Extendable plastic ...
[Closed] Extendable plastic tubing... Brace yourselves
6 Users
Where on earth can I get some extendable plastic tubing like this?
https://www.cromwell.co.uk/shop/packaging/packing-cartons-and-tubes/telescopic-squared-tube-packaging/f/40714
Needs to be about 25mm x 1000mm internal. I already have two (no idea where from) but need another 3 or 4 not 50 which seems to be all anyone sells. The previously used cardboard tubes have got damp & disintegrated plus they are holding about 2.5kg so the bottoms always fall out.
Other options that are available much appreciated.
Posted : 19/01/2022 5:49 pm
Does it have to be extendable?
32mm solvant weld waste pipe cut to length, with a stop end solvant welded on, then a couple of lengths of gaffa tape on t other end.
Cost about £2, maybe less.
Posted : 19/01/2022 6:16 pm
Doesn't have to be but is preferred.
2m of pipe is £3.39 so not convinced on your pricing there plus gaffa is a total bodge.
Posted : 19/01/2022 6:50 pm
But those ones in your link are max 200mm long or am.I missing something?
Posted : 19/01/2022 7:04 pm
Each,not for 3.
3mtr length is £4.00 plus end cap is £1.15.
Use solvant weld on access cap on each end then if presentation is important
Or solvant weld a screw on inspection
fitting onto one end
Costs go up to £3.20
Posted : 19/01/2022 7:06 pm
25mmx 1000mm? weird size.
There are some on ebay same as your link for less than £10
https://www.ebay.co.uk/itm/403415393417?hash=item5ded6e6489:g:9bUAAOSwIpFh5Vy0
Posted : 19/01/2022 7:23 pm
The ones in my link and on eBay are 200mm max, I need to store items 1000mm long.
The ones I have are perfect, I just can't find them anywhere.
Posted : 19/01/2022 8:02 pm
Vesda pipe with end caps. You might even be able to blag some offcuts from a local fire detection company. I’ve seen untold metres skipped at the end of jobs.
Posted : 19/01/2022 11:46 pm
@thepodge
Max length 920mm X 22mm internal
MOQ8
https://store.cleartecpackaging.co.uk/clear_uk/rt.html
https://cleartecpackaging.co.uk/telescopic-round.html
Posted : 20/01/2022 10:25 am
