gone and had my van...
[Closed] gone and had my van remapped ( wow )
There's a "special" forum on Pistonheads for people like you.. 🙂
Posted : 16/05/2017 7:50 am
Rightio here is an update now I have done another tank of fuel .
Tank before remap 33.89 mpg
tank after remap 33.56 mpg
I have tried to drive as normal for most of this tank but have had a few mad moments to enjoy the power .
and also had the air con on a bit these last 3 days so happy with the fuel usage and very happy with the drive-ability .
Am gobsmacked how it pulls in the higher gears should have had it done years ago
Posted : 27/05/2017 7:45 pm
Thanks for update ! I have had mates who have remapped Golfs and Galaxy. Always been positive. Thinking about a bike vehicle and have started considering Diesels with a remap 🙂
Did you think about Clutch / Dual Mass Flywheel considerations ? ie more power could over stress them ?
Posted : 27/05/2017 8:14 pm
Are you remappers happy with taking responsibility for the excess deaths caused by NOX and soot from your remapped diesels. If you know ther is a problem try not to be a part of it - and don't deliberately make yourself one of the biggest contributors to the problem.
[url= https://www.theguardian.com/environment/2017/may/15/diesel-emissions-test-scandal-causes-38000-early-deaths-year-study ]Guardain report on excess deaths[/url]
[url= https://www.theguardian.com/environment/2015/jul/15/nearly-9500-people-die-each-year-in-london-because-of-air-pollution-study ]NOX deaths in London[/url]
Posted : 27/05/2017 8:28 pm
This thread just went full-STW
Posted : 27/05/2017 8:31 pm
Just use the old "powerful 4wd driveshaft saver trick"
Don't hoof it in first, Jamba
I remember the look of surprise a 600 Bandit rider looking for sport with a range rover had on his face as he dusted me from the lights on the inside... But once my turbo spooled up in second 😈
Posted : 27/05/2017 11:03 pm
He'd disappeared?
Posted : 28/05/2017 7:37 am
Nope. NOx in dragsters is added to get more oxygen into the engine. In diesels, it's a byproduct of the combustion and doesn't do anything good in the engine.
Nitrous Oxide =/= Nitrogen Oxides, do not conflate the two. One is a specific compound (N2O) and the other is a catch-all term to describe the NO, NO2 and N2O compounds.
Furthermore N2O is commonly known as NOS not NOx.
(I realise you clarified that later but still wasn't particularly clear)
Posted : 28/05/2017 9:41 am
Internet nobs with a crackpot green agenda are far worse.
Harmless compared to the life changing consequences of a 'car tosspot'* overestimating their ability and selfishly treating the queens highway as their own playground.
* usually called 'Scooby-John', RS-Kev or GTI-Gazzer. For motorbike cocks it's Dave the blade or Gixer John. Whatever it is they are all complete tosspots.
Posted : 28/05/2017 10:11 am
yes I did think about the clutch and running gear
and as I have had the van since new I figured the clutch will neen replacing soon any ways .
how long do clutches last as this one is 148000 miles old .
so no change in fuel consumption or a small reduction when I fall back to driving normally
one vehicle in the last 12.5 years and averaging 12000 miles a year I reckon there are far more bad poluters than me on STW mr Edukator
Posted : 28/05/2017 10:18 am
Posted : 28/05/2017 10:34 am
Can I ask one genuine thing - is this still wrong in some people's eyes - my old t5 was the 130 bhp version, VW made it with the same 2.5 engine in other versions inc. a 170 bhp. I found when carrying a lot for work it struggled a bit up hills so yes I had it remapped to make same output as 170bhp version, for a bit more low down torque and poke when needed. I wasn't tempted to go for the 200bhp+ some people had done, wanted to stay within limits of what VW already used then. I used posh V power diesel too which is supposed to clean your engine etc. The van drove well, nice and smooth with enough grunt for all situations now, I don't drive like a granny nor a boy racer, just boringly average. I guess maybe still a bad person to have done some might say but it did what I wanted without being OTT.
Diesels can be brilliantly simple engines, they produce as much power as you feed then diesel. There's no ballancing, or tuneing, just turn it upto 11. Older and cheaper ebay tuneing kits simply tricked the engine into dumping more fuel in.
NOx is produced at high temperatures with excess oxygen.
