Heat pump thread
Heat pump thread
If you divide your previous years gas kWh usage by 2900 you come to the power of the ashp you need to heat your home.
Obviously this is a one calc fits all and assuming no other work is done to insulation level or rad sizes.
I am helping my friend build to passive House standards . It's a steel frame and sip panel build . It's not a case of make it airtight , leak down check , and it's now a passive House. Otherwise I could build one with a marble floor , copper sheet roof , single pane windows and single skin brick wall. Make it airtight with crazy foam and silicon and conjure up air loss figure to passive house standard and it would be like living in a tent.
It's a underground up total build solution. The level of detail required is pretty high and alot of thought goes into how a steel portal frame can be insulated, the slab , ufh , ashp , window spec ,roof design , log burner with external air supply , kitchen extraction etc .
Posted : 29/10/2023 6:42 pm
In a passivhaus? That seems like a stunningly bad idea.
Posted : 29/10/2023 11:22 pm
No , it isn't. You need to buy a specific model that doesn't draw air from inside the structure.
Otherwise, yes a log burner inside a sealed room using the air from in that room for combustion is really rather dangerous.the mvhr create pressure that affects the burn and could draw CO back into the building.
By buying an external vented model the fire draws cold air in from outside, increased efficiency as you are not using already heated air from inside, then the flue exits normally
So it's a closed system, apart from a few seconds when the next log is chucked on.
Posted : 30/10/2023 9:00 am
I think the point being a Passivhaus is unlikely to need that level of heat, and certainly not the 'uncontrolled' and intense heat of a log burner.
Posted : 30/10/2023 9:48 am
Still deciding what to do with our old (1890) 2 bed brick cottage.
Solid brick walls, loft well insulated, new double glazed windows and composite doors. Floors not insulated only about 6” of space under there (checked with remote camera)
Small solar and 5kw battery setup. No existing central heating (or oil or gas) currently running electric radiators using home automation to heat during the lowest Agile rates. TBH we like a cool but obviously not cold house. 5kw log burner in the living room for main comfort.
Do heat pumps stack up on old houses? after all there is only so much can be done to minimise heat loss. (External wall insulation is not an option due to the area and planning)
If the pipe work is done nice we have no issues with it all being exposed and visible as a feature (rather than rip up nice original oak flooring)
hmmmm….
Posted : 30/10/2023 1:33 pm
I think the point being a Passivhaus is unlikely to need that level of heat, and certainly not the ‘uncontrolled’ and intense heat of a log burner.
Exactly.
Posted : 30/10/2023 1:37 pm
Logburner....
That's definitely an issue.  The in-laws built a highly insulated/airtight MVHR house with a pellet burner boiler(1) but insisted on an open fire much to their architect's annoyance. I don't know how the input ventilation was solved for it (it's open to the room).  As you'd expect, the uncontrollable heat is a real issue - regularly end up sweating in a t-shirt in winter as David throws another log onto the fire.  Given whats known about the pollution of even the 'greenest' wood burners I dont think anyone should be considering them now.  A lifetime of open fires almost certainly a contributory fact in his lung cancer as well.
1) pellet burner looked a sensible tech at the time.  There was a local supplier and UK manufacture and cost was reasonable.  It's not not local, manufactured in Europe and relatively expensive.  Also needs a bulky storage hopper and much more maintenance. Air or ground source heat pump is the only sensible choice now.
Posted : 30/10/2023 1:43 pm
CHB and CHB reacted
That's why there is an 8 X 4 roof lantern that can be opened electrically. If it gets too hot.
The building is in woodland with overhead power so the log burner is back up in case of long term power cuts
Posted : 30/10/2023 4:18 pm
If you divide your previous years gas kWh usage by 2900 you come to the power of the ashp you need to heat your home.<br /><br />
Could you please explain that a bit more. Just applied it to mine and ended up with 5.5kw. Seems a bit low.
As an aside, ran the boiler at 35degC output for 6 hours on Saturday. Outside temp was around 10degC max. House struggled to hold temp with each room showing a slow decrease in temp over that time from a starting point comfortable 19 / 18degC.  I thought our house was reasonably well insulated. In fact there’s not much more we can do other than external cladding (which we can’t as in a conservation area.)  Bigger rads needed before we go down the ASHP route!
