Just had our back garden cleared and now looking at doing some landscaping and digging foudations for a new retaining wall so need to get a digger into the garden, I don't fancy doing it all by hand.
Access at the back is difficult and nearly non-existant so it would need to come through the front garden and down the side path. Our house is lower than the road with approx 4 foot wall/drop from pavement to garden. Can I somehow get a mini/micro digger down?
Looking at hiring one of these
Hire a drone,they make all kinds of deliveries.
Just did similar last weekend. Used old slaps and wood to make steps then used the bucket and arm to help lower it down. Placed the bucket on the lower side drove out over the gap using the bucket and arm to keep the digger level then slowly lowered and drove forward inch by inch. Hope that makes sense.
Similar to this
dig your way in underneath your neighbours house.
Ask the hire company if they can drop it over the wall with a hiab.
You can get a micro digger that will fit through a standard doorway
[url= http://www.jewson.co.uk/tool-hire/earth-moving/excavators/products/6703/jcb-micro-mini-excavator/ ]Jewsons [/url]
Trebuchet?
Make sure you wear the safety belt. My sisters best friend was killed when his hired mini digger tipped over and he was trapped under the roll bar.
Sorry to hear that Rockhopper ๐ I have to agree mini diggers can be very unstable and easy to tip over when used on uneven surfaces.
Trebuchet
Gesundheit
what abut access from a neighbours garden
Phone the army and see if they need to practice their heavy helicopter lifts and get a Chinook to pop it over the top. ๐
Phone the army and see if they need to practice for the Royal Tournament
Hire a Kanga Kid with a trencher
It's not one to be taken lightly, micros with adjustable tracks are a piece of piss to tip over. I've been driving for years, in fact I'm now actually ticketed and I treat micros with care. Everything happens at warp speed on full revs, do not attempt any tricky manoeuvres with the tracks still "in"
Little 2t taekuchi stoner? Cracking machines.
and chappie could pirouette and pas de deux it all across the site. Class act.
Small diggers are ridiculously unstable. what's the biggest you could get down the side? Your drop is bigger than the effective track length of that digger you linked to. Will need quite a bit of infill to drive it off the edge. Things start to get more steady at 3-tonne. I'm not a proper ticketed digger driver by the way, just means I have to make sure I don't cock it up.
Have you considered an auger for the bulk of the excavation? As long as your ground isn't too rocky you may get away with it and will just have to join the holes.
And a tilt/swivel bucket Stoner?
More 7-tonne I think though.
Trying to do anything like that in the pictures above in anything smaller than a 3 ton digger is almost certain death !
Where abouts are you?
๐ก Pump track, maybe knock the ground floor out too, do it you know it makes sense.
bang on
I have no idea where i got 2t from. It's a 7.5 ton. Tbey piss all over the competition. Can't see why track length would matter though?
I would say use magnesis or attach a couple of octoballoons and waft it with a korok leaf.*
*I have been off work and playing way too much Zelda: BOTW
North Shore woodwork? Seesaw or Helter-skelter - your choice.
If the tracks are shorter than the drop, they won't bridge from top to bottom as you lower down. 3 1/2' tracks would not get you down a 4' drop unless 5.10 are doing digger tracks now.
Not an issue if you have rubble infill to track down, as the drop is reduced.
But up for knowing alternative methods, could get the mini digger in the tractor trailer and save some tracking time.
