Chat Forum
2
Posts
3
Users
0
Reactions
42
Views
Ok new place has some dubious mounting of radiators so I want to remove radiator, mount the hangers and then put the radiator back. Can I just shut of the radiator valves, remove rad and remount and re-presurise or am I going to have to drain down the whole system
Posted : 05/11/2009 3:26 pm
You should be able to isolate the rad closing the valve and lockshield.
Undo one end of the rad and drain into a baking tray. Let off the bleed screw to allow air in the top.
Remount the rad and reconnect. Top up the system and bleed as normal.
Posted : 05/11/2009 3:29 pm
Should be fine just shutting off the rad valves.
Posted : 05/11/2009 3:30 pm
