4 months on it's a lot better, but still a 40% tear in a tendon, bone oedema and an inflamed bursa. No external rotation and limited overhead range of motion.
Impact site is quite clear in the MRI
[url= https://c1.staticflickr.com/5/4176/34404885176_02738143b7.jp g" target="_blank">https://c1.staticflickr.com/5/4176/34404885176_02738143b7.jp g"/> [/img][/url][url= https://flic.kr/p/Uqf2Hs ]Shoulder MRIa[/url] by [url= https://www.flickr.com/photos/brf/ ]Ben Freeman[/url], on Flickr
Interesting graph footflaps, but that sort of backs up the point that going lower doesn't make any differece to what's going on? Assuming 90 degrees refers to knee angle and not angle with vertical...
You would be doing more work though simply by moving the weight further.
If you just touch parallel then you're only just maximally tasking the Glutes for a tiny moment. If you want to properly train them, you need to go lower (or do another glute specific exercise).
A good article on partial vs full range exercises:
https://www.strengthandconditioningresearch.com/perspectives/partial-squats/
One graph from the article
[img]
?resize=1024%2C1024&ssl=1[/img]
They're well worth following on FB, put up loads of good stuff on weight training.
NB My main Glute exercise is barbell weighted walking lunges - kills my glutes. I used to do overhead, but now just do back squat walking lunges (due to a duff shoulder). Overhead is a much better overall workout though...
I do mine in the garden on a sunny day...
Do I really care tho?
I'm only doing this
a) for the general physiological benefits of weight training as have been documented
b) it might help my cycling
Seems to be doing b) from what I can tell.
Up to you really. Personally I want to maximise the benefit from any training I do, so if a small change makes a difference, I'll make that change. Also, I like to understand why I'm doing it and how it's working, not just follow a plan blindly.
Re cycling, the main crossover I notice is my acceleration from zero on the single speed, I have so much more power available now and can just accelerate off the mark way quicker than I used to.
It seems easier to do the steep climbs for me. So I can do them at a lower level of exertion, which means can ride my steep local trails and be less trashed which means I end up eating less.. or at least that's how it seems.
That may not stand up to physiological scrutiny, but it feels that way for now. It'll be interesting to see if it helps me do the 5-6hr rides on the even hillier terrain.
Try doing barbell step-ups onto a block just above knee height.
Very similar movement pattern to a walking lunge...
Precisely.
(basically forcing him to go below parallel)
Nasty. Shame about the shoulder limitations. An injury in that area would drive me nuts.
Good luck with recovery.
Likewise. I started quite naive just going through the motions and focusing on form without really thinking about the benefits but I'm a little more clued up with that now and know exactly what I want to achieve and how to do so.
I love lifting weights and combining it with some explosive stuff - I can get a good body that's totally functional in daily tasks, too. It's replaced cycling for me at the moment.
Well, I've given up on squats every time. I think they're causing some sort of muscle imbalance that's causing the knee pain.. and now I can feel my patella tracking out of line again.
So it's two sessions of deadlifts to one of sqauts on a three session rotation, and I'm trying leg extensions on a machine to see if it helps the knee.
Also trying 3x10 rather than 5x5. Deadlifts much more satisfying.
I have a love hate thing with them. They keep putting my QL muscle into spasm on one side, been going on for years. I almost dread doing them now. Got to within 2kg of 2xBW last year, but can't get close now without the QL going into spasm, which puts me out of lifting heavy for a couple of days.
Interesting. I must get an endorphin rush off it or something because I do enjoy it. I did 3x10 80kg last night.
When you quote 2xBW are you just talking one rep absolute max?
I'll run tonight having not squatted for nearly two weeks and also stretched my quads. See how that goes.
If you were training 3 days then big deadlifts are a once a month exercise.
If i do a couple of warm up sets and then 3 sets of 150kg then a 1rm of 160 @ 60kg bodyweight then i am busted for 3-4 weeks before doing it all again.
