Engineering Drawing...
[Closed] Engineering Drawing Practise
9 Users
 wors
Dimensioning - putting equal - equal on a dimension for 2 holes around a centre line say with the centre distances of the holes on too. Good Practise or not?
Posted : 26/01/2012 10:15 am
Never seen "equal" on a drawing but not 100% what you're asking!
Posted : 26/01/2012 10:23 am
Over dimensioning IMO. One or the other.
Dimension them on a common PCD? Think it's up to you/company/client practise - as long as there is sufficient info on the drawing to re-draw it/manufacture it based only on what is on the drawing sheets then you've passed the first/major hurdle 😉
Posted : 26/01/2012 10:27 am
You got to think about the guy who has to build it. Have you provided all the info he needs? How you present that info isn't that important as long as its correct and easy to understand and is consistent
Posted : 26/01/2012 10:29 am
 flip
Put the = sign on either side of the centre line along with the dimn. normal practice.
Posted : 26/01/2012 10:33 am
 wors
There is enough info on the drawing, I always thought putting = = around a centre line was bad practise, but my current boss doesn't. Not that it matters.
I guess I have been influenced by the older guys who I used to work with who drew everything by hand.
Posted : 26/01/2012 10:35 am
 kevj
It in not necessarily bad practice and I have seen examples of this on many drawings. The only problem is if the reader is not able to quantify what '=' means from other dimensions.
Posted : 26/01/2012 10:37 am
 cp
Dimension between the holes, with a equal each side is usually sufficient in our place.
EDIT - and for our subbies
eg/
Posted : 26/01/2012 11:03 am
 flip
Yes but the OP said around a C/L there isn't one on that example.
Posted : 26/01/2012 11:05 am
 cp
I know - I was showing what was sufficient for us & our subbies.
If they were absolutely position critical holes, eg. dowel holes, location holes or some such, I wouldn't be using = X =, everything would be off datum faces. For stuff like mounting holes, tapped holes etc... I'd say either as I've done above or with a CL, doesn't really matter.
Posted : 26/01/2012 11:08 am
 flip
Ah yes.
This is making me miss engineering 😐
Posted : 26/01/2012 11:12 am
Me too.
Spend my time on illustrator instead of solidworks these days 🙁
Posted : 26/01/2012 11:24 am
