Heat pump thread
Heat pump thread
Do we already have one of these? Sorry if I've missed it.
I did one of these online quote forms and have got a quote from a vendor, minus installation, and it looks like he's given me options on the invoice rather than an actual quote - but not sure what they actually are. I've got things like this:
https://www.cityplumbing.co.uk/p/samsung-ehs-r32-monobloc-heat-pump-5-kw-ae050rxydegeu/p/467506#fo_c=2832&fo_k=86b9f668fb4e03fd35f1e04c8c11c375&fo_s=gplauk
But then also something that looks like this:
https://www.daikin.co.uk/en_gb/products/product.html/EHVH-UD6V.html
Not sure if I need both those things or are they just different choices? I assumed there was an indoor and an outdoor component to these things, is that what I am looking at?
Also he's added a HW cylinder to the list - I already have one of those, do I need a different one?
Posted : 24/10/2023 11:40 am
Ok so it looks like a normal HW cylinder doesn't have enough coil area to heat enough hot water - that's fair.
If there's a £7.5k grant available, then that looks like it would cover most of the cost of these items?
Posted : 24/10/2023 11:44 am
I was told that you realistically need 15mm pipework and preferably 22mm pipework to make it work efficiently, so If you don't have that you're looking at £4k-£9k for a replumb too.
You might also want to do the rads too, so another £3-4K
Posted : 24/10/2023 11:52 am
Yes I understood this but more recently have heard conflicting advice. We have microbore but online (and one quote) told me its possible to do it using 10mm piping.
Posted : 24/10/2023 11:55 am
Yeah I know all about that. Just asking about the cost of the pumps specifically.
Posted : 24/10/2023 11:56 am
Our air source heat pump has two units, one outdoor and one indoor. The Samsung looks like the outdoor and the Dakine the indoor. These systems operate at a lower temperature to a normal heating system, so probably need a different HW cyliner to allow for this.
A couple of things that never seem to be mentioned:
1). Because of the lower temperature heat pumps work best with underfloor heating, or radiators have to be up-sized to suit.
2). They work better with a well insulated building.
Posted : 24/10/2023 12:02 pm
 Bear
Any heating works better in a well insulated building, a heat pump should work in any building providing you can fit a large enough emitter. <br />Microbore may work but is unlikely and I would advise to remove it. <br />The only size heat pump we would consider using 22mm pipework is the small 3.5kW. 5&7 are usually 28, 10&12 in 35mm. <br />Design is critical, and I would chose the manufacturer carefully. The same goes for the installer. Check to see if they do maintenance as most seem to fit and run away. Also some that do service aren’t as thorough as they could be. <br />We are inundated with maintenance work as there are so few that do it and unfortunately the industry is riddled with poor installers.
Posted : 24/10/2023 12:26 pm
Got the iStore 270l - from memory it was around 3k  for the unit and fitting (That's Aus Dollery-doos) and was installed when we got our solar fitted. IIRC in total we paid under 10k (again, aus dollars).
It's outside (people have them indoors???) and we've had it all for a about 18 months. Seems to provide around 35-40kWh and the app shows it's solar is working from around 0430 until around 1630 but we're only in October, Dec/Jan/Feb will be 30c+
Posted : 24/10/2023 12:30 pm
The housing association my partner works for is retrofitting an entire estate. They seem to expect a big increase in electricity usage as the cabling and substations have been replace or added to.
I need to do something about our gas boiler but am sitting on my hands seeing what happens on this estate.
Worst case it will increase the energy bills of tenants of social housing.
i did a slight amount of research into this... old school house 1960s radiators etc
basically assumed that id need to upgrade the plumbing and rads
however, i also read that octopus are bringing a new heat pump to the market with the intention that it works seemlsessly with existing plumbing
Posted : 24/10/2023 12:49 pm
Is that quote based on any heat loss calculations specific to your property or is it the old school approach of just chucking 8n the largest unit you can?
You could get away with it on boilers with cheap gas but it makes heat pumps less efficient.
Posted : 24/10/2023 1:00 pm
 Bear
There are heat pumps around now that will work but they will be expensive to run. The key is getting the flow temp as low as possible.
Octopus are forgetting that the building regs have been re-written to account for low temp heating systems. They are marketing something that in my opinion will be detrimental to the heat pump industry. Remember they sell electricity too!
Has anyone seen any good online sites that go into the detail of heat pumps.  We have 20mm pipework at the moment and the water in the pipes isn't particularly hot so I think we are not in bad shape but I really want to understand a bit more before going looking for suppliers.