Your 130bhp engine will have turbos, egr and intercoolers and engine maps designed to keep the temperatures as low as possible whilst recirculating as much exhaust gas as possible to keep excess oxygen out. You can easily dial the boost up, blank off the EGR and turn the injectors on for longer and get more power and maybe even better mpg. But combustion temperatures (intercooler nonlonger big enough) and oxygen concentration go up so NOx is produced.
Youre also trying to squeeze more fuel through the same injectors. So it wont atomise properly. In the heat of the engine the droplets burn before they vapourise meaning they turn into soot (as theres no oxygen at the center of the droplet). So the endgine produces far more particulate emissions too.
If VW could make a 170bhp van from the same parts as the 130bhp version, with no hit on mpg or polution, why wouldnt they? They would sell more vans as the comparable transit would only have 130bhp or whatever. The truth is they cant. A re-map can because it never gets tested as rigorously.
Posted : 28/05/2017 11:22 am
@trout thanks, 148k that clutch owes you nothing ! Car I am looking at has a 130bhp petrol model and the 105 diesel - so perhaps clutch / flywheel are different but "the car" can handle it. Definitely leaning towards a remap if we go for that car in diesel which is likely as there are so few petrol models available used
Posted : 28/05/2017 11:24 am
Next thing to ponder, what's more environmentally damaging, the handful percentage wise of remapped vehicles, or the poorly maintained tradesmens vehicles ran on a shoestring to scrape an mot every year.
Edit, on that note, I was behind a united utilities corsa van the other day that had clearly a leaking injector, so big businesses is equally culpable as the skint one man bands
Posted : 28/05/2017 11:27 am
Jambs, petrol and diesel have differing torque curves, low down grunt in diesels, it's why dual mass flywheels were developed for early Common rail TD's, to stop them snapping drive train components
Posted : 28/05/2017 11:32 am
@thisisnot very interesting thanks, have heard justifcations about manufacturers havibg to cater for widely differing fuel quality too. Also it's ironic to talk about testibg properly as we know no diesel (or petrol) has really been tested properly.
@ulysee thanks
Posted : 28/05/2017 11:42 am
It's always someone else's fault or there's someone worse. Well here it's you who's just made your already dirty diesel absolutely filthy. You and those like you are the problem. There's a thread on here because someone found a fast food box at the roadside - STW outrage, but litter doesn't kill people in large numbers. Diesels, especially filthy remapped diesels, do kill people. And what do gain? It's just easier for you to break the law, you don't "need" that extra power, but people really need cleaner air.
It's about time there was a proper exhaust gas test in the MOT.
Posted : 28/05/2017 11:59 am
 sbob
ulysse - Member
The answer is someone else.
Always is.
Special mention to the chap who only does 50% more miles than average.
Have a pollution test cheating VW as a prize.
<[i]insert slow hand clap gif here[/i]>
Posted : 28/05/2017 12:18 pm
A pollution test cheating VW in only 2 states in the US where the emissions limits were effectively conceived to all but ban diesels, perfectly legal in the rest of the world. But don't let facts get in the way of riding your high horse
Posted : 28/05/2017 12:31 pm
And you are aware that the official VW recall remap due to misinformation causing mass hysteria world wide, is more polluting than the original map?
Mpg down to 30mpg, force regen to achieve the modified emissions limits the engine was never designed for, destroying egr valves in weeks, VAG running out of replacement egr valves, now on backorder with a lead time of months.
Slow handclap gif.
Posted : 28/05/2017 12:35 pm
I note your concern doesn't extended to animals or litter contribution to environmental degradation / pollution.
Trolling human killing diesel users whilst hypocritically telling people they are ignoring an alternate perspective is your new hobby I guess?
Posted : 28/05/2017 12:52 pm
 sbob
ulysse - Member
The only thing getting in the way of riding my horse, which doesn't run on diesel or petrol is the smog from your vehicles.
You know what isn't more polluting?
Using your car less.
Thanks for demonstrating your sense of entitlement and spectacularly proving my point.
It's always someone else's problem.
Posted : 28/05/2017 1:16 pm
I think everyone should take a read back. The green crusader comment was made in response to the ridiculous notion that a car driver and pedophile were somehow comparable.
But if you all want to look like utter fannys knock yourselves out.
Posted : 28/05/2017 1:23 pm
Isn't that the sole purpose of this forum for some posters?
Posted : 28/05/2017 1:30 pm
Not for me, I don't need the help of STW to achieve that.
