Excel help - letter...
[Closed] Excel help - letters to numbers...
 gee
I wonder if someone can help... I have a row of grades a-d, and some blank cells that I want it to ignore, which I need to be able to report an average of as a number where a=1, b=2, c=3 and d=4. It's important that it ignores blanks rather than assumes blank=0 as that really affects the average. i.e. if I had a,a,a,c then it would report 1.50.
I am currently doing this by running a mirror sheet which uses vlookup to convert each letter to a number, and then =average to work out what I need. There must be a way of doing this in one cell without the mirror sheet, but I can't work out what that is. Anyone....?
Posted : 19/02/2018 3:44 pm
I don't know a vast amount of Excel so I don't know if this will help, but you can do it computationally.
You can use CODE to convert it to ASCII, which is 65 for A, 66 for B and so forth.  Subtract 64 from this and you've got A=1 etc.  (Lower case starts with a=97).
Posted : 19/02/2018 4:01 pm
 tiim
Nested if statement?
=IF(A1="a",4,IF(A1="b",3,IF(A1="c",2,IF(A1="d",1,""))))
Posted : 19/02/2018 4:08 pm
I tend to use SWITCH instead of nested if -
=SWITCH(A1,"a",1,"b",2,"c",3,"d",4,"")
RM.
Posted : 19/02/2018 4:14 pm
Easier way to convert a letter to a number
=COLUMN(INDIRECT(A1&1))
but I haven't thought of an easy one formula way to do what the OP wants without a rather long formula
Posted : 19/02/2018 4:19 pm
 tiim
I tend to use SWITCH instead of nested if –
=SWITCH(A1,”a”,1,”b”,2,”c”,3,”d”,4,””)
Nice - Elegant.
Posted : 19/02/2018 4:47 pm
Here you go, OP.
=SUMPRODUCT(({"a";"b";"c";"d"}=A1:J1)*{1;2;3;4})/COUNTA(A1:J1)
Change "A1:J1" to whatever it needs to be. If you get stuck, shout.
Posted : 19/02/2018 4:54 pm
Nice solution Rob Hilton
Posted : 19/02/2018 6:30 pm
 gee
Rob - thank you very much for your time, that doesn't seem to work - I get a "did you mean to enter a formula?" error.
Any ideas? I copy/pasted it in and changed both cell ranges to the ones I need. Tried entering as array formula and normal formula - no difference. I thought with an array formula that you didn't enter the curly brackets and just press ctrl+shift+enter?
Posted : 19/02/2018 8:21 pm
Rob's formula works a treat, I gave it a try but.......you may need to replace the copy and pasted speech marks with ones you type in yourself
Posted : 19/02/2018 8:30 pm
RB is probly right.
Sumproduct() is an array function, so no need to ctrl+shift+enter. You can use arrays as arguments in other "regular" functions too. Very powerful things can be done :).
Posted : 19/02/2018 8:42 pm
 gee
Amazing - thank you. Replacing the quotation marks fixed it.
Posted : 20/02/2018 9:12 pm