Posted : 24/10/2023 1:06 pm
The estimate was 4.6kW which is way more than enough to warm the house, based on my experience with a 9/12kW boiler. Perhaps not enough to do both HW and heating at the same time though. But there are 5 and 8kW units listed.
heatgeek.com
Posted : 24/10/2023 1:08 pm
leffeboy and leffeboy reacted
heatgeek.com
Brilliant, thanks
Posted : 24/10/2023 2:14 pm
When I see & hear this my standard retort is "every heating/cooling system works better in a well insulated building".
Posted : 24/10/2023 2:19 pm
Obviously, but the issue is that heat pumps can't put out as much heat as a gas boiler, and they also lose more efficiency when run at higher temps; this means that the financial penalty for poor insulation is much bigger than with gas.
Posted : 24/10/2023 2:30 pm
J-R, mikejd, mikejd and 1 people reacted
We got a quote for the Octopus system last year.  We have a mix of 8mm and 10mm microbore.  Octopus said this would have to be replumbed and best to do it with 28mm pipe.  The cost of the ASHP, 270l UV cylinder and a loft fill tank was £7900 AFTER the £5k grant.  The replumb was £7k with a mix of 15 and 28mm pipework.
So even with the grant at £7500 today, we'd still need £8k plus insulation, plus rads/UF heating, so minimum of £15k AND it would cost more to run.
Posted : 24/10/2023 3:32 pm
Dumb question - if we want to see how a heat pump would work with our house as is, could we just turn down the boilers CH temp to whatever a heat pump would generate and then see if the place stays warm enough?
Posted : 24/10/2023 3:47 pm
Dumb question – if we want to see how a heat pump would work with our house as is, could we just turn down the boilers CH temp to whatever a heat pump would generate and then see if the place stays warm enough?
yep - that is my understanding.
In the recent cold snap, our house couldnt hit the desired temperature (21c) with the boiler flow set to 60c, the temperature of the house just sat at 20.5 for 3 hours, until I increased the flow temp to 65c, then it hit 21c pretty quickly.
so I dont think our house is suitable for a heat pump without a lot of money being spent
Posted : 24/10/2023 3:48 pm
Heat pumps can produce 60C I think, at least some - but the efficiency (Coefficient of Performance or CoP) goes down. Given that right now electricity is about 4x the price of gas, you need a CoP of 4 or more.
Models will vary of course. There's a Samsung domestic one listed on some seller that shows the following for different flow temps:
@35°C 4.27
@40°C 3.98
@45°C 3.69
@50°C 3.40
@55°C 3.11
But it doesn't say what outside temps that refers to.
EDIT those numbers are SCOP or seasonal COP which seems to be an average over the whole heating season..?
I just set our boiler to 40C and asked it to raise the temps, it put 1.5C on in about 2hrs, from 17.5C to 19C. But it's 15C outside.
Posted : 24/10/2023 3:57 pm
yep – that is my understanding.
That's interesting. I had my flow temp on the boiler set to 50-55c last winter and it was ok, but then we prefer a cooler house heated to not more than 20c. Minimum loft insulation and no cavity wall insulation.
Assuming I topped up the loft insulation, would that suggest I could run a heat pump for our needs?
I wonder whether the answer lies in the table posted by molgrips, but I'm not quite sure how to read that.
Posted : 24/10/2023 4:02 pm
I wonder whether the answer lies in the table posted by molgrips, but I’m not quite sure how to read that.
Well your house needs a certain amount of power entering it to offset the power leaving it i.e. heat loss.
Your boiler might supply a certain amount of power, say it runs for 3hrs at say 60C on any given day in total at 6kW, then you've used 18kWh of gas which would cost you something like £1.35. Given that electricity is 27p/kWh you would still have to run it for 3hrs at 60C, but to still be paying £1.35 you'd have to have a COP of 3.6 - which that model above wouldn't manage. So at 60C you'd lose money with a heat pump.
But you can run it for longer at a lower power, say 6hrs at 40C, and output the same amount of heat BUT if the COP would be nearly 4 as per the table, you'd save money.
Posted : 24/10/2023 4:12 pm
dhague and dhague reacted
Thanks. So going by the data you posted for the Samsung domestic model:
@35°C 4.27
@40°C 3.98
@45°C 3.69
@50°C 3.40
@55°C 3.11
I'd need my house to be fine running at a boiler flow temp of 40c to be in with a shout of switching to a heat pump. If it isn't then loft insulation and radiator upgrades first?
Posted : 24/10/2023 4:27 pm
If it isn’t then loft insulation and radiator upgrades first?
loft insulation is worth doing regardless - if you have little to none already - its so cheap and easy to do, it'll reduce your heating costs regardless of the heating mechanism.
Posted : 24/10/2023 4:45 pm
Jolsa and Jolsa reacted
In my head, it would only be worth going to a heat pump if also going for solar panels and batteries to offset the increased electricity consumption hoping you can fill the batteries during the day and empty them during the hours of darkness primarily through the heating, but it is one hell of an outlay!