Posted : 30/10/2023 4:38 pm
That’s why there is an 8 X 4 roof lantern that can be opened electrically. If it gets too hot.
So overheat the house then send it to the sky. Genius.
Posted : 30/10/2023 8:15 pm
 ajc
If it’s a proper passive house they will use the log burner once. Total waste of money
roof lanterns and horizontal glazing are often a total disaster in a passive house unless they are well shaded externally.
Posted : 30/10/2023 10:01 pm
What I've mainly taken from this whole thread is the high temperatures some people are heating their homes to. 21 and 22C ? Are you running an old people'home ? Or is it a shrine to Bikram Yoga? Are you all walking around stark bollock naked and having to go outside to cool down and leave the doors open ?
Posted : 30/10/2023 10:26 pm
nuke, retrorick, nuke and 1 people reacted
What I’ve mainly taken from this whole thread is the high temperatures some people are heating their homes to. 21 and 22C ?
You don't know what everyone's actual rooms are like. My thermostat is at 17.5, the heating isn't running, but it's 22 or so in here with two adults and the TV on.
Similarly just because the stat is on 21 doesn't mean it's actually 21 everywhere.
Posted : 30/10/2023 10:30 pm
This might help https://protonsforbreakfast.wordpress.com/2022/04/05/what-size-heat-pump-do-i-need-a-rule-of-thumb/
Heat loss - I think @molgrips has mentioned it a few times, and you also raise it. As long as your heating system can at least match your rate of heat loss the house stays at its set temperature. Like you’ve seen, a steeper heat gradient from colder outside temperatures can make it hard to maintain. And I think a few folks, @molgrips included, have described that you need a chunk of energy to raise the house temperature from, for example, your overnight setback temperature.
It’s been said a few times in various ways but the solution to heat loss shouldn’t be to put more energy in, it should be to insulate and stop draughts.
Still looking at an ASHP here as even with higher running costs over our GCH it’s less carbon. Protons for breakfast, in another article, mentions typical household gas heating CO2 output being ~2,500kg/year or similar. Not good.
On lower boiler temperatures, what’s the arithmetic relationship between circulating temperature and efficiency? The difference in steam plume appearance from ours puny dribble of steam from running at 50 Celsius to some neighbours’ at temperatures unknown is noticeable.
Posted : 01/11/2023 7:46 am
heres a graph from heatgeek, showing return temperature vs efficiency in condensing gas boilers
flow temp efficiency graph
Posted : 01/11/2023 9:07 am
If you are considering a heat pump, it might be worth factoring in wether or not you have an EV. If you do, you can get some really cheap overnight power on an EV tariff, and then you could keep your house warmer overnight which would reduce consumption during the day, and should save you some cash, I think.
That's probably a function of how the boiler has modulated, rather than how much is condensing, I reckon. We see similar steam plumes at different flow temps, but our boiler can't modulate much.
Posted : 01/11/2023 10:31 am
julians
Is there a downside to running the boiler cooler if it keeps the house warm enough?
Posted : 01/11/2023 11:04 am
I'm no expert so take this with a pinch of salt,but no I dont think there is any downside if you have a combi boiler.
If you have a regular boiler with a hot water cylinder then the flow temp of the boiler needs to be sufficient to get the hot water up to your desired temperature and ensure that legionella bacteria cant grow - commonly talked about as being no cooler than 60c which means a flow temp of 67c
Posted : 01/11/2023 11:13 am
I’m no expert so take this with a pinch of salt,but no I dont think there is any downside if you have a combi boiler.
If you have a regular boiler with a hot water cylinder then the flow temp of the boiler needs to be sufficient to get the hot water up to your desired temperature and ensure that legionella bacteria cant grow – commonly talked about as being no cooler than 60c which means a flow temp of 67c
Which is why you should almost certainly fit the manufacturer's (because most boilers won't talk to anyone elses) weather compensating controls.  Good boilers will be able to give a high flow temperature only when needed for water and the work in efficient, condensing, mode at a lower flow temp for heating.
