Excel help - IF fun...
[Closed] Excel help - IF function
5 Users
I thought using the IF function would be pretty straightforward.
I want to compare 2 cells, both containing numbers, and evaluate if they are equal in a 3rd cell. E.g.
| 3 | 4 | =IF(A1=A2,[1],[0] |
This example should return a 0 because 3 does not equal 4.
Can anyone see why this wouldn't work? Excel claims the formula has an error in it.
jon
Posted : 19/08/2011 12:05 pm
Try changing the formula to A1-A2=0 rather than A1=A2.
Oh and are the figure EXACTLY those integers? If there are any decimals in there then this sort of comparison can be tricky to get right and you may have to use something like A1-A2 < x where x is suitably close to zero for your requirements.
Posted : 19/08/2011 12:06 pm
in A3 type: =if(A1=A2, 1, 0)
Posted : 19/08/2011 12:07 pm
=IF(A1=A2,1,0)
works for me
Posted : 19/08/2011 12:08 pm
Cheers Stoner, sorted. I blame the Excel function description which says IF(logical_test,[value_if_true],[value_if_false]) with the bloody square brackets in.
Posted : 19/08/2011 12:09 pm
Could you enter in A3 =A2=A1
This should give you a true or false result.
Posted : 19/08/2011 12:10 pm
Remove all packaging before placing pizza in the oven 😉
Posted : 19/08/2011 12:15 pm
