Garage doors - anot...
[Closed] Garage doors - another thread. This one about my broken electric one.
2 Users
Over Christmas our garage door stopped working - I press the zapper and nothing happens at all – no noise (ie clicks of solenoids going, motors whirring but not engaging etc) however the convenience light comes on so I know the remote and receiver unit are both working.
The door isn't jammed as I can get it to manually open (using my own contraption of a correctly-sized spindle attached to my cordless drill).
It stopped working once before but suddenly came back to life again, this time it hasn't.
Where should I be looking/what could be the problem?
Posted : 07/01/2016 3:26 pm
Motor fuse in the control box would be my first place to check.
Then check relays.
Sometimes its enough to pull them out, put back and thats it.
Posted : 07/01/2016 3:29 pm
In the control box? As in the unit that sits beside the door (the receiver unit) or is it part of the actual door itself?
Posted : 07/01/2016 4:12 pm
The box beside the door - that will send the signals to the motor unit.
Start/stop/etc.
Check if the motor has a cut out on it - this may have been triggered.
Posted : 07/01/2016 5:18 pm
Cheers - will take a look at the weekend
Posted : 07/01/2016 10:21 pm
Cheers Hammy - after working out how to disassemble the receiver unit I found the pull out fuses and right enough the power one had blown (I'd already checked the mains plug fuse where the power comes from - I hadn't even thought there would be another fuse inside the unit). Anyway, the hardest bit was trying to locate a 20mm 6A fuse on a Sunday morning but I managed it and it's all working again!
Thank you for your advice 🙂
Posted : 10/01/2016 8:53 pm