"Usually, there is no growth above 55°C, and a temperature of over 60°C has a bactericidal effect. Thus, the WHO recommends that water be heated and stored at 60°C "  However, water at the tap should be no higher than 50C due to the risk of scalding so theres a need to balance the two risks.   Ideally you'd have a temp limiter before every hot tap outlet (and I building regs requires them on the bath in new builds) but most homes don't have that.
Also why 67 - surely that depends on losses between boiler and tank.  If they're in different parts of the house might be significant but if close together minimal.
It strikes me that boiler controls could be smarter here - you only really need it to reach 60+ for disinfection so it would be enough for that to happen briefly once a week with a lower temperature the rest of the time
Posted : 01/11/2023 12:22 pm
Also why 67 – surely that depends on losses between boiler and tank
Id just read that generally speaking your boiler flow temp needs to be 7 deg higher than the target temp for your stored hot water otherwise it could take an age to reach the target temp/may never reach the target temp - I guess its just a rule of thumb as every system is different as you note. I was just playing it safe with my 'advice' above.
It strikes me that boiler controls could be smarter here – you only really need it to reach 60+ for disinfection so it would be enough for that to happen briefly once a week with a lower temperature the rest of the time
There are some hot water cylinder thermostats that will set the target temp of the water in the cylinder to 60deg once a week so you can have a lower temperature the rest of the time - no idea how good they are, but I came across them when researching how hot to have my water temp , also I think if you use manufacturer controls some can control the water in the cylinder more smartly than is commonly the case.
note I dont have my hot water cylinder set to 60deg, I set it to about 55deg and am comfortable that this is not a risky approach (in terms of legionella) - but it does seem contra to most advice on the internet
Posted : 01/11/2023 12:42 pm
Only two potential issues:
- Short cycling
- Not being able to heat the hot water enough
There are solutions for both those if you have a sophisticated enough boiler.
Re legionella, you don't actually need to keep the HW at 65 all the time, especially if you use the whole tank regularly. If you let it sit at say 40C for a long time you will have an issue. Some systems can run a decon cycle once a week, you could also simply fit a timer to your electric immersion and have it come on once a week just after a normal heat programme. There is once again a Heat Geek article about this.
That said, your flow temp might still need to be 70C or so to get the water up to even 50C in a sensible time frame before the boiler starts to short cycle, so you're never going to get there if your flow temp is 40C unless you have some sort of smartness.
Posted : 01/11/2023 12:48 pm
All the glazing is triple glazed , including the roof lantern , and all is fitted with electronic remote control internal blinds . Incl all the horizontal windows.
The log burner will probably be rarely used , and may well be a total waste of money but when your £300k down the road another couple of grand is neither here nor there really .
As previously stated, it's a back up in case of power cuts , there's no gas available. It's a 5kw model in a 250m2 building.
Posted : 01/11/2023 12:57 pm
I thought the point of a Passivehaus was that it didn't need any heating, hence the 'passive' part?
Posted : 01/11/2023 1:04 pm
 ajc
@molgrips that is a common misunderstanding of Passivhaus. A hang over in name from a different building concept. @singletrackmind, regarding your blinds to prevent overheating. They need to be external as internal blinds don’t do much as the heat has already made it through the glass. Beware of overheating risk. I am guessing no one has done a phpp model and stress tested the overheating risk.
Posted : 01/11/2023 1:16 pm
Based upon the rudimentary calc from singletrackmind, we would need 3.2kw heat pump for a 4 bed detached house. I'd guess we would need potentially slightly higher as most of the gas is used in 5-6 months of the year so not a nice flat graph of usage.
I still need to see how the low flow temp set is affected by proper cold weather and if the house can warm up from the low set back overnight temp. It usually drops to 16.5 (in hallway) on a cold night at the lowest outside temp.
Posted : 01/11/2023 1:24 pm
 ajc
@singletrackmind the passivhaus trust has a technical guidance on overheating risk and a Phpp plugin you can download from their website.
Posted : 01/11/2023 1:50 pm
I’d guess we would need potentially slightly higher as most of the gas is used in 5-6 months of the year so not a nice flat graph of usage.
This is why I asked for the underpinning, as I assumed such a simple rule of thumb accounts for that and wanted to check. I looked into the links provided and whilst there is some additional info, there are caveats (such as adjusting upwards if you live in the northern half of the UK, but YET... no real underpinning. I live in a 5 bed stone built semi, there is no way 5.5kw is enough to keep the house warm in the depths of winter.
