Fellow Prismo for A...
[Closed] Fellow Prismo for Aeropress - any thoughts?
17 Users
Just seen this https://forgecoffeeroasters.co.uk/product/fellow-prismo-for-aeropress/
at my local coffee roasters - anyone used one/have one?
Posted : 04/06/2019 11:51 am
What is it ??
Posted : 04/06/2019 11:54 am
essentially a pressure valve like on a pressurised basket on an esprresso machine by the looks
Posted : 04/06/2019 12:09 pm
This might help re. explanation of what/why/should i?
https://ineedcoffee.com/prismo-filter-upgrade-for-aeropress-review-and-tips/
Posted : 04/06/2019 12:23 pm
Interesting.... Funnily enough just ordered a new Aeropress because the other is worn out...
Posted : 04/06/2019 3:04 pm
Interesting... I like the idea, but having read the review, it seems like it's not going to make enough difference to justify the price for me.
Funnily enough just ordered a new Aeropress because the other is worn out…
You know you can buy new seals?
Posted : 04/06/2019 3:15 pm
I bought a new seal for mine but it was still essentially worn out.
I think when you initially seat the plunger into the cylinder, the little bits of coffee act as a fine abrasive and on mine, they'd started wearing the plastic away.
Still tastes good though.
Posted : 04/06/2019 5:33 pm
Yeah mine is a bit scored, and bows outwards even with the pressure I put on it.
Posted : 04/06/2019 6:04 pm
 cdoc
Tried a prismo but it seemed to make a worse brew than my normal aeropress espresso method.
Also, just ordered a replacement seal from Aeropress and it is the new silicone version. Much better all round than the original rubber ones.
Posted : 04/06/2019 6:19 pm
Oh? Direct from them, or...?
Posted : 04/06/2019 6:21 pm
 cdoc
Direct from their website. Way tighter seal now.
Posted : 04/06/2019 7:12 pm
I bought a seal for a friend from my local roasters - they sell Aeropresses, so I asked them if they had spares and they produced a seal from the back room: worth asking. It was a fiver.
I think when you initially seat the plunger into the cylinder, the little bits of coffee act as a fine abrasive and on mine, they’d started wearing the plastic away.
I wonder if using the inverted method makes that less likely? Since the seal is already in the cylinder when the dry coffee goes in. I've had mine about 4 years and I must have made thousands of cups of coffee and it doesn't show any signs of leaking - this isn't a (strange) boast BTW, just interested to know how/why they fail! I'm religious about not leaving the seal compressed inside the cylinder apart from when it's in use.
Sorry for the seal tangent. Have a baby seal:
Posted : 05/06/2019 10:10 am
Yes seen the replacement seal but they are circa 40% of the price of a new press. The rest of mine is worn also and assuming after market replacements are not as good as the original decided to go for the full hit.
Posted : 05/06/2019 10:44 am
Interesting but that review linked above basically says don't bother!!
Posted : 05/06/2019 10:50 am
what's the thoughts on those metal filters you get? Do they improve the taste in anyway, other plus is better for the baby seals not using a disposal filter all the time
Posted : 05/06/2019 10:56 am
For almost two years now I have been on a quest to get my AeroPress to make something closer to a true espresso
Why bother? An Aeropress makes Aeropress coffee. It's different to filter and cafetiere coffee, and nothing like espresso.
Posted : 05/06/2019 1:03 pm
what’s the thoughts on those metal filters you get? Do they improve the taste in anyway, other plus is better for the baby seals not using a disposal filter all the time
I had a metal filter and went back to the paper filters. I didn't really notice any difference in the taste but the coffee stuck to the filter so required a tiny bit more effort in the morning to clean up after making a coffee so decided it wasn't worth it.
Posted : 05/06/2019 1:30 pm
Whether it's better for the baby seals is open to question too. Some ham-fisted use creased ours pretty early so we too went back to papers.
Posted : 05/06/2019 2:08 pm
I've tried the prismo (have it at home). It's not worth it. It doesn't produce anything like espresso pressure and aside from directing a jet of aeropress coffee (weaponised hot coffee?) it doesn't add anything to the flavour.
So my opinion is just buy a nice bag of coffee as an alternative.
If you want to produce espresso at home with less (or manual) machinery than a Gaggia/Rancilio I can recommend the Flair espresso pump. No, it's not cheap, but it's fun, in a take time over your coffee way. The results are really good, in fact most coffee shops locally don't make coffee as nice as I have at home now.
Posted : 05/06/2019 2:45 pm
I replaced my old Aeropress after a few years of daily use because it was badly scored and the plunger barely touched the sides. Leaked everywhere and made a mess. New one is a joy to use in comparison.
Personally the best results for me have come from grinding my own beans.
Posted : 05/06/2019 3:08 pm
Thought it would be more hassle at first, but never use paper filters now, and it's nice not to have to remember to take them with me/order more when I run out. No difference in taste. Imagine the impact of 4 square inches of paper on baby seals is minimal, so that's not why I have the metal one.
This, at first. Solution: hold the filter by the edges over the bin and flick the clean side. Rinse small amount remaining under the tap with the main press. Job jobbed.
Posted : 07/06/2019 12:25 pm
Question for the collective; Do you remove the seal from the plunger when cleaning your Aeropress? I eventually split mine doing that.
Posted : 08/06/2019 9:24 am
Nope. But then I rarely clean it further than rinsing off the end of the plunger inside the other bit.
Posted : 08/06/2019 10:06 am
