HDMI/HDCP passive s...
[Closed] HDMI/HDCP passive switch to 2 devices ??
5 Users
does that exist ?
All I really want is to avoid repeatedly unplugging HDCP output lead from one input socket into another, and repeat. I only want one to be active at any time.
There seem to be loads of switches for, say, 2 devices into 1 tv socket but I want the reverse (and it doesn't seem to work just connecting "backwards")
Anyone know what I need ?
Posted : 02/03/2015 4:32 pm
I just use an hdmi splitter to take the single output signal from my receiver to both a TV and projector. It's passive and works flawlessly. The devices signal back to call the signal.
Posted : 02/03/2015 4:58 pm
Will have a better look around then - thanks
Posted : 02/03/2015 5:28 pm
I had a manual switch but found it caused confusion with the TV when switching. The handshaking process would go wrong and it would drop into a low resolution or deny it completely.
I have an AV amp now with HDMI switching built in and it acts as a bit of a hub and uses the CEC feature of HDMI so devices can control each other. Really like that if I switch off the TV it switches off the amp and can switch off the connected device also.
Posted : 02/03/2015 5:34 pm
Got one that 99% of the time it will automatically switch between devices, on the odd time it doesn't for example getting confused with 2 or more devices switched on at once it has a switch to go around all the inputs. It's a Duronic HDS3 Mini 3 Port Gold HDMI Auto Switch PIANO BLACK 3x1 (3 way input 1 output HDMI Switcher) for £7.99 from Amazon.
Posted : 02/03/2015 6:18 pm