Posted : 24/10/2023 4:47 pm
I’d need my house to be fine running at a boiler flow temp of 40c to be in with a shout of switching to a heat pump. If it isn’t then loft insulation and radiator upgrades first?
As @molgrips mentioned earlier you really need to know at what external temperature those cop figures were taken. The lower the external temperature the lower the cop value, from memory they drop substantially once you get below zero. Heat pump running costs are at their most expensive when you need it most.
Posted : 24/10/2023 4:50 pm
Yeah, forget that idea unless you've a couple of acres of panels with battery storage to suit. Generation for me through November-January over the last 5 years has been less then 100kWh per month, the worst being 53kWh for December last year, barely 2 days worth of heating if temperatures drop below zero.
Posted : 24/10/2023 4:57 pm
Hmm.. well yes, I think so (I wrote a long post as I thought about it but came back to the same conclusion). The hotter the rads are the more heat enters your house. You may be able to run a heat pump for much longer at a lower and more efficient temp.
But it also depends on how you set your heating. If you want to run at 40C then it's likely to be a bad idea to turn it off all night because say you cool down to 13C overnight, you'll never get back up to 20C when running the boiler that low. But, if you let your house get down to say 18C over night instead, you might be able to run at 40C because it has less work to do. And, 20C after it's been on all night at 18C feels a lot warmer than 20C after it's been 13C overnight, so you could put your day temps to 18C (as I have) and let it drop to 16C overnight. Wether or not this works out cheaper is something you have to try out.
But regardless, definitely add as much loft insulation as you can fit, there is no scenario in which this is a bad thing. It's cheap and will pay for itself in a single winter.
Also rads are cheap, and can be upgraded really easily if you have plastic pipes. I've replaced our 600mm single panel with 700mm doubles - around twice the heat output, and there's enough slack in the plastic behind the walls so I just have to turn the valves off, drain the rad through the drain port, stick new mountings up and refill. And wipe up the inevitable black gunge spillage.
If you have dry lined walls, make a test hole with a screwdriver gently first, as the heating pipes coil up behind the wall and you can puncture them with the drill... not that I'd know of course...
Posted : 24/10/2023 4:59 pm
ASHP NIBE system.
Some real world numbers, house is currently 22c with an outside temperature of 7c. Supply temperate is currently 31c with return temp at 18c. Used about 4.5kwh of electricity last 24 hours. House has very high level of insulation, under floor downstairs and oversized radiators.
If you have gas you could try and set the supply temperate lower and see if you freeze or house stays warm. You’ll need to do this over at least 48 hours to get a reliable result. The key is to keep that supply temp as low as possible to avoid need for supplementary heat via the immersion as that gets costly very quickly.
Posted : 24/10/2023 5:01 pm
I'm hoping to break even, but I'm lining this up because our boiler will eventually fail and I don't want to buy another gas boiler. If we can get a heat pump we can heat our home with 50% renewables, we can run lower and slower which is definitely more comfortable, it's probably going to be quieter, and we can get an induction hob and have our gas disconnected which will save £20/mo on standing charge.
On top of that, we have an EV, which means we get really cheap electricity overnight, where we can heat our water for peanuts and we can keep the house warm overnight really cheaply. It would be worth running all night at 7.5p/kWh so that the heating has less to do in the daytime.
Oh yeah and running low and slow only works for heating - you can't get 60C hot water if your gas or heat pump flow is only 40C...
You must have big rads - and/or a slow pump, or an intelligent one. In my experiment it was 45/31.
Posted : 24/10/2023 5:03 pm
leffeboy, J-R, leffeboy and 1 people reacted
I want to get a heat pump but I have 22mm primaries and 10mm to rads. The last radiator on the run does get warm still with a low flow temp - setting 2 on the Worcester Bosch which is apparently around 43C . I'm not sure if the number displayed on the little lcd screen on the boiler is the flow temp and I couldn't find anything in the basic instructions suggesting what it is.   I'm not sure if this proves I could run a heat pump relatively ok in terms of efficiency or if I'd be paying through the nose for it. Ideally, I'd get switched over to a heatpump and cylinder and then worry about the pipe work later as I've had a lot of the ceilings etc re-boarded a couple of years ago and I don't want to rip it down as well as hack walls up to get new pipe work in as that was also all back to blockwork and re-boarded too. If only I had changed to at least 15mm when the new rads went in!
We've got oversized radiators  already in most rooms. 3 of the 4 bedroom rads ideally would be a little bigger as they are 600*800 K2s , those rooms don't suffer but then we've not had a really cold snap (sub zero) yet with the lower flow temp.
