Grinding basics...
[Closed] Grinding basics...
I've just ground and made an espresso in a mocha pot which has turned into a cup of coffee - to watery - although if feels like rocket fuel.
Talk me through the basics of grinding if you would...
Posted : 23/12/2014 5:55 pm
Well first you need a Grindr. From what I've read on here you need to speak to Jamie about that.
Posted : 23/12/2014 5:58 pm
If you have a Gaggia espresso machine then the grind should give you a 25 to 30 seconds short at pressure bar 9 to 12.
Since you are using mocha pot perhaps you could tamp it a bit to make the coffee more compact but try not to tamp it too much or your mocha pot will explode. ๐Ÿ˜€
Posted : 23/12/2014 6:05 pm
Wear suitable protection, and ensure the local area has no signifcant fire or environmental risks:
Posted : 23/12/2014 6:11 pm
I give up.
I thin that's me done for the year. Chow.
Posted : 23/12/2014 6:33 pm
Don't forget to dress the wheel before you start.
Posted : 23/12/2014 7:47 pm
Try bumping a little as well. ๐Ÿ™‚
Just experiment with different grind settings and tamp pressures until you start getting decent results. In your case try slightly finer with the same tamp.
Posted : 23/12/2014 7:53 pm
Flounce?
Posted : 23/12/2014 8:01 pm
Posted : 23/12/2014 10:59 pm
