Flash .SWF file con...
[Closed] Flash .SWF file conversion to .SCR
3 Users
Anyone know of a good bit of software that can convert a Flash .SWF file to a .SCR file for a PC screensaver. Versions I've tried so far work but make the file jerky and not as smooth as the original. Ta!
Posted : 14/07/2010 11:17 am
swf2saver pro - mac and PC compatible, about 30 bucks
Posted : 14/07/2010 12:20 pm
only software I came across (cheap) that will generate mac and pc files from same machine too
Posted : 14/07/2010 12:21 pm
Cheers, I'll go have a looksee.
Posted : 14/07/2010 12:57 pm
.scr files are just .exe (executable) files with the extension changed. If I recall correctly, flash can save directly to a standalone exe. If you aren't authoring this file yourself you can probably find a freeware application that will convert the swf to an exe, then just rename it to scr.
In fact, I just found this: http://www.swf-to-exe.com/
Edit: as always with freeware apps and services like this you should virus scan everything before running it.
Posted : 14/07/2010 1:09 pm
Really? Hmmm. I'll try that too! Thanks. Tried the swf2saver pro and it's still slow and jerky when tried on a PC system annoyingly. Possibly my noob Flash skills causing an issue.
Posted : 14/07/2010 1:14 pm
Hmm. That doesn't seem to be working just changing the .exe to .scr. Just opens up a black Abobe Flash Player window.
Posted : 14/07/2010 1:49 pm
Is it an old pc? Might be the graphics card not coping - flash uses a lot of processing power
Posted : 14/07/2010 6:13 pm