Posted : 01/11/2023 1:58 pm
 mert
I have 9kW of GSHP that keeps my house comfortable from the end of February to mid November. That's a (very) well insulated 200sqm 4 bed detached, probably a similar foot print and volume of a typical 5 bed in the UK? I've got 3 *HUGE* double bedrooms in there, and the living room is almost the same floor space as my last house!).
Only issue is it still has the small radiators from the original "pure" electrical heating system. So I still need to buy bigger rads for a few of the rooms.
Over the winter it struggles (when the daily average drops below about -5) then the house will run at about 17-18 degrees. especially if it's empty all day.
Coldest temperature i've seen in the house was about 13 after we'd been away for a long weekend and the outside temp peaked at about -15 for those days...
TLDR, you probably need about twice the power given in the calc to ensure it works all year round.
Posted : 01/11/2023 2:14 pm
Try a higher set back temp. It's part and parcel of the low 3ff8xient approach.
Posted : 01/11/2023 3:32 pm
Has anyone any experience of the Samsung Gen 6 ashp’s?
Getting quotes through to retro fit our oil fired mid 00’s stone build, well insulated detached. They’re speccing a 12kwh Samsung gen 6. Yet to get to the detail on rads etc.
Posted : 17/11/2023 6:15 pm
Looking for advice on questions to ask and things to check for a possible ashp and solar install.
We've just moved to a 50s semi with solid brick walls, and doing a two storey side extension and single storey rear extension, effectively covering over half the existing wall area with modern building control level insulated construction. Roof insulation is currently good and easy to top up if needed.
The extension will have under floor heating. I've got a quote for a 12kw ashp with sunamp thermal battery and 5kw of solar. The calcs in the quote look good and as this is replacing existing gas boiler I can get the govt grant.
What sort of pitfalls do I need to check for? anything to discuss with installer?
Cheers!
Posted : 22/12/2023 10:57 am
An interesting post by Protons for Breakfast for the end of year
https://protonsforbreakfast.wordpress.com/2023/12/23/2024-reasons-to-be-cheerful/
Me, though I live in a fair-sized Victorian house I am still interested in an ASHP heater.
Is it optimal? Maybe not from a $$ perspective. But burning £300 of gas per month in the depths of winter does not seem a good thing to me.
We are insulating several outside walls over time. This has made a BIG difference to how warm the adjusted rooms feel.
Posted : 23/12/2023 10:21 pm
lesshaste and lesshaste reacted
I will definitely be giving Octopus a ring soon. Maybe after I have upgraded my rads.
Posted : 23/12/2023 11:09 pm
 CHB
Octopus will upgrade your rads as needed as part of the install. They are changing all but two of mine in Feb.
Posted : 24/12/2023 8:47 am
Do you mind me asking the cost?
Posted : 24/12/2023 9:00 am
Maybe I'm a bit dim, but is this the max power of the ashp, or the actual amount of electricity you will be using. The reason I ask is that we have a 16kW ashp, but the actual usage is nowhere near that - rarely more than 6. At some point I had Octopus come out and do a survey and they measured our house and sucked their teeth and declared we'd need a unit bigger than they supply.
Posted : 24/12/2023 10:52 am
 Bear
Octopus are picking the low hanging fruit, and their CEO stating with new high temp units you won’t need to upgrade rads is on dangerous ground. Octopus also sell electricity …….. Building regs now require  low temp heating systems as well, so a new system on a condensing boiler will need similar sized rads
Posted : 24/12/2023 11:02 am
I can upgrade my own rads cheaply enough. Our old ones were tiny, mostly 600x700 or smaller, with two in the big living room. I reckon I can double the nominal heat output by going slightly wider and double skin.
Posted : 24/12/2023 12:47 pm
 CHB
Molgrips: Our quote is crazy good, just under £2000 for a Daikin, 4 radiator upgrades (3 layer) and a 180l water tank inc installation and all electricals.
We got the quote when the subsidy was £5000 and then when it went to £7500 and Daikin had a £250 discount added it tumbled in cost. <br />Neighbour go a quote a couple of months ago and his is more like £4000, so I think we were lucky and got in before the rush.
