Help with a Word Ma...
[Closed] Help with a Word Macro
I'm trying to get a macro to run through a Word document and extract all the acronyms. I've found a reasonable macro that does this. The only problem is that it adds the abbreviation list to a table in the document being scanned. I want it put it in a new word document. I've tried editing the code, but I'm an absolute beginner at this stuff. Can anyone help:
Sub AcronymExtract()
Application.ScreenUpdating = False
Dim RngDoc As Range, oTbl As Table, i As Long, j As Long
Dim strAcr As String, strFnd As String, strDef As String
strAcr = ","
Set RngDoc = ActiveDocument.Range
With ActiveDocument
  Set oTbl = .Tables(1)
  RngDoc.Start = oTbl.Range.End
   For i = 2 To oTbl.Rows.Count
    With oTbl.Cell(i, 2).Range
      strFnd = Left(.Text, Len(.Text) - 2)
      strAcr = strAcr & strFnd & ","
    End With
  Next
  With RngDoc
    With .Find
      .ClearFormatting
      .Replacement.ClearFormatting
      .Format = False
      .Forward = True
      .Text = "\([A-Z][A-Za-z0-9]@\)"
      .MatchWildcards = True
      .Execute
    End With
    Do While .Find.Found
      .Start = .Start + 1
      .End = .End - 1
      strFnd = .Text
      If InStr(strAcr, "," & strFnd & ",") = 0 Then
        strDef = Trim(InputBox("New Term Found: " & strFnd & vbCr & _
          "Add to definitions?" & vbCr & _
          "If yes, type the definition."))
        If strDef <> vbNullString Then
          With oTbl.Rows
            .Add
            .Last.Cells(1).Range.Text = strDef
            .Last.Cells(2).Range.Text = strFnd
          End With
        End If
      End If
      .Collapse wdCollapseEnd
      .Find.Execute
    Loop
  End With
  For i = oTbl.Rows.Count To 2 Step -1
    End With
    With RngDoc
      With .Find
        .ClearFormatting
        .Format = False
        .Forward = True
        .Text = strFnd
        .MatchWholeWord = True
        .MatchWildcards = False
        .MatchCase = True
        .Execute
      End With
      j = 0
        j = j + 1
        .Find.Execute
      Loop
    End With
      If j = 0 Then
        oTbl.Rows(i).Delete
      Else
        oTbl.Cell(i, 3).Range.Text = j
      End If
  Next
End With
Set RngDoc = Nothing: Set oTbl = Nothing
Application.ScreenUpdating = True
End Sub
Posted : 21/09/2016 2:32 pm
What I can help you with is making that text vaguely readable. I've edited your post for you.
Posted : 21/09/2016 2:36 pm
I think the simplest method would be to let the macro create its table, then once complete, copy-paste that table into a new document, then go back and delete the one in the original.
In days gone by with older versions of office I would normally use the record macro button to do some of the steps I wanted. Once recorded, then I would look at the code it created and modify it to suit.
For example, It would be easy to record a new macro that records you doing the following:
selecting the created table and copying it to clipboard.
file -> new file
paste from clipboard into new file
return to original document
delete selected table
once saved, the code will be daily straightforward / understandable and could be merged onto the end of the code that creates the table in the first place.
Posted : 21/09/2016 2:44 pm