I've made the house as airtight as possible and I really put the effort in. Only rooms not gutted and completely back to block work is the kitchen which I will do whenever that needs to be changed (new kitchen was done in 2014 so not planning on that for a while). House dropped to 17c after 4 days of the cold weather around the weekend before last week's storm without any heating on, that was swiftly sorted as it was too cold. MVHR has been useful to a point but it won't make up for the poor 75mm insulation in the walls and 50mm under the ground floor which is also beam and block so cold air rushing through underneath.
Posted : 24/10/2023 7:20 pm
You can get a cheap thermometer with thermocouples from Amazon, that's what I got to test my temps with. Also handy for balancing rads.
Posted : 24/10/2023 8:20 pm
I've got solar panels with a battery. Just had an electric heat only boiler installed( uses same rads) with an air source water heater installed in the garage. My thinking is that the boiler will only run for half the year when needed, so offsetting the extra cost compared to gas. The water heater plugs into a normal electric socket and runs independently. Just had an induction hob installed and gas meter is getting removed next month saving on standing charge.
Posted : 24/10/2023 8:59 pm
Another Nibe owner here (new build but certainly not passivhaus). COP graphs suggest 2.8 at zero degrees outside and 45C flow temperature. COP of 2.0 at -10C and 1.5 at -20C. Our actual energy use over the last 2 years suggests those numbers aren't unrealistic (was down to -12C last winter). Never thought I'd say this but wouldn't go back to gas and a combi.
Bit sick of reading garbage like this:
https://www.bbc.co.uk/news/uk-england-67059247
Who would ever guess that a heat pump isn't viable for his house built in 1450 with leaded single glazed windows.....
Posted : 24/10/2023 9:47 pm
prettygreenparrot, BigJohn, BigJohn and 1 people reacted
You must have big rads – and/or a slow pump, or an intelligent one. In my experiment it was 45/31.
Combo of big rads but very high level of insulation.
Hot water set to start pump at 40c and 50c for stop. We are lucky to have good pressure with unvented hot at 3 bar so don’t need to run the hot water so high. Does a 65c legionella cycle every 14 days.
Posted : 24/10/2023 10:35 pm
LOL at letting the house get down to 18 overnight. That's what our thermostat is set to!
Posted : 24/10/2023 10:36 pm
Well my thermostat is set to 17.5 so ner ner ner.
Posted : 24/10/2023 10:58 pm
Another NIBE owner here - 2 year old new build Isle of Mull - thanks to the Gulf Stream we rarely see temperatures below zero. House is 110m sq, well insulated, airtight but not to Passivhaus standards, we have UFH downstairs on an insulated concrete slab with a couple of radiators upstairs (they rarely come on). There is no mains gas here. I managed to sneak in at the end of RHI and got £4200 back on the £10k it cost to install. System has been troublefree and doesn’t really need any maintenance only to check expansion tank twice a year.
To answer the original question, no, they are not the same. The Samsung is an air source heat pump, that unit is sited outside, and supplies the heated primary water to the HW cylinder and central heating.
The Daikin is a split unit. I’ve not got time to look it up at the moment (Daikin do a lot of different, similar looking units), but you have a similar unit as the Samsung outside, then the tall cabinet inside.The samsung has all the refrigerant in the outside unit, with just 2 water pipes heading into the house. The Daikin will have some thinner refrigerant lines going to the indoor unit. It is slightly more efficient doing it that way, but needs an extra qualification (F-Gas) and more expensive kit, to fit it, it’s basically an air con unit, but rather than pumping air around, the indoor unit transfers the energy into water. You cannot get the £7.5k grant for the air to air heaters, only the air to water heaters.
Split units are a lot more expensive (though rumour has it that Daikin are giving some large installers massive reductions), takes up more room, and I cannot see the need for it in a building that needs 5kW of heat. It does have one advantage, in that it can be used for cooling. It can probably only cool, not chill like an aircon unit. Another advantage is that the outside unit can be sited much further away from the building than the Samsung, which can probably be up to 10 metres away, off the top of my head, the split Daikin unit can be 30 or 40 metres away. It has an integrated tank/cylinder in the cabinet.
For the Samsung, you may need a new water cylinder/tank. It will most likely need to be pressurised (there are non-pressurised ones available, but why wouldnt you want pressurised hot water?), the size of it may need to be changed, and, most importantly, the coil inside the cylinder needs to have a minimum volume. Gas boiler cylinders do not, generally, have enough coil volume to allow the HP to heat the water in a short enough time. HP cylinders have a larger coil, and thus larger surface area to get the heat into the cold water to heat it.
Yes, I know a lot about HP’s!
Posted : 24/10/2023 11:47 pm
Just reading this thread - again with an eye that when our gas boiler dies it's new central heating system and heat pump.
Those being told it will work with microbore and existing systems - is it a case of it will work, but maybe not as efficiently?
