Hi all,
I have a very basic knowledge of CMD prompt.
I want to use something like the following but excluding X,Y,Z folders, printing listing the contents of the rest of the folders (without file data, including sub-directories).
[code]dir /s /b > print_No_Data.txt[/code]
Thanks
Reckon you'll struggle to do that exclusion in a one-liner. I'd probably be wrapping the DIR commands in a FOR loop in a .cmd script (or cracking out Powershell). The cmd FOR is quite powerful but the syntax is nuts. Here:
When you say "without file data" do you mean the /brief output above, or do you just want the folder structure? /ad will list only directories.
Ahem...
[url= https://support.microsoft.com/en-us/kb/196158 ]https://support.microsoft.com/en-us/kb/196158[/url]
Yes, just the brief data Cougar. I'll have a better read of that link but there's a brief break in the rain - time to ride home now.
Pyro. Not sure if I missed something in that link Pyro but yes, taking that
[code]dir > filename.txt[/code] but extending with [code]/s[/code] to include subfolders, [code]b[/code] for brief data and also getting it to exclude specific folders in its output.
[i]Ahem...[/i], where's the exclusions?
Yeah Powershell. Let me have a go, I'm learning it ๐
Ahem..., where's the exclusions?
The most awesome bit about that is the commands on that kbase page are a more simplistic version of what's actually in the OP. (-:
Me too. So far my approach has been to write any scripts I need in .cmd script and then redo it as PS. I'm sure I'm missing the point somewhere here.
My approach is to Google the shite out of it ๐ (Which the OP could've done really, but I'm bored)
well that was easy ๐
Are you prepared to share your answer with the class, young Dez?
Get-Childitem -recurse [i]source-folder[/i] -File | where-object {$_.PSParentPath -notmatch "[i]exclude_folder[/i]|[i]exclude_folder2[/i]"} > [i]filename.txt[/i]
I'm sure there's a posh Powershell way to pipe to a file, but why bother eh? ๐
Get-ChildItem -Exclude 'directory' -Recurse | Select-Object -ExpandProperty FullName | Out-File 'C:\Temp\Results.txt'
I think you could set a variable with multiple values for 'directory' but I am typing this from Ubuntu and haven't got round to installing PoSH yet...
NOTE: The whole thing might just fail ๐
Ah, yeah like what he said...
Do you have grep?
If so you could use it to filter out the folders you don't want like this:
[code]dir /b /s | grep -Ev "(MyFolder1|BadFolder|IgnoreThis)" > file.txt[/code]
Yeah, mine actually gives more file info than he wanted, looking back at his post. So...
Very similar Graham, I reckon.
Get-Childitem -recurse source-folder -File | where-object {$_.PSParentPath -notmatch "exclude_folder|exclude_folder2"} > filename.txt
Ooh, I love it when you talk dirty.
Ha, I think between the answers he should be able to figure it out now ๐
I've codified your code markup for you where applicable.
(amateurs ๐ )
EDIT: I broke it in the process, it really doesn't like mixing code and italics. Here's Dez's:
(Muphry's Law in action)
Do you have grep?If so you could use it to filter out the folders you don't want like this:
Not on Windows (did anything ever come of bash for Windows?)
I don't think that would work anyway; it'd filter out the folders, but not the contents of those folders.
I can't find the PowerShell equivalent to /b ๐
I asked because I just ran that on my Windows box ๐
(We have [url= https://www.cygwin.com/ ]cygwin[/url] installed on all our development machines)
It does because /b give you the full path on every line so it contains the folder name.
Only issue would be if you have files/folders with the same names further down the tree, because they'd get filtered too. But you can fix that with a better regex.
Isn't it just a -name switch?
Thanks for all replies. I've just got home. Lots to do before I get time to properly look at the posts but it's clearly not as simple as I imagined it was.
It's these threads where I remember how little I know about computers ๐
When I said I have a very basic knowledge of using CMD prompt, it would have been better to say, I know [code]ping, -n, -t, cd, dir, print, shutdown, diskpart, list, select[/code] basically, how to create a bootable usb drive, how to navigate to a file/folder and how to check if the internet's working (google's pingable).
Thanks again
Ok, well I am sure this is solvable in PoSH using mine and Dez' previous answers but if you must do it from Windows CMD
try;
dir /b /s | findstr /V "bad poor" > results.txt
to exclude folders bad and poor
Doh, of course it does! That makes it a bit easier.
It's not as complex as I thought it was, as I was misremembering how /b and /s worked together. See BigEaredBiker's post, that looks good to me.
[i]Isn't it just a -name switch?[/i]
Tried -file or -name and then the exclusion doesn't work. I shall not give up, even if I have been superseded!
DezB,
Did you figure it out? I just combined your PoSH solution with mine and it works (there is probably a neater way)
Get-Childitem -recurse /home/user -File | where-object {$_.PSParentPath -notmatch "Dropbox|Music"} | Select-Object -ExpandProperty FullName | Out-File filename.txt
This dumped the contents of my /home/user directory excluding the Dropbox and Music directories to filename.txt.
This was on the latest PowerShell Alpha on Ubtuntu 16.04 but should work exactly the same in Windows...
No, I went home ๐
Like it!
I'll have a look tomorrow - I need more challenges like this, best way to learn.
Thank you all. Worked perfectly.
One day STW won't come through and god knows what will happen to the universe!
[quote=Cougar ]Do you have grep?
Also you'd have to be sure that the folder names you are excluding cannot possibly come up in any of the filenames else they'll be excluded too. ๐
Yeah I mentioned that. Easy solved by being a bit more specific with the regular expression.
e.g. by giving the full paths:
[code]dir /b /s | grep -Ev "C:\\Users\\makecoldplayhistory\\(secretstuff|pron|grot)"[/code]
Cougar - Moderatorย
Yes, it's in the Anniversary Update of Windows 10 (64bit only).
https://msdn.microsoft.com/en-us/commandline/wsl/install_guide
Really quite neat too. Runs Ubuntu binaries without recompiling. It can even run gui stuff so long as you've got an X server running somewhere.
Oh cool. I'll have a play with that later. Ta.
I almost feel like I've achieved something this week ๐