Posted : 27/12/2023 11:47 am
 mst
@supersessions9-2 I've just installed similar whilst adding to and renovating  a 1965 cavity walled house. So far in the part of the house that is built to current building regs the heat pump works fine, not seen it pull more than 6kw. The second part of the renovation is to do the original house which will need interior wall insulation and careful attention to draught proofing.
We have underfloor downstairs only. The upstairs rads don't seem overly large to my eyes.
Our sunamp is not charged from the 10kw ASHP, just from electricity. I need to sort out being on a different tariff for the winter as in the summer the 6kw west facing solar takes care of the sunamp and the other water tank.
I'm not sure if the position of the ASHP makes a difference. Ours is on the north facing side of the house and never gets any real sunlight on it.
We had an engineer do a set of calculations to size the heat pump which gives me confidence that it's not undersized as long as I follow the renovation plan.
Posted : 28/12/2023 2:02 pm
Wow.
Posted : 28/12/2023 2:08 pm
Our condensing boiler is on its way out, the heat exchanger has gone apparently. 1910 semi w cavity wall insulation, double glazing and loft conversion in last 10 years, so thinking we might be ashp possibles
Anyone have any experience of this outfit ?
https://www.airahome.com/en-gb
Swedish apparently, with a mission to make ashp affordable
Posted : 28/12/2023 4:13 pm
 ajc
Always use a local company who will want to service and repair breakdowns in the future.
Posted : 28/12/2023 7:53 pm
Wasn't sure where else to post this but for the energy conscious minded, good deal on well reviewed budget thermal camera
https://www.hotukdeals.com/4275911
Posted : 07/01/2024 10:56 am
Tempting compared to £50 to hire an inferior Flir One for a week.
Posted : 07/01/2024 2:08 pm
Hi team!
So we are investigating ASHP and have had a survey, to replace our oil boiler (fairly new, 2 years old Worcester Bosch which is adding to the conundrum).  House is mid-00's build stone detached 4 bed, with a cavity then insulated breeze blocks.  Decent loft insulation and double glazed wooden windows.  No underfloor heating.
As part of the survey we're looking at a 12kwh Samsung HT Quiet, with the aim of running it at a flow temp of 45 ish.  Listed specs show COP of 4.2 @ 45 degrees.
We've calculated then the output of the rads, and modelled it against a 55 degree flow temp, the first chart, and then a 45 degree flow temp, the second chart.  Both with -2.2 degrees external temperature and assuming worst case insulation.
55 degree:
https://imgur.com/a/BlCB0pr
45 Degree:
Our rad types are in there, and they’re wondering if we could switch to K3’s in some rooms. What are the general thoughts?  It goes from being ok in the 55 degree to definitely not in the 45 in some key rooms.  We have a wood burner which we can use to boost things when it’s very cold (rural area, we lose power supply quite frequently).  Is it sufficiently borderline that it would be worth going ahead with the ASHP and seeing what the performance is like?  Or stick in a modern K2 radiator?  Part of the reason I’m asking is the K3’s are so deep (18cm) it would be a bit of a nightmare.  Having looked at BTU outputs I think we could achieve similar outputs with modern K2/Type 22 rads.  Or am I being overly optimistic?  I think it’s fair to say we’re willing on this topic but generally a bit nervous.  Minus any radiators, we’re looking at about £4k after the grant, including a new 300L hot water tank and some 28mm pipe run.  I’d really welcome any advice or insight!!
Posted : 18/01/2024 4:13 pm
We had single panel rads throughout, I've been fitting T21s that are 800mm wide instead of 600mm, it's about double the output. I didn't fancy T22, because of the size, and I think triple would be out for us.
We did fit a massive 1800mm T21 in the hallway instead of the original 600mm single panel which helps heat the core of the house. But then, the house is relatively well insulated so the rest of the rooms keep their warmth.
BUT we've done a lot of work reducing cold spots.  Ours was built in 2007 and the builders were slap-dash as you'd expect.  For example anywhere that the inner block wall was cut through - extractor fans, the French doors on the first floor - the cavity wasn't blocked off, so there's a great draught coming in via the soffits and the vent bricks.  Sealing these off where I can has made a big difference to keeping the heat in which means less heat from a smaller rad can still heat a room.
