Hot work bead makin...
[Closed] Hot work bead making or Lampwork
2 Users
 ji
Any experts here (on the basis that STW knows everything)? My daughter (17) is interested in getting into lampworking - melting rods of glass in a blowtorch to make beads etc. She has asked for some starter equipment for Christmas, but I am a bit unsure what to get - eg would something like [url= http://www.warm-glass.co.uk/hot-head-torch-p-2718.html?cPath=177_61 ]this [/url] be a good starter kit, and what else should I be looking at?
Also how easy is the gas (Mapp) to get in the UK - I assume I can't just link this up to a standard propane/butane tank?
Thanks
Posted : 01/11/2015 3:39 pm
Not a clue about glasswork but some of my brazing gear comes via a beadmaking place.
http://www.tuffnellglass.com/contents/en-uk/d103.html
I use one of the 2nd hand oxygen concentrators (£235 ex-hire medical gear) in conjunction with a small 6kg propane cylinder for brazing bike frames. I've done many hours of brazing without any refills (using a regular gas welding torch).
I'm sure they'd be able to answer any questions regarding what is feasible with a propane torch vs MAPP vs oxy-propane (which you could also do with "hobby gas" refillable oxygen cylinders).
I use those small disposable MAPP cylinders for silver soldering cable guides etc. They are easy to get (B&Q, Screwfix etc) but might be quite pricy in the long run (my small plumbing style torch would probably use one in about 20 mins running).
Posted : 01/11/2015 5:09 pm
 ji
Thanks for the link Mick. They look pretty cheap for a hot head torch (which takes Mapp cylinders) although I note your comment about price... I' aiming at a budget of up to £100 max, so even second hand the oxygen kit looks too pricey.
I'm sort of surprised that there aren't more starter kits around - everything you need to get started sort of thing.
Posted : 01/11/2015 5:50 pm
