Help with maths que...
[Closed] Help with maths question please.
6 Users
I want to work out the area size of:
500 sq metres, in acres, as a fraction?
Posted : 11/03/2009 9:31 am
500 Square Meters = 0.12355269073358267 Acres
So if my brain is working just less than 1/8
Or are you wanting something more accurate than that?
Posted : 11/03/2009 9:34 am
[url] http://www.onlineconversion.com/area.htm [/url]
1 acre = 4046.8564224 square meter
500/4046 = 0.124 acres which is about an eigth (0.125)
Posted : 11/03/2009 9:35 am
from convertit.com
500 meter^2 = 0.123552690733583 acre
[unless you mean "500 metres square", which would be 250,000m2 or 61.77 acres]
Posted : 11/03/2009 9:36 am
You don't need maths you need a google lesson. Type
"500 square metres to acres"
into the google search engine without the quotes and it should recognise you want a conversion and pop the result up above the search hits.
Posted : 11/03/2009 9:41 am
about 1/8 sounds right, not 61 acres.
Thanks
Posted : 11/03/2009 9:42 am