Posted : 18/01/2024 4:39 pm
Yeah -  a bit of me thinks we could just put it in and see, and see how the flow temp works in the room.  If we had to have a flow temp curve that went up to 50/55 degrees when its sub-zero outside, I don't think that would be the worst thing, given the frequency.  My thinking is we could then upgrade rads as necessary, once we see how it feels.  But this also seems a little contrary to advice.
Posted : 18/01/2024 4:41 pm
Those heat loss numbers look huge.  How did you arrive at those?
That adds up to 9.5kW or so.  Our boiler runs at a minimum of 9kW, and even in this weather it's running for no more than about 30% of the time - usually much less - which would put our heat loss at 3kW. It's a smaller house though - 3 bed semi.
Posted : 18/01/2024 4:49 pm
So the heat loss numbers were calculated by the company, they took worst case insulation values and higher design temperatures.  Do you think they've overdone it?  They're estimating our energy use annually on a heat pump as being around 5163 kwh
Posted : 18/01/2024 4:51 pm
Why would you replace this before it is dead or oil prices are so utterly silly it is not economic? Surely £4k plus grant and a hugely wasteful environmental cost outweigh any benefits?
Posted : 18/01/2024 4:52 pm
tillydog and tillydog reacted
Do you know how they calculated the heat loss and what internal temperature they have assumed? Ball park figure for your house would be around 75W/m2 at a guess. It is also worth noting that the output of a lot of R32 ASHPs drop off at lower temperatures so worth checking the performance charts. You need to factor in the hot water too.
A new wave of Propane (R290) heat pumps are coming out now which will go up to higher temperatures and have slightly better performance at these higher temperatures so worth checking them out although most of the ones I have seen are lower capacity at the moment so you may need two units.
We have an oil boiler and I don't think I'd rip out our system for an ASHP unless if completely failed, even with the grant money available. I certainly wouldn't rip out a 2 year old boiler.
Posted : 18/01/2024 5:04 pm
HI Matt, well firstly we'd look to sell the boiler so it wouldn't be wasteful. Secondly heating oil prices are rising quite heavily over the last few years, to the point where the cost would be neutral right now when we're paying circa 65p.  It's not uncommon to have to pay up to double that, and that's not going to get better over the coming years. In terms of environmental cost oil heating is far from brilliant!
There's also some secondary impacts, so we would be able to change the layout of the kitchen to significant benefit, which we're thinking of re-doing this year, the boiler location is fairly intrinsic.
You're right however, the kitchen component has got us thinking about it sooner than we might have, which is is making it a tricky decision!
Do you think they’ve overdone it?
Well I don't know, I mean I'm not a heat engineer. But I think there are ways to calculate it.  I know that our boiler is over-powered even on minimum setting, so I could figure it out from that if I had a means to measure exactly how long it was running for, or even a smart gas meter - but if you had a decent modulating boiler then I don't know how you'd know how much heat is going in.
I don’t think I’d rip out our system for an ASHP unless if completely failed
Our boiler is both old and crap, and it has gone wrong plenty of times. I've managed to fix it on many occasions, but I think there's a pinprick leak in the heat exchanger so I think it's only a matter of time.
Posted : 18/01/2024 5:06 pm
Thanks Mranger156 - as I say I think they've overcooked the calculation on heat loss to be pessimistic - I'd asked us to calculate it erring very much on the safe side.  re the Propane 290 yes, been looking at that.  As mentioned part of the reason we were considering it was the ability to free up the boiler space in the kitchen and future proof etc.
Posted : 18/01/2024 5:08 pm
HI Matt,
Posted : 18/01/2024 5:09 pm
Oh yeah, the boiler cupboard - we have a tiny kitchen, I'd love to get that back!
Posted : 18/01/2024 5:15 pm
Yeah @molgrips!!  🙂
Posted : 18/01/2024 5:16 pm
The heat loss figures are not too far off. What I’m looking at is the flow temperature of 45, and, they’ve put a delta T of 20 degrees.
