Dropped my phone in...
[Closed] Dropped my phone in the bath.
It's a galaxy s4 and it has the little earphone sign come up.
If I make a call I can't hear or be heard.
With the cover off I can see lots of little screws holding it together. If I try to take it to bits to dry it out will I totally kill it?
Any other suggestions?
Posted : 09/11/2016 8:59 pm
Probably best not to turn it back on until its dried out.. take back off, remove battery if it does and stick it in a large jar of rice (uncooked obviously) to dry for 24 hrs
Posted : 09/11/2016 9:02 pm
Gave it a blast of mrs Zip's hairdryer and it lives again!
Posted : 09/11/2016 9:05 pm
Ueh keep it turned off for about 3 days, put in airing cuppbord pr somewhere warm with rice/scillica gel packs.
There's obviously water in it so power it off straight away before it spreads and dry it out, you might have got lucky.
There still might be moisture lurking inside.. you need to dry it properly.
Posted : 09/11/2016 9:06 pm
Put it in rice.
Take out of rice.
Cook rice.
Add eggs.
Throw phone in bin.
Eat rice.
Mmm, egg-****ed-sung.
Posted : 09/11/2016 9:07 pm
When upgrade time arrives, consider a more water-resistant device should you think you might need it.
Getting fed up with similar occurrences I opted for Xperias, currently I'm using the X3c and have no issues.
Posted : 09/11/2016 9:11 pm
Have had similar, I think there moisture in the phone was making it think headphones were plugged in so was attempting to use that as a mic when it wasn't really there. A couple of days in a bag of rice sorted it.
In future if you're gonna use your phone for browsing pron in the bathroom, put it in a clear plastic bag and have a shower rather than a bath.
Posted : 09/11/2016 9:13 pm
You need to counteract the water effect therefore you must throw the phone in fire. This must be done for the exact same duration of time as it was in the water. Hey presto! Damage reversed!
Posted : 09/11/2016 9:14 pm
I belive isopropyl alcohol (maplin) should drive the water out.... look it up on u tube.
Posted : 09/11/2016 9:21 pm
Have put it in a bag of rice just in case. Sure it will be fine.
Glad it wasn't a posh phone or my iPad.
Posted : 09/11/2016 9:30 pm
Oven at 60 degrees for a few hours
Posted : 09/11/2016 9:34 pm
I've had this on a wet iPhone. Roll up kitchen roll, poke into headphone socket, change paper, repeat. Worked fine after.
Posted : 09/11/2016 9:49 pm
Note many manufacturers put moisture indicators in their phones, little stickers that are stuck in strategic places that change colour in presence of water. Allows them to invalidate your warranty should you return the phone as they can prove it's been in the water.
Posted : 09/11/2016 10:22 pm
 cp
doubt an S4 in the OP is still in warranty, but the sentiment does apply in general
Posted : 09/11/2016 10:47 pm
Or don't take your phone into the bath.
Posted : 09/11/2016 10:57 pm
And where do you expect to take photos of my willy?
In the kitchen? That's sick.
Posted : 09/11/2016 10:59 pm
At least dropping it into the bath will stop it spontaneously combusting in your hand... ๐Ÿ˜‰
So it's considered acceptable behaviour to soak an expensive piece of electronic equipment, then return it and ask for a refund claiming its faulty manufacturing?
Little wonder they do it, then.
Like fat-assed individuals who put big phones in their back pockets then snivel because they bend when sat on!
๐Ÿ™„
If my phone does die from rice ingression what should I buy?
Must be android ,take a memory card, have a battery I can easily swap and a good camera with a dedicated camera button. Does it exist?
Posted : 09/11/2016 11:20 pm
I have a Sony Z3 which has all of these (bar the battery but the one in it is excellent)and is waterproof* to boot. Mines a couple of years old so is presumably fairly cheap now or a newer model available. Very happy with it.
*They say it's waterproof and I use it in the shower sometimes. However after a brief dip in a canal it was temperamental for a few days and the camera lens misted up so probably best taken with a pinch of salt.
Posted : 09/11/2016 11:30 pm
CountZero - Memberย
Absolutely they're right to refuse based on water damage. My point is that any other fault that arises that isn't to do with water damage will be instantly rejected because they have proof that at some point there was water in there. Also some get tiny bit of water in through a hole somewhere which triggers one of the indicators but doesn't get into the phone internals, and that's it, no warranty.
Posted : 10/11/2016 10:28 am
Yep, and replace it with propan-2-ol.
Posted : 10/11/2016 10:48 am
I did this with mine and it deleted all my contact details, apart from my Uncle Ben's.
Posted : 10/11/2016 11:32 am
my son had a habit of nicking my old S4 to watch youtube videos...last time he had it he left it in the backyard...in a paddling pool with about 12 inches of water...for about 3 hours. it had on of those tech21 cases on. the phone was still working ...until he then dropped it and broke the screen
Posted : 10/11/2016 11:51 am
