Endomondo Uploading
[Closed] Endomondo Uploading
7 Users
I have used Endomondo for a few years now with no issues..... until a few months ago when the Endomondo site was presumably 'upgraded'...... now I'm experiencing two issues when uploading from a Garmin 500...
Issue 1 - all uploaded rides have the 'include in statistics' button unticked, so I have to go back into the rides one by one and tick them..... right hassle!
Issue 2 - when uploading theres a drop down list for the type of activity ...eg running, mountain biking etc..... no matter which option I select from the drop down list all activities upload as Running..... so again I have to edit each ride after upload to correct the activity.
So.... any ideas why this is happening or what I can do to fix things????
I can't see any options in Endomondo settings......
Posted : 14/10/2013 8:30 pm
Strange.
It always used to default to running, regardless, but they changed it a couple of months back to let you choose at upload time. Worked for me the last time I did that. All of my uploads have the right activity type still (just double checked).
Posted : 14/10/2013 8:38 pm
my rides always used to default to cycling sport!
Posted : 14/10/2013 8:49 pm
I'm having exactly the same issues that the OP is describing. I'm using an Edge 800 and it seems to have started about a month ago.
EDIT: Seems we are not the only one - see discussion here:
https://getsatisfaction.com/endomondo/topics/ehqmz1efs7rol?utm_medium=widget&utm_source=widget_endomondo
Posted : 14/10/2013 9:16 pm
Yep - with you all
Defaults to running and doesn't show rides from September in the stats
Its tried to get all clever and has just ended up being annoying
Posted : 14/10/2013 9:42 pm
I've had (sort of) the opposite experience.
Endomondo doesn't support uploads from my Dakota 20 via the Garmin Plugin so I have to do them as a File Upload. Previously, this would load it in as "Running" and I'd then have to go edit it in Endomondo.
Now, I get a drop-down in the dialogue box that lets me change it before Endomondo saves it.
To the OP - does this happen if you only load in one session or only when you try do do a few at once?
Posted : 14/10/2013 9:45 pm
Bolton john... exactky mate!
I've emailed Endomondo twice and had no response ! annoying!
Posted : 14/10/2013 9:49 pm
Fellas..... I have a response from Endomondo!
[i]Thanks for getting in touch
We're aware of these critical issues, and we are working on solving them. You can follow the issue here: https://getsatisfaction.com/endomondo/topics/garmin_upload_stopped_working
Have fun tracking with Endomondo![/i]
Cheers,
Mikkel
Endomondo
Posted : 15/10/2013 5:12 pm
uploading from file option and browing to the file rather than direct from Garmin seems to work ok!
Posted : 15/10/2013 8:19 pm
Direct from Garmin 800 here always says Running too.
Posted : 15/10/2013 8:21 pm
Same issue uploading from my edge 800 too!
Posted : 17/10/2013 10:19 am