Thats the radiator mean water temperature to air temperature DT, (mean water, ~40 degrees minus desired room temp, 20 degrees = 20 Mean Water to Air temperature differential / DT). That would give a HP flow/return DT of 10 degrees (MW-AT of 40, so flow is at 45, return at 35), which is a little high for my liking.
45 degrees flow is the max I’d even look at if fitting an ASHP, I’d design it for 35 degrees, with a return of 30 degrees, Delta T of 5. That will be far more efficient than running at 45 or higher. I read a figure of something like a 2% increase in electric use for each 1 degree rise in flow temperature, so 45 degrees flow would be 20% more than 35 degree flow.
Could you add another radiator into the rooms needing K2/K3 rads? I’ve got the same thing in my bathroom, the OH wants a towel rail, it wont give out enough heat, so I’ve got to fit another rad.
Also, be aware, the quoted BTU/KW outputs of radiators is at a MW-AT of 50, or 60 degrees (all makes differ slightly), yours will be ~20  MW-AT, so a rule of thumb (it can be calculated more accurately) is you need a rad 3 times bigger,e.g. if 100 kw is required, you need a radiator with an output of ~300kw at MW-AT of 20 degrees.
Posted : 18/01/2024 5:45 pm
 Bear
R290 heat pumps are around now and have been for a number of years, but just because they can do higher temps I wouldn't recommend it. Lower the flow the more efficient it will be.
Do the rads now and it will be zero rated for VAT.
heat loss calcs should be to MCS standard.
Posted : 18/01/2024 6:00 pm
I would like a decent rad in our bathroom but there's no space other than where the towel rail is.  I could replace the rail with a rad and just hang towels above it - but can you get some kind of rail/rad combo for central heating usage rather than electric?
I may try our house on 35C tomorrow and see what happens
Posted : 18/01/2024 6:01 pm
 ajc
The MCS heat loss calcs generally already have quite a bit of margin for error so no need for the installer to add an even bigger factor on top. That is how you end up massively over specified. You can get a door blower test done on your house and manually add that figure into the mcs calcs to make the heat loss more accurate
Posted : 18/01/2024 6:09 pm
@alanl that is super useful, thank you!! I’ll get them to model the 35 flow temp and delta of 5, and see what that shows in terms of rad volumes.
what external temperature would you use for the calculation?
grateful again for the brains on singletrackworld!
Posted : 18/01/2024 6:40 pm
Typical is -3 to 21 degrees in the middle of the Country, if you are in the Highlands, then -5 or -8 to 21, in the sub tropical South coast, you could probably get away with 0 to 21. It can be adjusted for the location and personal requirements, if you never have it above 20 degrees, then use that as your target room temp. If you only get 5 frosts a year, then put it at 1 or 2 degrees. This heat loss figure is used to size the heating system required, in a perfect world, you’d get exactly the right size heating source as your heat loss, but in the real world, if you get within 10%, thats good enough for most.
‘ajc' makes a good point, most heat loss surveys over estimate the heat required. They do not take account of people in the house (people give out 100 watts of heat), hot water use - the heat from the water exits into the house, cooking, when your oven/hob is on, that heat warms the house too, of course, any clear sunny days heat the house,and my favourite gripe with them, MVHR systems.
MVHR cannot be used to downsize the heat requirement, which is stupid, as that is what they are designed to do. The ‘ventilation’ heat loss is typical given as one change of air per hour, in many houses, the ventilation losses are bigger than the fabric losses (through the walls/windows/roof), adding a MVHR should drop the ventilation figures from 1 to 0.2, so a house that has a 2000w ventilation loss would only have a 400 watt loss with MVHR, yet the heating system has to be designed for the 2000w loss. Totally messed up.
Posted : 18/01/2024 9:40 pm
Thanks @alanl that’s very useful. We are rural North Yorkshire so somewhere in the middle probably. We are also a 19 degree house tops. 19.5 on very special occasions 🙂 you’re right about the bodies. It’s quite noticeable how warm it gets when we have people round  We do however do quite well with the sun. The length of the front of the house is south facing and it’s amazing how it heats the house. We have got solar panels going on next week!
Posted : 18/01/2024 9:44 pm
 Bear
You can take into account MVHR in heat loss calculations.
Providing you can justify why you have dine so then it is fine.