I'm on instagram if anyone is interested in my training @fiftyplusfit
either you've gone too heavy too fast & although your big muscles are up to it the smaller stabilising muscles aren't yet or it's just a technique thing (i.e. you aren't doing it right). (Or both!) I made both of these mistakes when learning to squat... took me ages to get the proper technique down. If I were doing it again I'd definitely get someone good to teach me!Well, I've given up on squats every time. I think they're causing some sort of muscle imbalance that's causing the knee pain.. and now I can feel my patella tracking out of line again.
I followed the Stronglifts programme which started really light, something like 40kg. I couldn't find any reference online to squats causing problems with running, but there's a definite correlation between that and the knee problem I hadn't had for years.
It might also just be a tightening up which could just be me - I've also started stretching my quads with the traditional hold the ankle to your bum pose. That may also have helped - I'll try a run tonight.
You're definitely 'hench', Twinwall. Those veins are awesome superhero stuff, too.
Like this pic and accompanying text...
[i]Here was going to be an AWeSoMe picture of me deadlifting two and a half times bodyweight, unfortunately the person, (not to be named) even though they insisted they had the shot, did not have the shot, so here's me getting creative. [/i]
Careful... you might get accused of virtue signalling or somesuch... 🙂
Patella pain is more than likely tight calf muscle, do calf raises and stretch it/foam roller.
How's the weight loss?
The big problem is with outside of knee - could be ITB, could be some other mystery tendon.
Lost a little before my holiday.. waist is slightly narrower though.
yep, I normally do a 5x5 style ramp eg 5x70, 5x90, 5x100, 5x110, 5x120, 5x130 and then singles / doubles up from there eg 2x140, 1x150, 1x155, 1x160 etc
Although I've not got past 1x140 recently due to the QL thing....
I would only do deadlifts once a week though, too much load on CNS to do more often.
My body doesn't work like that at all, anything over a 1 week rest and I can't get anywhere near max for squats or deadlifts. I have to lift heavy at least once a week to be able to maintain max strength.
I'm at ease with my lack of sexuality. 🙂
If you are having issues with squat depth etc, worth reading or rereading Starting Strength by Mark Rippetoe.
The only thing I have slight issue with in it is around toe position. If you are training for cycling (or field sports) then toes forward is better than having then splayed out at 30 degrees. If you're not bothered about cycling performance then 30 degree splay is great.
Back should be neither straight nor vertical throughout a back squat.
The back should keep it's natural soft S shape and the bar should track over the midfoot as you bend at the waist through the movement.
Front squat is different obviously.
He's very dogmatic / rigid and takes no account of people's varying limb lengths. There are much wiser resources out there (see vids I posted a couple of pages back).
When you lot were grunting away at 2x BW did you find it helped your cycling? Or are they not complimentary activities?
Last year before the op and massive calorie deficit experiment I'd ridden my bike about twice before hooking up with mate for a local blast that starts with a hill climb. I flew up without much effort - even tempted to say it was easier than before I started lifting but, tbh, by comparison I was weak as piss before the weights though I was no slouch when it came to moving heavy objects. I was 71kg then and deadlifting 140kg (160 1RM) so not quite 2xBW but close enough.
Contrary to this...
...I was doing it twice a week on alternate weeks for sometime and am doing the same now. Perhaps 140kg just isn't heavy enough to stress the CNS but I reached that weight again this week and it doesn't look like slowing any time soon so I guess I'll see.
As for the squat - have a look at Candito's 9 week squat programme. Some of the accessory stuff is quite helpful for a more balanced development. Sumo deadlifts, for example - good for me after the hernia op as they're working my weaker areas. Check it out, it's all grist to the mill and something to try when you get bored. His bench programme is worth a look, too.
Presumably CNS means central nervous system?
Interesting concept.
Yes.
