Got my CS30/CS32 Ch...
[Closed] Got my CS30/CS32 Chainsaw assessment today. Ask me some questions...
25 Users
Questions about chainsaws I mean...
Posted : 10/07/2013 7:02 am
Why should you wear the proper gear?
Posted : 10/07/2013 7:03 am
Should you pick it up by the blunt or pointy end ?
Personal Protection Equipment must be worn to protect the user from....dangerous stuff.
Ear protection, chainsaw trousers, head protection, eye protection, chainsaw boots, gloves..
Posted : 10/07/2013 7:05 am
Is it possible to fit a chainsaw to the stump where your hand should be, like this guy?
If the blade is blunt enough to pick it up by, it needs sharpening.
This will make the cut more efficient, reduce vibration, increase accuracy and increase safety in use..
Posted : 10/07/2013 7:06 am
Yes....yes it is.
Though I cannot see a chainbrake fitted to that machine so personally I would have a more modern version fitted with the required safety features.
Posted : 10/07/2013 7:07 am
 br
Why should both feet be firmly on the ground when using the chainsaw?
Posted : 10/07/2013 7:20 am
What danger does chain shrapnel pose?
Posted : 10/07/2013 7:21 am
Complete the following sentence:
I cut down trees, I wear high heels Suspenders and a bra......
when severing heads in a shopping mall, which 3 safety points must particularly be borne in mind ?
Posted : 10/07/2013 7:24 am
What length bar for zombies?
Posted : 10/07/2013 8:05 am
As a follow on question, should you kneel or stand when decapitating small children?
Posted : 10/07/2013 8:25 am
What tyre's do I need for chopping logs?
Posted : 10/07/2013 11:20 am
Small children should be dealt with by an angled cut from a standing position. If you kneel down you are leaving yourself vulnerable to attack as you need to stand before running..
Posted : 10/07/2013 11:23 am
How many working petrol chainsaws can you juggle with?
Posted : 10/07/2013 11:25 am
If you pull round the chain by hand, can you kickstart the engine?
Posted : 10/07/2013 11:28 am
Why should you check the height of the depth gauge on each tooth of the chain?
What kind of chain lubricating oil should you use near watercourses?
Posted : 10/07/2013 11:40 am
10 safety features on the saw?
Spark plug has black deposits on it. Good/bad?
Name two different sprocket types?
When would a semi chisel chain be better than full chisel?
What is the optimum chain tooth angle for dismembering dead prostitutes bodies, and which type of saw horse is best utilised to properly and fully secure their limbs during this operation (2 points)?
Posted : 10/07/2013 11:55 am
What is the air speed velocity of an unladened swallow?
Posted : 10/07/2013 11:57 am
I thought the CS30,31,32 etc assessments no longer existed as of the end of last year? Are you sure of the qualification you're getting?
a chainsaw on a conveyor belt chops down a tree in a forest, no-one is around, does it make a sound?
Posted : 10/07/2013 12:08 pm
You're half way through decapitating a small child when the chain jams on their orthodontic brace. What is the recommended technique to free the chain?
Posted : 10/07/2013 12:10 pm
There's an aeroplane on a conveyorbelt. Will chasing it with a chainsaw make it take off faster?
Posted : 10/07/2013 12:14 pm
African or European?
Posted : 10/07/2013 12:15 pm
True, they are now 'officially' NPTC units 201, 202 for maintenance and cross cutting. 203 for small fell etcetc but mostly they still get referred to by the old 'CS' names as everything is the same except the numbers on your city and guilds card/cert.
Posted : 10/07/2013 12:21 pm
on my saw, my new chain (which is correctly adjusted before running) appears a bit too slack on the lower side after I have run it...what do I need to check? could my bar be slipping?
Posted : 10/07/2013 12:49 pm
New chains tend to stretch, just re adjust the tension (whilst holding up the nose of the bar) and all should be good.
Posted : 10/07/2013 1:08 pm
I think teddy was testing kayak, mechmonkey, not a pro like you 🙂
anyway, if my chain kept slackening after running briefly Id be also checking that my sprocket didnt have a worn channel in it too ...
Posted : 10/07/2013 1:10 pm
In the event of losing a leg or arm (careless I know), tourniquet or not?
Posted : 10/07/2013 1:21 pm
Is there anything wrong in this picture?
Posted : 10/07/2013 2:06 pm
I PASSED!!!!!!! 8)
Because the Flamingo look is soooo last season?
It induces periodic wingeing in old war veterans.
I put on Womens clothing, and hang around in bars?
Fire exits should be noted, signage must be erected to warn of slippage danger due to the spilt blood, Muzak played over the tannoy must be in stark contrast to the horrific bloodbath ensuing on the ground to aid relaxation.
You want a mid-range bar to maximise reach without compromising manoeverability.
You need kneel only if the child is royalty. All others can be bought down in a relaxed but respectful stance.
Minion dual ply front, High Roller rear,
5 of the garden/diy variety, 3 professional larger models.
So long as you have it parked on a hill.
Depth gauge should be checked as there is an increased risk of kickback with incorrect depth and also vibration can increase.
A biodegradeable oil should be used. Various brands are available based on ingredients such as rapeseed oil.
Blade cover, exhaust, chainbrake, cut out switch, H&S sticker, hand guard, on/off switch, chain catcher, spring-mount, front teeth.
Bad. Mixture too rich
Rim and spur
When cutting hardwoods, 'dirty timber', stump work.
31.5 degrees, and a Y-shaped saw horse for prostitutes limbs.
Unladened, but is it atop a conveyor belt? This greatly affects the outcome.
That's right. The course was billed as CS30/31 or whatever but when he came to pass us, he explained the new qual-code. (201 - 203 or something)
The conveyor belt and the chainsaw make a sound, the tree does not.
Sweets?
No. Aeroplanes are inanimate. Unless the pilot sees you, there will be little or no change.
Prefer not to say.
Yes, although you may require some help with the arm one...
Yes, skinwall tyre on the rear, black sidewall on the front.
Thanks for the questions folks. Strangely I wasn't asked many of the above ones but thankfully I passed anyway... 😀
Posted : 10/07/2013 2:29 pm
Congrats! 😀
Posted : 10/07/2013 2:34 pm
Well done! 😀
Posted : 10/07/2013 2:55 pm
Bloody brilliant, both passing and answering the questions 😆
Posted : 10/07/2013 2:58 pm
favourited for if and when I go for mine. Lett's revision guide to chainsawing exams.
And well done!
Posted : 10/07/2013 3:11 pm
