Engineerists - Can ...
[Closed] Engineerists - Can I shorten a hardened steel tap?
I've needed to re-tap a thread on a machine I have to change the pitch of the thread (M16 left hand) which is a one time thing so I didn't want to spend £50 on a tap.
Bought one from China for £10 shipped but it's a taper tap rather than a bottom tap (I can only get to one side of the thread) so it's not quite reaching the bottom of the thread.
Is it possible for me to cut/grind this end of the tap down to remove the taper section effectively making it a bottom tap?
Posted : 07/02/2013 11:43 am
An angle grinder will go through it, then dress the end on a grinding wheel.
Posted : 07/02/2013 11:48 am
Don't see why not -it'll be bloody hard though, so grinding will be the best way. Two initial thoughts:
- If you cut it off, there won't be any run-in on the tap thread, so be careful it goes in square/may be hard to start it
- You will lose a lot of the thread on the tap that would be otherwise engaged in the hole as you cut the thread. If you need to put in a lot of torque to make the new thread you could pull/'drill' the thread out of the hole (badly phrased, I know...)
Posted : 07/02/2013 11:49 am
^^what they said basically -
You can cut it with a grinder but it won't be pretty - however if you've already 'started' the hole using the tap at its full length, the 'cut down' tap should pick up on the threads OK.
Posted : 07/02/2013 11:53 am
Yup, definitely try doing it in stages, don't just cut a big lump off. Normally you use about 3 taps to get a hole threaded to the bottom.
Posted : 07/02/2013 11:54 am
I like many people have shortened many taps in my time. Just get a bir rowdy with the tap wrench - that should do the trick. 🙁
Posted : 07/02/2013 11:58 am
Cheers guys. I have already tapped the hole and it's just the last 5-10mm I need do so the tapered section shouldn't really be needed now. I'll take a small bit off first and leave a bit of taper to see how that goes.
Posted : 07/02/2013 12:09 pm
Edit: Just checked again and I think the tap has gone far enough so no need for cutting 🙂
Posted : 07/02/2013 12:26 pm