To correct what I wrote above - obviously the weights are 'stressing' my CNS but not enough to over cook it, so to write.
No doubt in a few weeks time I'll be on a different forum asking why I can't even lift a cuppa, brah...
The problem with all the advice your getting is it's from folk who aren't you. Go to the gym, do stuff, preferably without injuring yourself and learn from experience. Don't be afraid to try new things, if they work for you, great, if not, ditch em.
Training with weights and bodyweight training is a learned skill, patience is the key.
If your going to the gym just to lose weight then you are doomed to fail, you have to love training to truly get the best from it.
I'm currently training the one arm pull up, i'm not expecting to bust one out for probably another six months, but i have the determination to get there.
Great advice!
I noticed the pics on Instagram. That lever with weight, too!!
****ing nutter, you...
I don't particularly enjoy it.
I'm doing it to see if it a) helps my power and b) helps my weight, and also c) because I am travelling without a bike and I don't particularly enjoy running either. Also d) I am getting older.
But...
At least give it a chance, learn a movement and go through the progressions to achieve it.
How about training to do a strict dead hang pull up or a front lever.
No matter how strong or good you are there is always something new to learn and while your busy plugging away an air of henchness will engulf you.
On the subject of CNS fatigue, there is a simple test for seeing if you are fatigued or not..
https://www.t-nation.com/training/tip-take-the-tapping-test-for-cns-health
Ok teasel - fair enough. I like the act of lifting the heavy thing. But it's relative. Give me fair weather and a bike, and the gym wouldn't get a look in 🙂
And it's partly the faff that annoys me. So many exercises for sculpting this or that in a slightly different way or allowing me to lift a few more kg.. don't really care about any of that. That's what I liked about stronglifts - just turn up and do three exercsises as it tells you on the screen.
I've started training for the seven basic gymnastic moves with [url= https://www.gymnasticbodies.com/ ]Gymnastics Bodies[/url]: Front Level, Side Lever, Hollow Back Press, Straddle Planche, Single Leg Squat, Rope Climb (arms only) and Mana. ETA is about 2 years less the couple of months I've been working on them so far.....
That ^^ appeals to me a bit more tbh.
If you want to know more, let me know - I can show you the programming etc..
They're a bit light on detail before you cough up and join.
Another bunch to look at is [url= https://gmb.io/ ]GMB Gold Medal Bodies[/url] similar idea, although I've not paid for their programming but have done one of their workshops.
Thanks for that CNS test, Footflaps. That'll probably be useful in the coming weeks. Got 5 x 145kg deadlift today so a personal best there but I suspect I'm going to need a bit of a rest soon.
No matter how strong or good you are there is always something new to learn and while you're busy plugging away an air of henchness will engulf you.
One day, when you're just a memory, your gym will have that plastered all over the wall as some sort of homage to your veiny form. 8)
Yeah, I think that's for the bodybuilders and their vanity. Doesn't interest me either, though I understand that some folk want to get slightly bigger shoulders or biceps to complete the image they wish to achieve and isolation can be useful for that extra few (barely noticeable) mill of width or "peak". Definitely a long term project that takes high levels of dedication, as far as I can see.
I would like to add weight gaining is not only depends on Gym workout itself...it is all about your calorie intake, body fat and muscle mass....weight gaining either by large quantity calorie, fat through food or by tight muscles through workouts are different in outlook. But the body fat is more soft and the muscle is more "dense and compact. Often when begin a weight reducing task, it will show an initial loss of weight due to body water lose. If you are workout hard with heavy weights to get fit and see a weight gain, by adding mass muscles by burning calorie!. so body weight may go up as you add compact, tight muscle mass. Weight gaining with good fit outlook is slow process. you should have enough patience, good diet and workout schedules... 😀
I agree Gold Medal Bodies have some great stuff online, i also like Alan Thrall and Omarlsuf.
