Does this , (Silico...
Does this , (Silicon sealant) tool exist?
9 Users
3 Reactions
I need to redo the sealant bead behind the kitchen sink against the splashback. Most of it is normally accessible, but the critical area that has failed and is at risk of water damage is right behind the tap, which is hard to get to with a standard sealant gun and of course the tap is complete arse to remove because the backing nut is largely inaccessible behind the bowl.
Does a low profile or small gap sealant applicator exist that solves this issue, or is there a some other clever solution? This must be a fairly common problem. Well it is, because our bath taps are not much different.
Posted : 16/09/2025 9:26 am
Posted by: tthew
...is there a some other clever solution? This must be a fairly common problem. Well it is, because our bath taps are not much different.
It is, your thinking about it back to front though.
The tool your looking for is the correct spanner to remove the tap:
https://www.screwfix.com/p/forge-steel-adjustable-basin-wrench-1-2-3-4-/410YC?gclsrc=aw.ds&gad_source=1&gad_campaignid=22599672207&gbraid=0AAAAAD8IdPwCfY4lgG6GZurY-aNjVp18b&gclid=CjwKCAjwlaTGBhANEiwAoRgXBbiQhW7tRI64FtMrLztBgmfg8bDgNnpofhMoc8-gYE3xggOVSZO9FRoCX_oQAvD_BwE
Posted : 16/09/2025 10:27 am
Use some silicone profiling tools? You'll get a much better finish
https://amzn.eu/d/h8MFGou
Posted : 16/09/2025 10:35 am
It's not that kind of backing nut, it's a small one that clamps a big C shaped washer, (as far as I can feel!) No doubt a tool for that exists, but messing with plumbing just adds more steps if a compact applicator is a thing.
Posted : 16/09/2025 10:42 am
Sorry couldn't edit my post...
What I meant was, you can you pipe the silicone in from either side of the tap to meet in the middle and then finish it with the profile tool?
This vid is really good....
Posted : 16/09/2025 11:08 am
I’ve never found anywhere that my finger won’t fit.
Posted : 16/09/2025 1:06 pm
thenorthwind reacted
Use masking tape either side of the joint to create the size of bead you're after.  Get a bottle of white spirit and a load of paper towel, spludge a line of silicon in there as neatly as you can then use a finger soaked in white spirit to smooth it off.  Wipe the excess off your finger with the paper towel and repeat till happy.
And it annoys me that people fitting taps leave that 2 inch thread uncut so you can't loosen it off with a normal socket.
Posted : 16/09/2025 1:33 pm
Not addressing the space problem specifically but watch this
Posted : 16/09/2025 2:39 pm
toby and mattyfez reacted
Don't use masking tape... You'll create a small lip and it won't age well.
A couple of quid on a pack of profiling tools is really what you need.
Really easy to do a perfect job that way..
Have a lot of kitchen roll on hand an a bucket to chuck soiled ones in.
Pipe the silicon on fairly generously and let the profiling tools do their job.. There will be a fair bit of wastage, hence the requirement for a big roll of paper to wipe the profile tool with an a bucket to chuck it in but it's really the best way to do it.
I got an excellent result my first time doing it and was supprised how easy it was if you follow the process.
Posted : 16/09/2025 2:46 pm
^^^^^^^^^^^ THIS ^^^^^^^^^^^^^^^^^^^^
Just to add
Buy decent silicone . Mapei or Dow
Dont leave it very long before tooling it as  it will skin over
Do short runs with the tool and wipe it clean every pass.
Do not use a finger covered in spit. The uncured silicone absorbs the mouth bacteria and its one of the causes of blackening
Posted : 16/09/2025 3:00 pm
Posted by: scuttler
That video is bang on.
Posted : 16/09/2025 8:09 pm
Posted by: wheelsonfire1
I was about to say that a wet fingertip will fit, bugger messing about with fancy tools, when a wet fingertip does the job with greater sensitivity and precision.
Posted : 16/09/2025 9:38 pm
And be sure to use a water based lubricant rather than an oil based lubricant.
Wait..are we still talking about the same thing here?
Posted : 16/09/2025 9:48 pm