Posted : 25/10/2023 8:39 am
Those being told it will work with microbore and existing systems – is it a case of it will work, but maybe not as efficiently?
Possibly. Depends on the size of the pipe, and the size of the radiators. Look at it this way, the pipes have to pass the energy through them. If they are big, more energy can pass through, small, then they are limited a bit.
It is explained on this page:  https://www.heatgeek.com/does-my-pipework-need-upgrading-for-a-heat-pump-with-cheat-sheet/
Note the table halfway down. The typical speed of water in the pipes is 0.9mps. 15mm pipe can handle 2.75kW of power. 10mm can only handle 1.15kW. There are ways to get it working, speeding up the water flow, raising the incoming temperature, increasing the spread between the flow and return temperatures (DT), and others, but they all reduce efficiency, so will cost more to heat the house.
If you have 10mm pipe from your boiler to the radiators, then I’d take a guess that you will need to increase the pipe size. If you have 15/22 pipe running round, then 10mm feeding the rads on short stubs from the 15/22mm then you may not need to increase the size. It needs an heat loss survey, then working out what piping you have to see if it can be reused.
An easy way to find out if a HP will work in your house is to turn your flow temperature on your boiler down as low as possible, 35 deg C is good, though some wont go that low. If the gas boiler copes at a 35 deg flow temperature, and your house stays warm, then a HP will be an almost direct swap.
Posted : 25/10/2023 9:14 am
As I suspected - and our house is almost entirely 8mm microbore from one manifold per floor...
I'm kicking myself that I've only managed to replace a few pipes with larger over the years - I should have done more, but budgets and all that... I have managed to upsize radiators as they needed changing. This means the boiler is rarely above halfway on the heat output.
Posted : 25/10/2023 9:45 am
@molegrips @flicker
Those Cop figures are the efficiency that the HP is at when it's flow temp is at 'x'
The HP will be connected to a weather compensation sensor, so if it is cold outside, the flow increases and mild it decreases. This trys to match the heat being lost from the building with a proportional heat input. You therefore cannot ask what the outside temp equates to which CoP.
A reasonable exercise for a gas boiler household is to run the flow at 35-40°c through the winter and see if the house can achieve your desired room stat temp. This exercise will off course raise the next problem with UK heating design.....
Posted : 25/10/2023 5:55 pm
Thanks @buttonmoon but unless I've misunderstood something it's not possible for the cop to remain the same regardless of external temperature. The lower the external temperature the lower the cop.
Lifted from Viessman website
With an outdoor temperature of 8.3 °C, your heat pump could achieve around 3.8 CoP. However, if the temperature drops to around -8.3 °C, your heat pump’s efficiency could drop to around 2.3 CoP. If the outdoor temperature drops too low for your heat pump to produce any heat, a backup may be required. This is unlikely to occur in the UK, however, heat pumps in countries such as Canada may need to rely on a backup. This can become expensive,so if you live in an extremely cold climate, a heat pump may not be the most efficient way to heat your home.
Posted : 25/10/2023 6:20 pm
What kind of negative temps are needed to cause an issue?
We're in a frost hollow and shaded by the hill and trees behind. It's not unusual to see -5 to -10 for a week at a time...
Posted : 25/10/2023 6:29 pm
A reasonable exercise for a gas boiler household is to run the flow at 35-40°c through the winter and see if the house can achieve your desired room stat temp. This exercise will off course raise the next problem with UK heating design…..
This, but remember to run you timer circuit on always on, otherwise it won't be representative.
Posted : 25/10/2023 6:44 pm
@flicker. There are 2 variables going on. The outside temp reduces which via the weather compensation increases the flow temp as the property will compensate for the property which will be losing more heat.
Those figures should be taken with a pinch of salt though as the main variable is the system design, which if wrong will blow those manufacture quoted figures out of the water due to short cycling of the HP.
What i'd say is that as electric is 3x the price of gas, you are breaking even if you average a CoP of 3. You need to be on a elect tariff that reduces your elect cost to make a saving.
Posted : 25/10/2023 7:48 pm
We’re in a frost hollow and shaded by the hill and trees behind. It’s not unusual to see -5 to -10 for a week at a time…
It all goes to the heat loss of the house. If the house has been assessed properly, each room will have its heat loss, and the house will have a total heat loss figure. Heat Loss surveys just dont happen in the majority of houses with gas boilers, as the same boilers are put in to each dwelling, anything from 20-35kW gas boilers are fitted, when the actual heat loss of the building is, or should be, less than 10kW.
The heat loss design should be explained to the householder, as a number of assumptions are made. The big one is the range of temperatures. Typically, a figure of -4 to 21 degrees will be used for Perthshire, but, if you are in a particularly cold Glen, then you may want to specify -7 to 21, or -7 to 19 deg. C.
