Files from mac to W...
[Closed] Files from mac to Windows? Need help please.
7 Users
Hi,
I'm having a bit of trouble here, I have 70 gb of my friends files on my Mac computer and I have put them on a external hard dive which his Windows computer won't read. The thing is I done my research and formatted the hard drive to the required one but the Windows computer still won't read it.
Any ideas where I'm going wrong or ways around it ? I just want the files in his computer then I can format the hard drive to suit.
Posted : 29/09/2015 6:59 pm
I'm sure Cougar or another it wiz will be along soon....
Would an option be to get a large volume memory stick and use that to hop stuff across?
I assume that they are standard stuff with the file extensions.. ?
Posted : 29/09/2015 7:03 pm
So what format did you use?
Which is...?
What version of Windows?
How big is the largest file?
Posted : 29/09/2015 7:10 pm
Haha yeah research wasn't my strongest part of the post. I formatted to Fat 32 but then dropped the whole file on the hard drive so I clearly went over the max 4gb then with not really putting much thought in I changed the format to ( the older one can't remember) and put all the smaller files on but that didn't work either. So before I put it back to Fat32 and make sure all files are under 4gb just want to know if that is the best way to do it. It is only for a 1 off transfer.
Very old PC though. Running windows vista.
Thanks
Posted : 29/09/2015 8:17 pm
Well, that's where I was going.
FAT32 is the obvious choice but you've got a 4Gb limit on individual files. Confused about what you mean by "the whole file" - are you trying to transfer a disk image?
Posted : 29/09/2015 8:54 pm
What are the files?
both pc and mac should read fat32, I think mac can only read ntfs.
another alternative is:
put the pc and the mac on the same network and connect them directly to each other.
You can connect to a pc share from a mac if you go apple K and type in smb://(IP address of pc.
to create a shared folder on pc, just right click the folder >properties>sharing.
you'll find ip of the pc if you go start>run>cmd>ipconfig.
Posted : 29/09/2015 8:56 pm
Files are just photos and music, I put all his files on my Mac from this external hard drive but then loaded everything off his iPad to it (maybe that file was bigger ) formatted it and that's when the pic diddnt read it. I will have a play with it tomorrow night. I'll check file sizes.
Thanks for your help
Posted : 29/09/2015 9:13 pm
On the odd occasion I have a had a disc formatted on a mac not work on a PC, I Format the disc using the utilities on the PC.
Posted : 29/09/2015 11:00 pm
you could just use a normal mac formatted drive and install the trial version of this software to read it
[url= http://www.pcadvisor.co.uk/how-to/windows/how-read-mac-os-hfs-drives-in-windows-for-free-image-3369574/ ]http://www.pcadvisor.co.uk/how-to/windows/how-read-mac-os-hfs-drives-in-windows-for-free-image-3369574/[/url]
Posted : 30/09/2015 7:34 am
If you loaded everything on to it and then formatted it, that's why it didn't work. Formatting removes all the data.
Posted : 30/09/2015 8:18 am
Thanks every one, got it all working now as FAT 32. It had some big music files on it that I missed before. I broke them down to just under 4 gb and now no prob.
Posted : 30/09/2015 8:04 pm
