Garmin/OS map quest...
[Closed] Garmin/OS map question re altitude
8 Users
My Garmin wants me to tell it what height I'm at so it can calibrate itself. Are the OS spot heights still accurate?
Posted : 09/03/2010 9:38 am
Yes
Just out of curiosity, what do you think could have happened to make them become inaccurate?
Posted : 09/03/2010 9:41 am
sea level rising due to ice cap melt...glub,glub
Posted : 09/03/2010 9:44 am
How would that change the height of the land?
Posted : 09/03/2010 9:53 am
Oh, because I heard that triangulation pillars were now obsolete and that you could 'adopt' one (honestly) - because now all heights were calculated by satellite. Also, I know from conveyancing work that a lot of plans have been re-drawn because surveying is done by satellite now rather than [however they used to do it - theodolite? camera? I don't know].
Thus, I wondered if the spot heights had also been recalculated - by satellite.
Is that really dumb? 😳
Posted : 09/03/2010 9:57 am
the height of the land is relative to sea level?
Posted : 09/03/2010 10:00 am
So the land is floating on the sea and not connected to the seabed?
I see.
easier than measuring from the centre of the planet...
Posted : 09/03/2010 10:01 am
to its average - it doesn't go up and down with the tide or waves...
Posted : 09/03/2010 10:06 am
Not at all, I was just genuinely interested to know why you thought they may not be accurate.
Posted : 09/03/2010 10:14 am
it does on a Saturday night
Posted : 09/03/2010 10:16 am
Don't forget that you'll need to calibrate it every time you use it if it's a barometric reading. Can't really see why it would need calibrating if it used a GPS altitude (which isn't accurate anyway).
Posted : 09/03/2010 1:35 pm
Except there is no way to calibrate a garmin edge 305 which uses a barometer for elevation.
Posted : 09/03/2010 1:39 pm
[i]Can't really see why it would need calibrating if it used a GPS altitude (which isn't accurate anyway). [/i]
Depends how many satellites it can see. It needs 4 to give height as well as location but I've seen my GPS accurate to within 1m of the quoted heights on OS maps.
How's that work, then?
I suppose it would always be accurate when recording elevation change. Perhaps it takes a "best guess" from its GPS computed altitude.
Posted : 09/03/2010 1:41 pm
No, it's not. It is measured relative to Ordnance Datum. Historically this used to be an empirical measurement against mean low water spring tide level at Newlyn - but hasn't been for a very long time...
That would be luck. I wouldn't bank on much better than 30m accuracy for elevation (based on GPS alone) - hence why many units have a baro function.
Posted : 09/03/2010 1:59 pm
It's a Dakota 20. These are the choices on the Altimeter menu:
Auto Calibration - off/on
Barometer Mode - Variable Elevation/Foxed Elevation
Pressure Trending - Save When Power On/Save Always
Plot Type Elevation/Distance - Elevation/Time, Elevation/Distance, Barometric Pressure or Ambient Pressure
Press to Begin Altimeter Calibration - Do you know the Correct Elevation? - Yes or No - Do you want to use the current GPS altitude?
I haven't learnt it all properly yet, I thought I would get to grips with putting a route into it and following that route on a ride before I got into the more occult functions.
I want to know how much climbing I have done on a ride - training for Kielder.
Posted : 09/03/2010 2:26 pm
Karin - the best bet is to calibrate it when you get to Kielder. The weather (unsurprisingly) can affect the quoted elevation considerably. I always switch mine on about 20 minutes before setting off (from home). That usually gives it enough time to self calibrate and get used to the weather.
Posted : 09/03/2010 2:31 pm
Like I say, I need to learn it more. In the meantime, I will find out what the height is here - from my OS map - and calibrate it when I leave for a ride.
I will use your idea of turning it on 20 mins before I go out. Thanks.
Posted : 09/03/2010 2:39 pm
