Granulated/Crumbed ...
[Closed] Granulated/Crumbed rubber paint?!
6 Users
I've got a horsebox that needs the ramp recovering...currently covered in thin ribbed rubber with ally strips to prevent the horse skidding down it.
My options seem to be limited to paying £80-100 for some purpose made thick heavy duty rubber with raised ridges moulded into it that would replace the ally strips, but it will add around 80-100kg to the ramps weight and then I won't be able to lift it! The ramp is perfectly balanced at the moment...
Someone has said they used granulated rubber paint on theirs...just slap it on and it gives a rubberised stippled finish. I can't find details anywhere. The closest I've come is a boating forum where people are talking about something similar that they can paint onto decks as a non-slip surface. There was even mention of mixing raw crumbed rubber into an existing paint, but I wouldn't know where to start...
Can anyone help me out?!
Posted : 07/05/2010 5:46 pm
Put sand in the paint and roller it on!
Posted : 07/05/2010 5:48 pm
http://www.protectakote.co.uk/anti_slip_paint.htm
Posted : 07/05/2010 5:50 pm
Thanks Tazzy...replace Granulated with Granular I'm sorted 🙂
Shows it painted on a tail lift so looks like it will be able to cope with a horse stamping all over it 🙂
Posted : 07/05/2010 5:53 pm
You can buy rubberised paint. We made it where I used to work. Essentially it's rubber dissolved in solvents with paint added. We used to sell it as a protective coating for the aerospace industry (ie it's expensive and not readily available)
You can buy non slip type paint for metal fire escapes too. Joking aside it is a bit like sand mixed with paint. Only really prevents against slipping in the wet though.
Rubber boots for the horse?
Posted : 07/05/2010 5:54 pm
lol...slow typing from me there
car mats screwed down ?
I bet Aldidl/wilkos do em
Posted : 07/05/2010 6:22 pm
I knew I should have followed up my Rubber Horse Shoe idea.
Posted : 07/05/2010 9:34 pm