Posted : 28/05/2017 1:32 pm
 sbob
It was a strong gambit, I think it still has legs.
Posted : 28/05/2017 1:36 pm
I'm guessing, and forgive me if I'm wrong, that you've not been a victim of child abuse?
Posted : 28/05/2017 1:47 pm
*reads thread title*
*reads last page*
*scratches head*
Posted : 28/05/2017 2:14 pm
 sbob
milleboy - Member
Not sexual abuse, no.
But I have breathed in diesel fumes so am almost certainly qualified to comment.
Posted : 28/05/2017 2:24 pm
Really? Did you have years of councilling afterwards to come to terms with?
Posted : 28/05/2017 2:30 pm
I think this topic can broadly be summed up with a simple gif.
[img] ?w=650[/img]
Posted : 28/05/2017 3:10 pm
There'll be an element of that, but I'd think the tests are done with whatever fuel is specified, and the testers are going to go out of their way to make sure it's as good as practicable. That the engine then has to work in the real world everywhere from death valley to Colorado with a filthy fuel tank full of accumulated crap and fuels from all over the world is a slightly different issue.
As for testing, thats just whataboutism (like most of the arguments for remapping on this thread for some reason?). That the test is based on a flawed simulation of real driving which the engines get optimised to meaning they're never as good in the real world is one thing. Then making the engine worse is still worse than a less than perfect starting point.
Posted : 28/05/2017 5:24 pm
Has it changed your insurance premiums at all?
Posted : 28/05/2017 5:27 pm
 aP
I live near Heathrow, I don't fly. I guess that makes remapping our T5 ok, seeing as I breathe partially burnt jet fuel every day.
Posted : 28/05/2017 7:35 pm
I genuinely can't tell if this is Poe's law or Whataboutism.
Posted : 28/05/2017 7:39 pm
Particularly as the poster chooses to live there....
Posted : 28/05/2017 7:42 pm
Were the potential profits so great that VW deemed fraudulently achieved emissions figures worthwhile? You need to question the marketing genius involved
Posted : 28/05/2017 8:19 pm
 ctk
Note to self "utter fanny" best insult ever.
Which is worse for the earth:
Keeping your diesel and using it as before for say another 10 yrs.
Or scrapping it and buying a new petrol car?
Posted : 28/05/2017 8:38 pm
Or chucking litter liberally around Milton Keynes as some would silently endorse? C'mon we need balance here people.
Posted : 28/05/2017 8:43 pm
#PeakSTW
Posted : 28/05/2017 8:44 pm
ctk
my thoughts too but I need the van for work Flooring installer
not seen many petrol vans on the market .
62 years young and planning on keeping it till retirement
what is the possibility that engine maps have improved since my van was built and good remappers have programmed better maps for the indevidual van .
so when the novelty of the extra power has dulled and I revert to driving like a hypermiler as it is me paying for the fuel .
and say I get a couple of miles e tra to the gallon surly my engine is running better than when new in 2005
I certainly dont have the dosh to replace it and would be daft to on a whim so close to getting off the tools .
Posted : 28/05/2017 8:50 pm
Kryton, I have never suggested chucking litter around Milton Keynes or anywhere else. Or even implied it.
I limited my litter argument to humans with no mention of other species. And why did I limit it to humans? Because like most people I'm aware that litter can be a problem to animals but I've no idea how many animals are killed by litter copared to diesel soot and NOX, and not wishing to make a false statement limited my case to one of which the facts are well known, humans.
There is no balance. Remapping to improve torque and power increases soot and NOX emissions. For some reason some people on this forum find this acceptable. I don't, so I rightly and reasonably point out that the remappers are making a choice to deliberately increase their contribution a known cause of excess deaths.
Society makes choices, a level of pollution is considered socially acceptable/tolerable. If you choose to deliberately modify your car to make it more polluting it's plain anti-social.
Posted : 28/05/2017 9:47 pm
Edukator I can appreciate your "incremental" polution argument but the number of remapped diesels is tiny and their overall impact on pollution is minimal. What is far more significant is increasing over population and urbanisation (central heating is the buggest polluter I understand as is heating our houses warm enough to be able to walk round without a jumper in winter). That plus the whole diesel episode which saw emissions willfully misstated and the EU turn a blind eye. The Americans and Japanese (and most of Asia I think) don't really do diesels for non-commercial vehicles. We where duped.
