I need some way of securing my bikes in my van to make it an arse for them to get robbed. whats the best port of call?
on the ground anchor theme...
i put one in , then knocked the ball bearing into the socket of the bolt so that it could not be easily removed...How do i get it out again???
I use a cable threaded round the framework, luckily I was too lazy to line it.
alex - bolt up type ground anchor bolted to as strong / reinforced part of the floor? Weld up the bolts to prevent them beoing undone
Charlie - cut the heads off with a grinder?
really? Grinder is the only way??
I think that's the point isn't it!
just done a search and found a torc ground anchor with a van kit for £60 ish- sounds like what I need however its surely down to the weakest link - whats the cheapest chain / cable I can get away using without making my ground anchor efforts pointless!?