If the house is designed for -3 to 21 deg. C, then once the outdoor temperature gets below -3, the heat source will not be able to get to 21 degrees. It’s worked out as the range, and the range is -3 to 21, so 24 degrees range, the heat source will only ever get the house to 13 degrees if the outside temp is -11,  (this doesnt really happen in real life, but in theory, it's what should happen).
If you specified -7 to 21, then you have a 28 degree range, so at -11, the house should get to 17deg. Note, for most houses, there will always be a time when the heat source cannot heat the house enough to reach the required temperature, as we all have the occasional -5 or -8 night. However, heat loss calcs nearly always over-estimate the heating requirement. Add in the warmth from mammals in the house (a typical human gives off 100 watts of heat), cooking, hot water, sun/solar gain, and you can see the heating source does not have to work so hard when the house is occupied, and the requirement for an extra heat source is very rare.
Gas boilers have always been over-sized, so never have this problem of not being able to reach the required room temperature on the coldest day.
Going back to temperatures too cold for HPs, I know Daikin units the best, they say their units will work up to -25 deg. C. It will be nowhere near as efficient at that temperature, but, it will still outperfom an electric element heater. Of course, the upside is the efficiency is brilliant once summer comes around,and you will see 5:1 or better. In the typical 10 degree UK climate, it will, or should, get a steady 3:1+ efficiency.
Interesting. With the flow at 40, the rads only get to 35. The boiler is cyxlinf6 between 45 and 35 so the water is approaching average temp (and then cooling a bit on the way to the rads).
Posted : 25/10/2023 7:55 pm
Ours works down to -20C with a COP of 1.6 at that point.
The outdoor temperature control of flow temperature works really well once you settle on the right calibration curve. It senses the increased demand as soon as it happens, rather than waiting for the internal temperature to drop (which lags due to the thermal mass). So it doesn't matter that heat pumps can't react to big demands for heat, because if specced and used properly they don't need to.
We are 15mm on all the radiator drops, and mix of 15 and 22 on the runs. The only 28mm is flow and return between HP and under stairs cupboard where cylinder, buffer, expansion vessels, pump, filter and controller etc are all crammed in. Pipe cross sectional area goes up with the square of radius, so a small size increase allows a lot more flow.
Posted : 25/10/2023 8:10 pm
 Bear
It is not just temperature outside but also the humidity. Heat pumps work well in minus conditions in the scandanavian countries but there air is much drier.
Posted : 25/10/2023 9:24 pm
 rsl1
I'm soon moving into a new build. It's abnormally well insulated - not far off passivhaus. It has underfloor heating. It doesn't yet have a heat source. It would be perfect for a heat pump but for... reasons... I don't qualify for the grant so I'm getting a gas boiler. I've been trying to future proof for a heat pump but it's a total minefield of information out there and the accredited installers want nothing to do with me without a grant. The irony is I think I could install a gas system to get an EPC signed off and then immediately rip it all out to get a grant funded pump straight away. The raise in the grant makes it hurt even more!
Can anyone tell me exactly what ends up inside you house and how much space it takes up?
Posted : 25/10/2023 10:44 pm
I think there are two grants. Everyone is eligible for the £7k no?
Posted : 25/10/2023 11:38 pm
 Bear
No the BUS grant has criteria that must be met. We have someone who spends hours dealing with the applications. It is a real pain.
not sure why a company will only deal with clients who get the grant, I think I would avoid them. Seems they want the grant money as it is guaranteed to some extent. We do lots of installs where there is no BUS.
Posted : 26/10/2023 6:13 am
 rsl1
Well what I mean is they're not interested in telling me how to future proof to make their life easier once I can use the grant, which is fair
Posted : 26/10/2023 9:04 am
I should change that - I think the £7k is for everyone who has suitable loft insulation and a gas boiler right now? But the full install grant is for people on low incomes who haven't had any central heating before...?
Posted : 26/10/2023 9:14 am
 core
"I’m soon moving into a new build. It’s abnormally well insulated – not far off passivhaus"
That's not abnormal, at all, if it's been built to current Part L (came into force June '22) then most new houses are close to passivhaus standard.
Passivhaus standard is just an excel spreadsheet, by the way. It'll be forgotten here in the next few years as English (and soon after Welsh) Building Regulations will be at or above that level, as standard.
In my experience (20 years in Building/Building Control), air source heat pumps are only efficient and cost effective in highly insulated, air tight (and then you need a proper ventilation system) houses with underfloor heating. Everyone else reports huge running costs, even before electricity prices shot up.
But, it all depends on the competence of your installer, good ones will keep coming back (or monitor your system remotely) to balance it, monitor your usage/behaviour and help you program the system to be as efficient as possible. Don't expect any rapid rises in temperature, it all needs to be done very gradually. To get the most out of ASHP you need weather compensation too.
