I need your help to populate the 1st column of a spreadsheet.
I need a bigger gap between kiddie seats in the back of the rad/dad wagon.
What ISOFIX to ISOFIX measurements have you got, centre to centre?
Can you let me have the measurement as shown on the pic and the make/model of you car (plus year)?
We all like a good comparison right?
[url= https://www.flickr.com/photos/15149602@N00/35752589102/in/dateposted/ ]Photo of what I mean here:[/url]
Cheers!!!!
Centre to centre or outer edge to outer edge the diagram doesn't look very clear.
Edit: Audi A6 41cm outer edge to outer edge.
Isn't Isofix a standard? (And so governed by regulations around dimensions etc?)
S-Max is the answer. Provided I slightly misinterpret the question.
The distance between the two things designed for one seat is a standard but the distance between two sets will depend on the size of the rear bench.
Yep somouk - you got it.
I want/need to be able to sit someone between the kiddie seats.
You can certainly do that in a 63 plate S-Max. We have done. An adult too.
You can fit an adult between two isofix seats in an XC60 as well
16 Plate Passat estate 440mm. (centres)
