From personal experience I'd plant them in a pot now and keep them in direct sun/warmth. May or may not be right, but it worked for me.
just take them out stick them into a bigger pot i tend to go for approx 10inch diameter per plant let them grow to about a foot tall then I snap the top off it seems to make the bush out more.
I would just like to say i am no pro thats just what i found works
just make sure you water and feed them on a regular basis. I found cold nights tend to muck things up so tend to keep then indoors for most of there life until the flower then chuck them outside and let the bees do what they do, that or tap each flower to help pollinate (sp)
As coffeeking, I've had them potted at about that stage in the past. It worked for me too.
Definitely take them out now and into some good potting on compost. Keep them in a warm and sunny spot (but not too much direct light).
When were they planted? They look a little small for May so you will need to feed well and kept in plenty of light to encourage growth and flowering.
Don't forget you will need to ensure they are pollinated so on nice wind-free days get them outside for the bugs to do their stuff. Or get ticking with a small artist brush.
I didn't manage to plant any this year (first time in several years) mainly due to last year's crop being useless so I got disheartened.
EDIT - Mrlard covered most of what I said too 🙂
I tend to use between 6"-8" pots, mine are a bit bigger than your plants and i'll be moving them on over the weekend.
Which magazine rated New Horizon Multi-purpose Peat Free Compost the best peat-free one, Miracle Gro advanced (i think that's the name) did well too. Westland West+ multipurpose is supposed to be good as well - I have found plants yield more with better composts.
They could probably move now, usual wisdom is to plant them on when the first/second set of true leaves are out. You can plant them quite deep - up to the base of the leaves - and they will root OK from the stem.
I normally move them into 3 inch pots, then into 8 or 10 inch.
Loads of useful info on here [url= http://www.chillisgalore.co.uk/phpBB3/index.php ]chillisgalore forum[/url]
Cheers.
Cool.
Thank you folks.
Plants are kept inside over night only going out during the day to bath in the sun.
Will go and get some larger pots at the weekend.
For those that have successfully gotten crops in the passed what have you used as potting material?
At present they are just in compost. Is this good enough longterm?
And put some gravel at the bottom of the pots before filling with compost - chilies dislike being too wet and need good drainage.
Don't over-water as this encourages those horrible compost bugs (whatever they are called). Chilies like to be watered quite lightly - the compost shouldn't ever dry out entirely but it SHOULDN'T get too wet.
Very good advice - apparently they like to be planted like that and are quite unique in this.
Really? I grew a single one last year, in my living room. I got chillies (not many I may add) - can't imagine it got many bugs from other plants in the area?
As MF says Chilies like light watering.
Avoid peat based compost too....
Doing a bit of a trial this year, planting my Chili seeds in a number of different composts to see which is best.
The Chili plants that are doing the best so far are all in peat free, cheap multi-purpose compost.
CK - yeah you do need to ensure they get pollinated to get best results.
Whereas some of my plants from the year before were in crappy asda compost and produced hardly any yield...
Cheers, I'll plant some more then!
Not a lot you can really do wrong with chillis.
- The bigger the pot the bigger the plant will grow.
- Don't let them get dry as the leaves will shrivel & die (a healthy plant won't have dried out crispy bits at the end of the leaves).
- Sure fire way to kill them is exposure to cold (keep them somewhere warm & well lit over the winter and they carry on fruiting).
- black/white/green flies all love to munch on your plants. If infected a regimented spraying with a soap solution will clear it eventually.
- If you keep getting flowers but no fruit then just rub each flower in turn transfering pollen around (earbud, paintbrush, finger etc)
- If the plant looks like its struggling (infested/lack of water/been to cold) removing all fruit & flowers will encourage growth
one thing to remember, as I discovered when my chilli plant died, they die every year , I think that makes them annuals? [url= http://en.wikipedia.org/wiki/Annual_plant ]annuals wikipedia link[/url]
edit after reading my link I have found that they are tender perennials, grown as annuals..
and if you keep them indoors while they are flowering, you can help pollinate them by using a cotton wool bud, going from flower to flower like a bee would.
I've given up keeping them from one year to the next, hardly worth the effort
Mine are coming on well. Transfer them from the propagator to 3" pots now until they become approximately 30cm tall and then tease out the growing tips. Mine are being tansferred to 10" pots this week and then introducing them outside during the day and back inside at night for a week until acclimatised.
Yeah I managed to get my one last year to last over winter, but it died this year when I left it without water for 3 weeks. Oops.
Anyone keep seeds from one season to use for the next?
I have done this in the past with differing results. The best results I ever had was with a bought (given as a present) plant from Homebase - the next season I used seeds from one fruit and got a great crop. The following season the seeds from the second plant didn't produce anything of note.
I tried this year, planted my collected seeds in blocks of nine, with the collected seeds I only get 2-3 plants from each block.
Compared with newly bought seeds, I get the odd single seed fail, if that.
Been told not to bother by other allotment holders & to always use fresh new seeds, but thought I would give it a go.
BTW, got a raised bed from last year that must have 2000 small self seeded tomatoe plants from last year!
Not used the Asda compost, so cannot comment, but I am trying out six different typs/makes of compost this year, to see what difference they make, too early yet to come up with outright winner mind.
Has anyone used Osmocote slow release pellets with Tomatoes/Peppers/Chilis, how did you find if so?
ooh what do you feed them? Small children? Cats?
I normally just use Tomatorite - I assume as they are eaten you need to use fruit-specific feed. I have no idea whether Osmocote is or not though.
blimey fruit specific feed need to get down my LGS!
I assume this is only because you are ingesting it so [b]if [/b]you do feed, it needs to be edible.