Posted : 28/05/2017 9:55 pm
Go, on then, ill give you ten minutes to write down a short synopsis of the impact on humankind of how littering the countryside - that if googled cant be found so could reasonably assumed to be your own knowledge, therefore proving this statement:
Of course, if you can't that proves your not the true environmentalist you claim to be and are indeed trolling on the Diesel issue evidenced by ignoring any other environmental argument raised herein.
I make that 10:07 Uk for a response *waits*
Posted : 28/05/2017 9:57 pm
People can read and even read back, Kryton. Their comprehension is generally pretty good too. If someone else had written your own last post what would you think of it?
Posted : 28/05/2017 10:03 pm
In your shoes attempting to belittle someone whilst failing to respond to the challenge would lower my self esteem.
I've proved my point, night x
Posted : 28/05/2017 10:06 pm
P.S you spelled "compared" wrong. 😉
Posted : 28/05/2017 10:08 pm
Was it you or your computer that decided to spell "spelt" the American way, and leave the hyphen out of "self-esteem"? 😉
Posted : 28/05/2017 10:40 pm
Zilch. Nadda. Not a sausage.
One bloke in a shed, Vs the engineering department of VAG?
No it's not, you've just optimized it for something else. VAG were probably aiming to get as much power as they could without producing more pollution than allowed. You've just tuned it for more power.
If you put it through the same tests as the engine would have been through when new, it would without doubt now fail them.
Posted : 28/05/2017 10:47 pm
Interesting detailed article about the whole fiasco...
https://arstechnica.com/cars/2017/05/volkswagen-bosch-fiat-diesel-emissions-cheats-cracked-open-in-new-research/
Seems it wasn't VW rather than Bosch giving them what they asked for.
Very conveniently ignoring the recent report about the staggering amount of plastic on one tiny, remote island that researchers have just highlighted, some of it going centimetres deep into the sand, which, along with the micro-plastics that the environment is filled with, and which are ingested by organisms the entire length of the food chain, threaten everyone and everything, not just the on the macro-scale, like marine animals and birds caught up in fishing line and net, the plastic rings that hold four-and-six-packs together, etc.
"The ethical dwarf, posturing on the moral high-ground, presents a ludicrous spectacle"
Oh, and the amount of filth pumped out by the world's shipping, burning bunker oil, which is the filthiest, thickest fuel used in any transport, it's one step up from crude, creates more pollution than all the cars currently in use around the world.
By your reasoning, we should scrap all the commercial shipping now in use and build a fleet of wooden sailing boats.
Posted : 28/05/2017 11:13 pm
Stop sitting on the fence 🙂
I do think that manufacturers design to general parameters, eg fuel quality which can vary greatly in target markets. Also lower spec models are deliberately lower spec, ie artificially depressed power output. As an example of sorts it was widely believed that Porsche didn't fit a LSD into the Cayman or it would have lapped quicker than a 911 which is not acceptable for a car costing 60% of the price. IMO there is more than just emissions.
Edukator do they re-test emissions in the Controle-Technique ? (Note thats only every 2 years too, based on the amount of French cars I see with faulty headlights/brake lights I struggle to think a 2 year test cycle is desirable). At least in the Uk we re-test to a degree and we have started checking the DPF's are still fitted (easy to see why an owner would avoid ££££ by not replacing after discovering their "lifetime" filter had only lasted a few years)
Posted : 28/05/2017 11:23 pm
@count thanks for that link, tomorrows breakfast reading.
Classic corporate avoidance of responsibility ? Ask a contractor/third party to do something we don't want to be caught doing ?
Posted : 28/05/2017 11:25 pm
[quote=jambalaya ]I do think that manufacturers design to general parameters, eg fuel quality which can vary greatly in target markets.
If they didn't have sensors to detect changes in engine performance due to using different fuel standards, then yes, I expect they'd do that. Assuming that is they sold exactly the same car in target markets with widely varying fuel quality - I'm sure it makes sense for them to sell millions of vehicles which can cope with poor quality fuel into markets where the fuel quality is always good.
That's not a terribly relevant example - sure there are different versions of the same engine block with different power outputs, but you'll find differences in the components other than the engine block (yes, it is a marketing thing as they can have a cheaper version for those buying to a price point and gouge money from those who want a higher spec - but they can also save a bit of money on the cheaper version by using lower spec components whilst getting economy of scale through having a common engine block).
