Ford - replacement ...
[Closed] Ford - replacement locking nut key debacle
Long story cut short. It appears our car never shipped (from non-Ford dealer last year) with the original key or black bag/box or replacement code. And I'm about to sell it today and Ford are telling me that without that info they need to chisel them off. Yet a friend in Technical disputes that and says every dealer has a master key to help identify a replacement.
What say you? Could be nearly £200 of hassle otherwise.
TVM
Posted : 27/06/2011 11:13 am
Are you on about locking wheel nuts?
Posted : 27/06/2011 11:15 am
get friend in technical to talk to dealer?
Posted : 27/06/2011 11:16 am
Yep, locking wheel nut removal key.
Posted : 27/06/2011 11:17 am
Yessir they're all like that
^^ this.
The mechs have master keys but they don't tell sales/service.
Posted : 27/06/2011 11:19 am
My Focus locking nut mangled itself - got a replacement locking nut set from an autoshop for about £20 and paid a local garage £40 to remove the stuck nuts. Cheap as chips - £200?!!
Posted : 27/06/2011 11:22 am
You can get a locking wheel nut remover from halfords, you will need a vice to get it out of the tool.
http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_196491_langId_-1_categoryId_165469
Posted : 27/06/2011 11:24 am
Had the same problem on my 04 mondeo. Ford dealership wanted the car in "specially" to get them off which was going to cost me an arm and a leg. In the end I went to a mechanic next door who for £10, a couple of minutes work and the use of a socket set, had them bashed off. Re-ordered a new set of nuts for under £50.
Ford (used to - I worked there 3 years ago) have a "master set" that has about 40 options to all the locking wheel nuts. Go to a different local dealer, say you've lost it (ASK PARTS THIS NOT SERVICE) and ask them to order a new one. When they ask for codes, apply a blank look to your face and the chances are the parts guy will grab the set to ID which key it is and order a spare - about £25 if memory serves.
Hope this helps
Posted : 27/06/2011 11:32 am
What a bunch of arse. Buyer just emailed to pull out - didn't even call!
Original main dealer doesn't record such codes even on cars as new as 07. But they say every dealer has a master so I'm going to push on that front.
£200 was generally what local dealers wanted for chiseling plus replacement set etc.
Cheers guys
Posted : 27/06/2011 11:43 am
Yep they should.
Try another dealer. While in collecting mine from a service the other week a chap came in with the exact same thing. They told him to hang on a minute and one of the mechanics would be right out with their box of socket keys, match it up and order one from the code.
Posted : 27/06/2011 12:01 pm
We're back to phone unlocking again. £200 with a bloke with a lump hammer, or five minutes at the dealer and £20 for the correct adapter. Lump hammer please!
Given that the identifying number on the wheel nut key on my Mondeo is actually a colour, I'd be surprised if the number of possible variants got particularly far into double figures.
Our's is apparently an 8 digit code though ...
Posted : 27/06/2011 12:04 pm
try your local knackers yard. you might strike lucky for a 5er
Posted : 27/06/2011 12:17 pm
Cheap steel sockets, smack on and turn.
Posted : 27/06/2011 1:25 pm
