Excel challenge
[Closed] Excel challenge
I have several (up to 8 or 10 ish) series of data, and they all need to be plotted on a graph. This is easy.
The hard part is that each individual data point has its own timestamp. So for example, rather than having 8 values at 1s, 8 at 2s, 8 at 3s and so on, I've got series 1 point 1 at 0.34s, series 2 point 1 at 0.58s and so on.
Is this actually a scatter graph? I need to draw lines on the same chart and compare trends over actual elapsed time. Y values would need their own scale because the series range from 0-3000 to 0-1.2
Posted : 01/09/2014 8:42 pm
 Pyro
Yup, plot as scatter. You can still plot series, but it'll be a darn sight simpler that way.
Posted : 01/09/2014 8:49 pm
For a bonus point configure Excel so that double clicking on an Excel graph rescales the graph to zoom in on that point by a factor of 2 and right clicking on a point zooms out by a factor of 2.
Posted : 01/09/2014 9:11 pm
Ooh.. sounds useful, ta.
Posted : 01/09/2014 9:50 pm
I can send you some code to do the double click to zoom in bit, it's quite simple to set up in VBA.....
Posted : 01/09/2014 9:54 pm
sounds like functionality they should have built in in the first place...
but back to the OP, yes, scatter plot, time as the X axis. if you correctly apply a date/time format to the column it should even get the axis labelling right.
Posted : 01/09/2014 10:00 pm