Posted : 28/05/2017 11:49 pm
It would need drugs to make it look attractive 🙂
Posted : 29/05/2017 9:37 am
That's quite a leap, and I'm not sure how you got there by my reasoning, but yes. We should definitely be aiming at a fleet of ships that use renewable energy sources. I don't think wood is the best material to use for their construction though.
They do an emissions test at the contrôle technique, Jamba, but current limits are so high that a well-maintained 20-year-old diesel passes no problem.
Posted : 29/05/2017 10:10 am
Whilst it's certainly right to strive for reductions in emissions to ensure continued health of people and the planet, given that the US military is apparently more polluting IN PEACE TIME than the entire civilian population, perhaps if anyone has a real concern for the welfare of their neighbours and the habitat that 7 billion odd of us are sharing, it might be worth channeling some of this outrage elsewhere...
Posted : 29/05/2017 10:26 am
There's no outrage here, there was outrage on the litter thread, "scum" etc. But here the strongest language I've used is "anti-social".
We are all collectively responsible for many polluting activities and my appeal on this thread is to not deliberately do something that will make a vehicle pollute much more than it normally would.
There are other things we can do to reuce how much we pollute, and the more people who are prepared to do them the better. Rather than saying "everybody else pollutes as much as they can afford so why shouldn't I?" say "I'll do what I can to reduce how much I pollute and if everybody else does too the world will be a better place".
Posted : 29/05/2017 10:40 am
thisisnotaspoon - Member
Depends on how you define a remap, an off the shelf map flashed to your ECU, probably not much. That's a relatively Conservative map that you can just bung on.
But there are companies who make individual maps for individual customers, and they refine them with a laptop plugged in, In real time whilst driving rather than on a rolling road, to suit the individual customers requirements.
Obviously this is expensive and probably only used by people really into motorsports with custom engine configurations, but there's theoretically no reason you couldn't specify an emphasis on economy rather than performance.
Posted : 29/05/2017 11:46 am
^ I think it's fair to say that VAG tend to drive their cars when setting their maps, wiv laptops plugged in and everyfink
Posted : 29/05/2017 11:49 am
milleboy - Member
Really? I'm not a big Porsche fan boy but i think it looks pretty good.
Posted : 29/05/2017 11:55 am
bamboo - Member
Yes but you've missed my point.. They have specific breif to suit most customers under a wide range of conditions, and achieve a reasonable level of efficiency resulting in a one size fits all map.
A 3rd party engine tuner can push the envelope further, the ecu can be fully reprogrammed according to one persons requirements rather then a manufacturer who will program it to mostly suit the requirements of millions of customers.
Posted : 29/05/2017 12:06 pm
Or even the least polluting possible. But that's a lot harder and more complicated. You'd need real-time monitoring of NOX.
Posted : 29/05/2017 12:12 pm
[quote="mattyfez"]A 3rd party engine tuner can push the envelope further, the ecu can be fully reprogrammed according to one persons requirements rather then a manufacturer who will program it to mostly suit the requirements of millions of customers.Mostly what they do is switch off or modify the protection features within the software (overspeed, over pressure, antiknock, emissions and so on). Then they turn everything up a bit. Fuel, air, ignition, injection timing. Then hope it doesn't blow up. That's the tricky bit, how far can you go without it blowing up.
Sometimes it does.
And it's [i]really, really[/i] obvious when you look at the engine.
Posted : 29/05/2017 12:20 pm
Thats what one team do, they hire a particular car, dump the map and save it, modify a copy of the dump, flash, test, rinse repeat until it's what they want and then re flash the unadulterated map , return the car
Posted : 29/05/2017 12:27 pm
OP, how much did your remap bump up your insurance? Or does anyone know what the typical increase would be for a run of the mill performance remap like that?
Posted : 29/05/2017 12:30 pm
The point that tinas (and maxtorque earlier in the thread) made, is that the OEMs spend millions upon millions optimising emissions, fuel economy, and driveability on test rigs and testing the cars in a full range of environments around the world. They have full working knowledge of the software and all the calibration parameters- third party companies simply cannot gain this know how. I wouldn't let anybody touch my car for this reason alone.
Third party companies who do remaps may increase torque and power, maybe even reduce fuel consumption, but nothing comes for free - emissions will increase as a result. People are outraged at VW for cheating emissions legislation; using a remap which will be far worse is antisocial.