My brother only ever uses old teabags.
Don't feed the plants until the fruits are set or you'll get lots of leaves and hardly any fruit.
Best results I've had were using a mixture of sharp sand, vermiculite and peat free compost in equal amounts (by volume)
I found the best way to water was to stand the pot in a tray of water for an hour or so and keep the leaves moist with a trigger spray but don't spray in strong sunlight as the droplets act as little lenses and burn the leaves.
Tomatorite is my feed of choice as well, works well. As above, don't over water and get 'em in a nice warm spot of the garden. I tend to train mine up a bamboo pole or arch, depending on size, as I've found that a taller plant tends to grow more and larger fruit.
That's a good point HD, should have mentioned that in my post 😉
Re feeding, I like an early feed on potting out to kick start some growth of the bush, then let 'em starve until the fruits are out and start feeding again.
Wishing I had planted some seeds this year now. Especially as I recently saw a fantastic hardwood cold frame for next to cheap in TK Maxx too - it would have been perfect for my needs.
You still can - will only take a few weeks to come up now.
Every time I have planted seeds late (ie after March), I haven't had a crop - I think it is our exposed location and the amount of sun we get at our house later in the season.
I guess no harm in trying though as I have packets and bowls full of seeds...
Blimey they are doing well but YES - get them moved.
You should be able to carefully tease the roots apart with your fingers.
managed to keep one of last years going and now producing the first chilies of the year. The plant looks a bit scraggy though.
my Mrs pissed herself laughing at the rufty tufty mtb crowd going all gardeners world.
Who are you calling rufty tufty?
well she meant me and had to assume about the rest of you as she doesn't know you lot or anything about you..
toys19 - Member
That's what she told you at least.... 😉
CFH I won't have anyone casting aspersions about my wife.
Them pots look a bit small for plants of that size (and still growing). Do you plan on moving them on?
And they might do better spread out a bit, the ones in the middle may be scrowded and weak.
well done chunkypaul i reckon, my chilli plants are 4 times the size of that but with no fruits 😥
You've done really well. The chillies you've got are really multiplying! You're in danger of losing control.
Holy thread resurrection...
Should have grabbed some picture (maybe tomorrow), got lots of small chilli's coming through now 'undreds of the buggers. We gave a good amount away last year, but froze a large butter containers full for our use - just coming to the end of them now (luckily).
What anyone else plan to do with their crop? Freezing, jam(?), pickle em?
Freeze them. Dry them. Bottle them sliced in olive oil.
Looks like it is going to be a great crop.
Will get some pics of mIne up tomorrow. I use mine in a whole load of cooking but I want to Put a couple in some olive oil.
Any of you suffering with pests? My chillis are next to my peppers and something has gnawed a cone shape out of sOme of them
When we tried peppers, they just suffered badly from pests & basically didn't grow, though whatever it was didn't like chilli's too (luckily). No real help, just to say we had the same.. with no obvious enemy to focus on.
[url= http://farm7.static.flickr.com/6191/6038705249_2313178c81.jp g" target="_blank">http://farm7.static.flickr.com/6191/6038705249_2313178c81.jp g"/> [/img][/url]
One's on the right were planted late, but are seemingly doing fine if fruiting quite late. They did suffer slightly & one died due to the cat laying on it! (looking for a cool spot)
[url= http://farm7.static.flickr.com/6134/6038698015_19803722bc.jp g" target="_blank">http://farm7.static.flickr.com/6134/6038698015_19803722bc.jp g"/> [/img][/url]
So no-one got any 'special' ways to store chilli's?
My Apaches and Jalapeños are coming on nicely now, turning fiery red!
Tomato feed seems to be doing really well for them. Going to harvest in a couple of weeks, I reckon.
re storing? I dry mine on a line of thread.
Yup those pots are way too small.
You might try over-wintering a chosen few...
http://www.simpsonsseeds.co.uk/shop/Over-wintering_Chilli_Plants.html
... their 'heated mat' is prolly sus they're in an unheated glasshouse, it might work indoors on the right windowsill.
prolly cus even
We've got plenty of chillis but plants are still flowering too.
Don't plan on over-wintering ours, I thought I remember reading that they produce the best crop in the first year anyway.
Just stored all of my chillis in the form of Thai curry paste, frozen in ice cube trays.
Thai curry for tea tonight with Pumpkin, Butternut squash, green beens and maybe some brocolli & leek. Not what you'd call a classic Thai recipe, but it's what I've got from the allotment at the moment!
They do tend to produce the best crops in the first year, but for some reason one of my plants has gone mad this year (second year) and produced a ton of large, spicy, long chillis. Next year might be pushing it, so I have started collecting seeds from the best fruits.
That said, I do grow mine in the office these days, as they love the constant temperature and humidity. You just need to keep on top of the watering and feeding, otherwise they get a little dried out.
Current plants are:
3 x Black Pearl (flowering and fruiting heavily)
1 x Chilli Pyramid (ditto)
1 x Cherry Bomb (looking a little peaky, but fruiting)
1 x Pinnochio's Nose (Huge, fruiting massively)
1 x Tabasco (On death row. Three small chillis on it and few flowers)
I might try and get the Mauii Purple and Peter Peppers going over winter, and clear out all the rubbish plants in early spring.
Again, loads of chillis here. Just none that have turned red 🙁
got lots of red and green ones, though some seemingly started to turn brown.. imagining disaster I picked em quick.
I now have a suspicion these brown ones just a tad hotter than the rest, one of them that drying has turn yellow... maybe should have left a few as an experiment.
I think the benefit of overwintering lies in an earlier crop the following year.
