I want to print a list of the files in a folder (or copy/paste the list to a document). Only way I can see is ctrl/prtScn in to Word. Is there a better way to do this (ie something i can edit too) or some software to do this?
Ta
open a dos prompt in that folder (shift and right click, open command prompt here
type this:
dir > c:\list.txt
This will give you a directory listing in a text file called "list.txt" on the root of your C drive. Change the name and / or location of your output file to suit
dir /b > c:\list.txt is better if you only want the file names.
You can edit the registry to allow it from Explorer but I always use the nbt method.
At the dos prompt:
dir > myfiles.txt
Would a screen grab not be easier?
Ah forget that, I didn't read the copy/paste bit.
Download Hyena. Browse to the folder in the left pane and double-click. In the right pane, select all the folders. From the menu bar select COPY. Highlight the fields you want. Paste into Word, Excel or Notepad.
I'd do what nbt said, but I'm a bit bored.
Cheers!
Dear [s]Father Christmas[/s] Mr Bill Gates
Please can you add a function to copy & paste the list of file names in explorer
Yours,
40mpg
Hasn't he ripped off enough Mac functionality already? ๐Dear Mr Bill GatesPlease can you add a function to copy & paste the list of file names in explorer
[url= http://www.jam-software.com ]This lot[/url] do some handy software for files and folders including this freebie:-
http://www.jam-software.com/filelist/
I did not know that. Nice.
*Please can you add a function to copy and paste the list of file names in explorer
[url= http://support.microsoft.com/kb/321379 ]Happy Christmas 40mpg![/url]
*Well, nearly!
Had one that listed sub folder contents but cant find it, googled this though:
Open notepad paste this in:
dir /a /b /-p /o:gen >C:\WINDOWS\Temp\file_list.txt
start notepad C:\WINDOWS\Temp\file_list.txt
save the notepad file as list.bat on your desktop or anywhere.
Copy the bat file to the directory you want to list the contents of, then double click it.
Folder size would be nice in a windows app.
In the hope to see where the money shots are in directory size.
Yep, I use .bat files to automate parts of the circus.
Folder size would be nice in a windows app.In the hope to see where the money shots are in directory size.
This any use?
[url= http://www.jam-software.com/treesize_free/ ]TreeSize[/url]
Open a dos prompt in that folder (shift and right click
Run regedit.
Go to hkey_classes_root\directory\shell\cmd
Delete the "extended" key in the other window.
Hey presto, you don't need to press Shift any more, the option's always there.
Treesize is most handy for showing what dirs are using all the HD space. If you are doing a lot with files/dirs then TotalCommander is excellent ( there is a learning curve, so you might swear at it before you swear by it).
Long winded version here. Download winrar, zip em all up. Open zip file and export to a variety of file types.
What a bloody faff.
Typical IT logic in thinking it would be good to have to use a command prompt in this day & age.
TreeSize worked a treat. Thanks guys.
Cleared up a stack of space... found an installation of CoD at 4 gig I forgot about in past.
Everything must go ๐
