Ford Mondeo estate ...
[Closed] Ford Mondeo estate rear squarty not working???
6 Users
I have a 04 estate and all of a sudden teh rear wash wipe (squarty) has given up the ghost,
Does anyone know why, also how to fix it.
Posted : 20/03/2010 7:09 pm
if the wipers wipeing but no squarty check the pipes not popped off (both ends) if no wiper as well check fuses and see if you can hear if the motor is working, if not price up a motor from a breakers
Posted : 20/03/2010 7:42 pm
Mine was the same, the jet was bunged up. Tried to clear it with a pin with no success, started dribbling and then popped off, flooding the inside of the rear window with screenwash 🙄
I got a new one in the end from Fords parts desk, cost a couple of quid, turned up within a couple of hours for collection. Easy to fit, can't remember if I just had to remove a couple of screws to remove some internal trim or if I removed the high level brake light. Either way, it was obvious and quite easy.
Remove the jet and check the screenwash quirts out the pipe before buying another though.
Posted : 20/03/2010 7:51 pm
check its not leaking inside the headlining. my hatch had a pipe join which was a friction fit sleeve right above the rear middle seat… genius
had to pop the deadlining down and reconnect, that was it. now i think twice about using the rear washer in freezing weather
Posted : 20/03/2010 7:54 pm
On my mondeo the pump had gone and needed to be replaced, it was only £60ish fitted though.
Posted : 20/03/2010 8:04 pm
spooky you are spot on. I'll get a new jet.
Posted : 20/03/2010 8:07 pm
Happy to help 🙂
Steve...did you really just type [i]only[/i] £60! Ouch! Edit: Just noticed that included fitting, so not so bad.
Posted : 20/03/2010 8:30 pm
spooky,
How easy was it to remove the old one (if you remember)
Posted : 20/03/2010 8:35 pm
mine too...the hose had become disconnected and was leaking just above the rear drivers-side seatbelt point in the lining. Ford dealer put it back together whilst under warranty (twice) ...don't use it much now as I'm expecting it would do the same again.
Posted : 20/03/2010 8:53 pm
