How to repair stair...
[Closed] How to repair stairs?
5 Users
I'm about to replace my stair carpet so I thought now is a good time to repair the last 13 years of abuse by children jumping up & down the stairs rather than walking(yes I'm a grumpy old man).
There not gone, just creaking & a bit loose, my thoughts were to just re nail them down & maybe get a vat of wood glue to put between each plank.
Is there a better way, or is replacement a better option?
Many thanks in advance.
Posted : 07/03/2010 10:29 pm
It will prob be the wedges under the treads that need the most glue and fixing if you can get to them
Posted : 07/03/2010 10:33 pm
2nd the wedges.
If you can get under neath them, i used a combination of screws and some flexible no more nails stuff to fill up any gaps i could get to; seems to have worked ok, plus good underlay.
Posted : 07/03/2010 10:41 pm
Cheers guys, I'll see if I can get axcess when they have told me when the carpet is coming, I don't want to strip the old stuff off until a few days beforehand., if not glue & srew it will be...
Posted : 07/03/2010 10:45 pm
Squeaking is usually due to a nail moving in wood, or occasionally wood against wood. Redoing the wedges will be good and anywhere you isolate a squeak, pilot hole and screw it down. Not sure there's any need for glue.
Posted : 07/03/2010 10:59 pm
Nah fella...you can't do it from the carpet side....you have to get at them from underneath to sort properly...usually needs boarding stripping off.
Posted : 07/03/2010 11:07 pm
I thought talc worked, as in it got down the cracks & crevasses & filled them up, I thought glue would be a longer term solution?
I don't really want to strip the underside of the stairs as I can see that leading to a lot of work 🙁
Posted : 07/03/2010 11:28 pm
Talc will work short term but wont last long.
Careful checking and screwing down from the top side will make a big difference like darcy says.
A friend who couldn't get underneath his stairs used PVA glue and watered it down until he could squirt in every crack he could find - worked well apparently.
Posted : 08/03/2010 12:01 am
That sounds like a plan, a lot less work 🙂
Posted : 08/03/2010 6:10 am