If you heat loss a passive house you have to do so accordingly. You adjust the losses through the fabric depending on how it is constructed, you can do the same for the air losses.
Posted : 19/01/2024 8:54 am
If we had a heat pump I'd have the gas turned off and get an induction hob. But that would result in much less heat from cooking!
Posted : 19/01/2024 9:11 am
So I've spotted some errors in the sheet, so I'm going to get those fixed.  I then realised my logic was a bit flawed, so I'm going to get them to model every P+ rad being upgraded to K2, then with the lower flow temp and delta t.
One question, probably fairly silly, how is delta t adjusted?  What determines it being 5 degrees, not 10 degrees?
Posted : 19/01/2024 7:30 pm
I would like a decent rad in our bathroom but there’s no space other than where the towel rail is. I could replace the rail with a rad and just hang towels above it – but can you get some kind of rail/rad combo for central heating usage rather than electric?
@molgrips yes, we have exactly that, a ladder rad with no electric connection. Works as long as you don't cover it completely in towels.
Posted : 19/01/2024 7:43 pm
Bear
I didnt know that, and I've asked the same question at numerous training centres, they’ve all told me you cannot downrate due to the MVHR. Thanks.
Posted : 19/01/2024 8:53 pm
 Bear
Alan, I’ll talk to my boss who is involved with MCS so he will know exactly. But when you think about it as I said you adjust them for passive houses, you adjust the losses through the fabric accordingly. Air losses are no different and often way to high for most buildings as people are getting rid of draughts
Posted : 19/01/2024 9:08 pm
 ajc
Including mvhr in retrofit heat losses through MCs came up yesterday at an aecb certifiers meeting I was at. From memory they were told by MCS that they could not include mvhr and were in discussions about changing the rules.
Posted : 20/01/2024 8:34 am
Does anybody in the South East have a recommendation for someone to design and supply (maybe also install and commission) a heat pump, hot water system, underfloor heating and MVHR? Ideally one company to do it all as a complete balanced and designed system, and somebody that will offer a reasonable level of post install support.
This is for a new build. Approx 300sqm.
I've had quotes from Omnie and Green Building Store, but see that Screwfix and a few other places sell the ASHP and hot water tanks as a package for what seems like a good price. Would rather source from someone who can offer some design and advice though.
Posted : 20/01/2024 8:53 am
My sister's new ASHP install was costing her a tenner a day this last week.
Posted : 20/01/2024 10:59 am
 Bear
Is that the heat pump or all her electrics? She should have a kW/hr meter installed to check the actual heat pump usage. We are spending £9 on all our energy per day at the moment. This is why SCOP is more important as when it is milder it will be cheaper than other fuels if it has been designed and installed well. But high COP are achievable even in cold weather.
There are too many generalisations on here, but also there are too many companies who aren't doing a proper job too.
Posted : 20/01/2024 11:25 am
All, I think. Of course it drops right down when it gets milder and is generally cheap to run. It seems to get disproportionately worse when it's particularly cold though as not only do you lose more heat from the house but the pump becomes much less efficient. Of course we need to consider the whole winter not just one cold snap.
Posted : 20/01/2024 11:52 am
ghylley and ghylley reacted
 ajc
@Peekay You could try cvc systems. I have used them for mvhr and they are also doing heat pump for a job I have on site at the moment. I don’t have a completed heat pump install from them to give a rating, generally a little cheaper than green building store.
Posted : 20/01/2024 12:23 pm
Does anyone actually have experience of a propane base ASHP? I really think this is what I need based on a low temperature ow test in the house a couple of weeks ago. I can't see a downside apart from having to site it away from the back door of the house (but not too far).
Posted : 20/01/2024 2:37 pm
 Bear
All the Vaillants are R290. Decent unit, good support.
Posted : 20/01/2024 7:33 pm
This is a great thread. Finally got around to asking our installer how to adjust the flow temp on our Daikin ASHP. Seems we were set to 55 degrees!! No wonder it was so expensive to run. Today I did an experiment and set it to 45 degrees - house is still nice and warm and is costing about 80p per hour while heating the house to around 19-20 degrees.
Think I can go further and try 35 degrees flow temperature tomorrow and see what temperature the house settles at.
Posted : 25/01/2024 6:58 pm
Page 2 / 3
