I have a glass-topped table that's not faired too well in a recent house move. It has steel studs bonded to the underside of the glass which bolt into the frame.
A couple of these have come adrift - does anyone know what would be best to glue them back, bearing in mind that the glue needs to be invisible...
Ta!
Clear silicone adhesive.
Thanks Ernest, I though about trying that but the stuff that was originally used was a hard glue-like substance.
I could give it a whirl, see how it works. It should be fairly reversible...
epoxy resin? or the stuff to bond rear view mirrors to car windscreens? seen that stuff in b&q before.
That's quite probably the reason why they came off - a little bit of flexibility and they might not have been forced off. Although without seeing the problem it's difficult to know.