One last word - if you've an open plan ground floor, don't bother installing underfloor heating at first floor (well I wouldn't regardless of ground floor), it's so much hassle and additional cost for something most people never use. Warm air rises...
Posted : 26/10/2023 9:23 am
 5lab
is there a technical reason it wouldn't be possible to engineer a solution that "doubles up" a heatpump - that is to say, get loads and loads of warmish water out of a normal heatpump (which isn't going to work for microbore), then use another heatpump (obviously not a standard one) to generate less really hot water from the warm water that can be sent around an existing central heating system? Might be too expensive to be feasible (no idea)?
Posted : 26/10/2023 9:30 am
This is key, from my very limited knowledge.
Three neighbours have had pumps fitted in the past couple of years, and I'm considering one myself as the house is well suited.
A knowledgeable/ enthusiastic installer coming back several times over the first few months is key to getting it working well.  It's not fit and forget.  Tweaking setup seems to be essential.
Posted : 26/10/2023 9:39 am
is there a technical reason it wouldn’t be possible to engineer a solution that “doubles up” a heatpump – that is to say, get loads and loads of warmish water out of a normal heatpump (which isn’t going to work for microbore), then use another heatpump (obviously not a standard one) to generate less really hot water from the warm water that can be sent around an existing central heating system? Might be too expensive to be feasible (no idea)?
I'm not sure there would be any difference between that and simply using a heat pump that can supply water at the desired temperature anyway. Except for the extra general efficiency losses like more fans, electronics etc. You can get hot water out of a heat pump; you just can't necessarily get as hot water as from a gas boiler for less money at UK prices.
Our house is well insulated generally - I guess I could have a stab at working out the heat loss - but it has no fancy features, just bog standard 2007 level stuff with our own tweaks. But now I'm thinking wet UFH downstairs would be a major benefit. I'd consider installing this myself but the main issue is with the extra height of the floor in the kitchen. I guess I could refit my kitchen - I could keep the granite worktops and just move them up a bit, and refit cupboards.
Posted : 26/10/2023 9:45 am
 ajc
A passive house is not just a well insulated house with an mvhr unit and the new building regs are no where near Passive House standard (assuming new builds actually have the quality control to not have a large performance gap from design to as built). There seems to be a total lack of understanding of what the Passive House standard is by both developers and some in building control and the ‘almost a passive house’ phrase is used far too often where it really dosnt apply.
in terms of fitting heat pumps. Proper heat loss calcs and a system design by someone that knows what they are doing is essential. There is a lot of false information out there.
Posted : 26/10/2023 11:11 am
As a slight aside amongst all this (very interesting) tech speak but does anyone have a recommendation for an installer in the north west (Wirral) and/or can recommend an online portal to start building quotes?
With microbore (in a well insulated house) there will be work to be done but we have to replace our old boiler soon..
Posted : 26/10/2023 11:35 am
 ajc
If you do t get a personal recommendation try finding someone who has done the heat geek training. There is a list on their website. Local is very useful as they are far more likely to fix your broken pump on Christmas Eve than some random company from miles away.
Posted : 26/10/2023 11:40 am
 CHB
We signed up over the summer for a Daikin heatpump from Octopus.
Incredibly good deal. 8kW Daikin, 180l cylinder and most of the radiators replaced with upgrades for £1900 (the £7500 new grant picks up the rest). Install is planned for mid february.
Posted : 26/10/2023 12:15 pm
I'll take one of those too please thanks.
Octopus wouldn't entertain my query though, guessing they have no-one in my area.
Posted : 26/10/2023 12:32 pm
“I’m soon moving into a new build. It’s abnormally well insulated – not far off passivhaus”
That’s not abnormal, at all, if it’s been built to current Part L (came into force June ’22) then most new houses are close to passivhaus standard.
That's complete nonsense for the mass house builders.  UK building reg insulation requirements, which is all any of the mass house builders build to (and all most other builders and even architects will do unless you insist on more) are still way less than PH.  Sister has just moved to a brand new Redrow home and
- double glazing
- extractor fans in each bathroom (and cupboard to washing machine) plus trickle vents on windows make very *VERY* dubious about the claimed airtightness.  Theres little point in airtighting the walls and then punching some holes through for fans - they don't even have flaps that close when they're not in use.
Posted : 26/10/2023 12:54 pm
My house has draughts that come in through brick vents into the cavities and then into the poorly sealed interior and then the space between the dry lining and the inner walls. This is because as above, every time they put a hole in the wall e.g. for windows, pipes, extractor fans they didn't seal it. I was able to seal some of the French windows which helped a lot. I don't know if I need to check under the rest of the window sills as well.
