Have I just seen th...
[Closed] Have I just seen the ISS?
A constant white light that moved towards the east and then disappeared.
About 9.50 over Surrey.
Posted : 16/04/2014 9:59 pm
It was due over at about 9.48 so I would guess 'yes'
Cloudy here sadly.
Posted : 16/04/2014 10:01 pm
Yes, i just looked, tracking it on line. It was VERY bright tonight, about 75 degrees above the southern horizon and moving pretty much from due west to south east
Posted : 16/04/2014 10:04 pm
maxtorque - have you got a link to the tracking website?
Posted : 16/04/2014 10:05 pm
http://www.heavens-above.com
saw it earlier
got another pass that goes almost perfectly overhead, here, in 2 days time.
Posted : 16/04/2014 10:09 pm
From 2 nights ago
Posted : 16/04/2014 10:10 pm
have a look for iridium flares too (they're on the heavens-above site - but you need to put in an accurate location)
way brighter sometimes, but only last a few seconds
Posted : 16/04/2014 10:17 pm
I saw it when I lived down in New Zealand. One of the shuttles was attached at the time, and it made it even bigger and brighter than usual. Maybe I was kidding myself, but with the binos I could make out the two shapes clearly.
Posted : 16/04/2014 10:30 pm
What time can we see it next, will it be in the same place?
Posted : 16/04/2014 10:44 pm
in surrey?
17th: 21:02 - 21:08 going from West to East (looks like that'll be a good one)
18th: 21:50 W to E, but not so high up
19th: 21:02 same
http://www.heavens-above.com < stick your location in there, and it will tell you. click on a list entry, and it gives a sky map, so you can see which constellations it passes through (although the best ISS visibility is when it is not properly dark, so may only be a few brightest stars, plus Jupiter etc. visible)
Posted : 16/04/2014 11:10 pm
It has an irregular orbit so it covers the whole earth surface. So sometimes you can see it every day for a week, other times it'll be out of sight for a month.
Have a look at the tracking websites, there's also an Android app called Satellite AR that's worth a look - tells you all the satellites that you can see from your location at any given time.
In the UK, ISS usually goes from West or South West to East or North East. Usually a very bright, fast moving light.
Posted : 16/04/2014 11:15 pm