Posted : 29/05/2017 12:35 pm
If i was to do one it would cost me nowt extra on insurance, im with TWI
But what about when OEM mappers spending millions and millions on development get it spectacularly wrong, like with the 1.6 Hdi Siemens SID 807 which was undriveable or shook the car to bits in constant speeed cruise POT in 4th gear?
Posted : 29/05/2017 12:40 pm
Mick from Derby won't ever drive above the arctic circle, or across the Sahara. He might even agree to only use high octane fuel, this gives an engine tuner a lot more to play with as some of the constraints are lifted.
Yes they can, they are just parameters on an eprom that can be downloaded, messed about with and flashed back to the chip. Whether you trust them to know what they are doing, well that's a different question.
Quite an interesting article..
[url= http://www.motorsport-developments.co.uk/whatismap.html ]http://www.motorsport-developments.co.uk/whatismap.html[/url]
Posted : 29/05/2017 12:46 pm
That'll be the engine dev team not talking to the dressed engine team or the mounts team or the body structures team.
Or any combination of the above.
It happens.
The car was probably developed around a larger, heavier engine with completely different vibration (and gearing) characteristics.
Then the marketing team decided they needed an entry level/eco car and just slung the smallest engine they could find into the car.
That happens too.
Sometimes causes great surprise to the development departments when they start getting warranty/complaints about cars they've not even considered as a viable combination.
Posted : 29/05/2017 12:47 pm
from that link... 1day to do a map? Somebody should tell vw that's all it takes, they could drastically cut their development time, and save a fortune!
Posted : 29/05/2017 1:06 pm
Exactly, OEM's aren't infallible, and neither are all tuning companies some spotty teenage tosspot banging out maps in his bedroom on a nicked copy of WinOLS
Posted : 29/05/2017 1:09 pm
And as somebody who writes software for vehicle powertrains for a living, sometimes we see oems changing parameters that they have no calibration guide for during development, without understanding the consequences. Fortunately we work with them and develop the calibration together which corrects such mistakes before production sign off occurs. Third party suppliers don't get calibration guides (for IP reasons), so they are stabbing in the dark at best.
Posted : 29/05/2017 1:10 pm
Ok, let's think about hypothetical Mick's tuning.
Only run on good quality, high octane fuel. So you can whack the boost up, increasing temps and increasing NOx.
Never drives in the artic circle. That's more an issue with making sure the diesel doesn't solidify in the tank.
Never drives across the sahara. A more valid point, and but again that's more a hardware issue with specifying a different airbox.
And..............
VAG will have temperature compensation in the maps and the ECU. If he drove it to the arctic circle it would probably open the EGR a bit more because it can (cold air bring with it more O2). If he drove it to the Sahara (or Colorado) it might up the boost a bit to keep the power up in spite of lower air density.
What he does actually do though is drive around Derby. So let's just stick with the VAG map that keeps NOx and pm10 to a minimum ehh?
Posted : 29/05/2017 2:41 pm
[quote=mattyfez ]Mick from Derby won't ever drive above the arctic circle, or across the Sahara. He might even agree to only use high octane fuel, this gives an engine tuner a lot more to play with as some of the constraints are lifted.
It would if the manufacturers hadn't already accounted for that - if he's driving around Derby on high octane fuel, then the parts of the map which will work in the arctic circle, the Sahara or with low octane fuel won't be used. You'd be amazed to find that they have sensors which can detect these things.
I've not worked with ECUs on engines, but I have done lots of work with microcontrollers interfacing with hardware - sensing the envirnoment and having different parameters for different environments is trivial. If Mick is driving around Derby he'll already have the optimum mapping for driving around Derby taking all things into account - as above, any increase in power will be at the expense of something else.
Posted : 29/05/2017 3:33 pm
It's good to see some sense being spoken on stw
Posted : 29/05/2017 3:36 pm
Do you mean 'rare'?
Posted : 29/05/2017 3:48 pm
Sigh. It depends how you define optimum.
Posted : 29/05/2017 3:55 pm
[quote=mattyfez ]Sigh. It depends how you define optimum.
Of course, Mick may reckon that emissions aren't important.
Posted : 29/05/2017 4:02 pm
We don't know what Micks preferences and goals are, I'm just trying to illustrate they may be different to the manufacturers generic audience.
Micks has options with a custom map.
Posted : 29/05/2017 4:05 pm
Page 2 / 3