Posted : 26/10/2023 1:55 pm
If there's any installer recommendations in the Scottish Borders, I'm all ears please
Posted : 26/10/2023 2:02 pm
My house has draughts that come in through brick vents into the cavities and then into the poorly sealed interior and then the space between the dry lining and the inner walls. This is because as above, every time they put a hole in the wall e.g. for windows, pipes, extractor fans they didn’t seal it. I was able to seal some of the French windows which helped a lot. I don’t know if I need to check under the rest of the window sills as well.
If your reveals were anything like mine, then yes do it if you can. They may not cause huge draughts, but they all add up and sorting them out will certainly reduce the cold "feel" when you get little draughts here and there.
Posted : 26/10/2023 3:03 pm
Hello, total plumbing doofus here. Is there an easy way to tell what kind of pipes I have in my house? Is it as easy as getting a caliper on the radiator pipes or do I need to start finding the actual plumbing?
FWIW, I recently had a long chat with a pal who is a building physicsist specialising in heat. His rule-of-thumb advice was:
 - the biggest impact you can have on CO2 emissions is go from gas boiler -> heat pump, almost regardless of the state of your house.
 - The biggest impact you'll have on comfort is better insulation and airtightness.
He sensibly wouldn't comment on the economics of it because the costs of all of that ^^^ depends on a whole bunch of stuff.
Posted : 26/10/2023 4:51 pm
If there’s any installer recommendations in the Scottish Borders, I’m all ears please
I’m in Ecclefechan. I generally don't do new installs, so have never bothered with the MCS accreditation, and the majority of people only want one when they can get the Grant, for which the Installer has to be MCS accredited [1]. I do a lot of follow ups after the original Installer has made a mess of their grant funded install. I’ve been to 2 this week installed by Greener Energy Scotland, both were a farce, and no way did they meet the MCS criteria, and, of course, they never answer phone calls, never mind organising a visit to correct their faults.
If you want a chat about it,PM me and I’ll give you my phone number.
[1] I can get the grant through Heat Geek, with their umbrella scheme, however, they charge me around £2000 for each HP installed, as well as supplying all of the kit at a not very discount price. I disagree with that, and, could, in many cases, beat their price by buying independently, but, the grant went up to £7.5k from £5k, and now there is no way I can do it competitively, so, the customer almost always goes for the grant funded install by a larger company, rather than a small one or two man business.
Posted : 26/10/2023 8:41 pm
 Bear
Passiv House is way more than a spreadsheet, clearly never seen one put together, or if you have it wasn’t done properly
Posted : 26/10/2023 9:58 pm
Are those sorts of figures with a ground source heat pump?  I followed our water temp during winter last year and it rarely got up to 40 and our pipework is 20mm so I suspect we are in not bad shape but we run our house cold really - a bit warmer would be nicer.  Trying to work out if we really need to take the hit on going ground source but we could do it if we really need to
Posted : 26/10/2023 10:26 pm
Yes, but that may come at a high cost.  If you consume the same amount of energy to heat via a heat pump, you will emit about half or a third the CO2 than if you use a gas boiler. But you will pay four times as much.  Now, you won't use the same amount, you might use a third the energy, which means you'll emit way less CO2 - but you would still end up paying more.
Posted : 26/10/2023 11:03 pm
The window frames get cold in the winter - I assumed it was the frame itself.  How can you insulate inside the cavity walls without removing the windows?  Drill into the walls?
Posted : 26/10/2023 11:06 pm
Builder not fit cavity closers where they should have ?
Posted : 26/10/2023 11:09 pm
I don't know. I'm going to have to pull it apart and have a look!
Posted : 26/10/2023 11:24 pm
To do it properly, we moved the windows right to the edge of the outer brick. Plasterboard and window board then removed. Poorly fitted cavity closers removed as they were pointless with big gaps or in some cases weren't there anyway. This allowed air from the cavity to get straight behind the rest of the plasterboard. I topped up the cavity insulation right the reveal edge (less a bit so the new closers weren't crushing the new insulation but still touching). Then we used ct1 or sticks like **** and expanding foam on the new closers. Clout nails also used into the block to hold the closers as well. I then taped the nail heads with airtight tape. New triple glazed windows or existing were then put back in the right place so they came inward over the closers by as far as we could whilst the outer brick still taking most of the weight of the windows.
Posted : 27/10/2023 1:03 am
@molgrips
The window frames get cold in the winter – I assumed it was the frame itself.
What are your windows made of and what sort of glazing? I've got fibreglass framed 3G windows (Passive house certified. It's not that cold out today so the inner pane of the window is only about 0.5C less than the internal walls in the room, but the frame around the glass is still a degree cooler.
Frames (and the junction with the building) are the weak point
Posted : 29/10/2023 4:33 pm
Page 1 / 3
