floorsanding - stai...
[Closed] floorsanding - stairs
3 Users
I've got some internal stairs needing sanded.
Anyone done this themselves? Seems to me the std equipment (lawmower type belt sander and rotary edger) may not be much use, especially as there is a corner in the stairs. Anyone done this?
Posted : 03/01/2009 4:35 am
yup, did the stairs at the same time as doing all the floor boards in a house,
so i was using an edging sander that was hired out with the big drum floor sander,
this gets a good and quick finish but you have to do the corners by hand or with a detail sander(the ones that have a triangular design),
otherwise a belt sander would work just obviously take longer,
but sanding by hand would work, just depends on how much time you wanna spend on it!
as its not the most enjoyable of jobs 🙂
Posted : 03/01/2009 10:11 am
What I've done is:-
1. invest in a good palm sander such as a Makita. The one I've gothas about a 4" square pad, you can buy rolls of sandpaper at good buider's merchants, and simply cut off a square to fit. Saves a lot of money rather than buying specially cut sandpaper squares/traiangles.
2. Get a triangular paint scraper and a file. File an edge and keep it sharp!
The scraper lets you get into the corners fairly easily, and the palm sander will allow you to palm sand right up to the edge.
Rustins floor 'varnish' is the stuff to use, I recommend to go for a matt or satin finish, the gloss is very shiny!
After all that you need to put some sort of tread on the actual star where you walk to cut down sound and reduce wear on the wood. I've used a cheap corduroy and cut the tread to sit on the actual flat of the stair, floor tacking ( or stapling ) it into place and rolling it around the bull nose of the stair. This gives a protected and sound proofed actual tread, but allows the wood of the riser ( upright ) of the stairs to be seen.
It takes a while, but you only need to do it once!
best of luck!!!!
Q
Posted : 03/01/2009 12:02 pm