We're currently cleaning the house from top to bottom ready for the estate agent to take pics, now that's a bloody cns shredding workout.
Teasel, i find less is more at the gym, especially with dead lifting, it's a fine line between waking up feeling you can walk through walls and getting your affairs in order.
Yeah, I think I'm going through a mad phase at the moment because I feared not getting back what I'd lost through the hernia op recovery. I feel good - no noticeable fatigue or excess ache. I'm eating lots, too, and the strength seems to be returning very quickly.
As for deadlifting - in the grand scheme 145kg isn't that heavy, is it? I mean, I like to think I'm still right at the beginning of my lifting time as opposed to the end or reaching limitations but I'm almost as old as you so maybe I'm kidding myself.
Ebb and flow - I'll probably feel it's time to make a will in a week or two...
I dunno if I'd want to deadlift 145kg. I mean, I'm a cyclist not a weight lifter. This is all a means to an end, and that end is not lifting heavy weights.
Flexibility is another goal I think. Even the pre and post workout stretches have helped quite a bit.
's cool, Molgrips. No one is gonna force you if you don't want to. 🙂
But, getting all Socrates with a Yoda-esque voice - contemplate this, you must...
[i]“No citizen has a right to be an amateur in the matter of physical training...what a disgrace it is for a [person] to grow old without ever seeing the beauty and strength of which [their] body is capable.” [/i]
But I honestly don't see why the two things have to be mutually exclusive. Strength is strength regardless of application. That's why I lift at present - I like the strength available to me when lifting, say, a large chunk of tree. Or perhaps moving multiple stone slabs or blocks, digging a bloody great hole without feeling weakened or simply getting up from the floor without the aches and pains of age. If you lower your body fat to single digits (like Twinwall) you can even look good. What's not to like...
Well yes and no. Time in the gym might help my cycling but there'll come a point where the effort and dedication required to increase my deadlift say will take enough time away from my cycling to reduce my overall performance.
As for realising my full potential - the time for that has long passed 🙂 And with regards resisting age - stuff like gymnastics, martial arts, yoga, pilates would probably all have more of an effect I suspect.
I'd love to lower my body fat to single digits, but only because it would make me climb like a rocket and win races.
Really? You could easily slot in a session of 30 minutes or less even going as far as just doing DL. Adding just a few kilos a session is easy as you know and before you know it you're lifting twice as much as you found a struggle a month or so ago. Strength [i]is[/i] strength.
What are you - thirty something...? I was fitter at 37 than I was at 25 and I'm stronger now at 49 than I was at 37. When I stop sodding about with weights and complete a few major chores I'll start the hill sprints again. When I was doing that last year alongside the lifting I was the fittest I've ever been - at 48. Two years before that all my joints were aching, cycling was a struggle, general labour tasks were harsh on my body and I was generally knackered. I don't recognise that person nowadays - a weak shadow of my better self.
But hey, I'm rambling. It's your choice. I'm just adding my two pence of bollox.
Yeah but it makes me tired then affects my MTBing the next day.
I guess I could road ride and take it steady, but I'm pretty over that these days.
41. I think I have (or had) the potential to be a proper athelete. It's in my genes, my mum was an Olympic hopeful once (110yd hurdles), I could have followed on but I just didn't fancy sprinting in the end. By the time I found something I did like, realised what it takes to be good at it it was too late and life was in the way.
I should have been a track cyclist or perhaps a rugby player.
Oh Molly, never change x
It's not a complaint, it's a fact. I'm unlikely to win an Elite race now, let's face it 🙂
Agreed, but you could...
Go and have a go at some races.
Sort out your diet and get to single % BF.
Take the advice on here and get really strong.
Stop talking about what you could have been and go and be the best you can now.
That's what the whole thread has been about. Don't imagine I'm sitting around dreaming 🙂
But back on topic - according to the internet and some other threads on here, doing points 2 and 3 at the same time seems to be rather tricky.
