Fabricators of stw,...
[Closed] Fabricators of stw, could you help a fella out?
Morning....
Are there any fabricators out there that could do me some welding type of thing. I'm after 3 angle sets , set to 20, 25 and 30 degrees. Yes I could use a protractor but with my grinding machine it's easier to use set angles, especially when changing the belts. I'm not after a freebie. Willing to pay, just local firms are not interested, and I can't weld!
Posted : 17/10/2016 11:28 am
How about something like this: http://www.ebay.co.uk/itm/RDGTOOLS-ADJUSTABLE-4-X-5-TILTING-ANGLE-PLATE-/351046470221?hash=item51bc000a4d:g:zzcAAOSwQItUBDvk
Not set angles but adjustable?
Posted : 17/10/2016 11:48 am
I'd rather have several bits... Like a square, but set at the angles I need...
Posted : 17/10/2016 12:13 pm
 WTF
Posted : 17/10/2016 12:14 pm
Bugger.... Just realised I need 10,12.5 and 15 degrees....
Posted : 17/10/2016 12:20 pm
Tim - nip down to Bespoke Hampshire Fabrications in Heritage Business Park.
See Chris - he'll fab up anything you need and is quite happy to negotiate forms of payment.
If you aren't sure which is his unit - look for the 8ft tall solid metal Darlek outside!
Posted : 17/10/2016 12:21 pm
Is that down in gosport??
Posted : 17/10/2016 12:27 pm
Yup
Posted : 17/10/2016 12:30 pm
Will keep that in mind then cheers...
Posted : 17/10/2016 12:33 pm
bump for the evening crowd!
Posted : 17/10/2016 8:45 pm
here like this do you mean
http://www.arceurotrade.co.uk/Catalogue/Measurement/Parallels-Angle-Blocks-Test-Bars/Precision-Angle-Block-Set-10pcs
thats actually what we use (not those exact ones)but the same thing for setting angles for precision machining
Posted : 17/10/2016 8:52 pm
that would be perfect and easier to produce than what i had in mind! cheers Mick
Posted : 17/10/2016 8:55 pm
