Does this chisel ex...
[Closed] Does this chisel exist?
Not too complicated - all I want is a cranked bolster chisel I can use by hand.
My Google-fu must be weak (or I must be using the wrong name), because I can't find one anywhere. Just plenty of SDS ones, like this:
https://www.toolstation.com/milwaukee-sds-plus-tile-and-plaster-removal-chisel/p54509
Help...?
Posted : 06/01/2020 10:03 am
A bolster chisel & a lump hammer?
Posted : 06/01/2020 10:20 am
I've got a bolster chisel and a lump hammer already, what I want is a cranked one - i.e. the bend in the shaft.
Posted : 06/01/2020 10:23 am
Just bend the one you have then.
Posted : 06/01/2020 10:31 am
I'm sure the BIL has one for removing tiles .
Posted : 06/01/2020 10:32 am
If I had a blacksmith's forge, I would...
CheesybeanZ - I'm sure I've seen them too, I just can't find one to buy anywhere!
Posted : 06/01/2020 10:33 am
Thanks Tallpaul - that's kind of what I'm after, but without the plastic sheath as I'll be wailing on it with a lump hammer.
(sorry, clearly I'm the goldilocks of chisels... 😀 )
Posted : 06/01/2020 11:04 am
the plastic sheath will come off if you want but its there to protect your hand while you are bashing it with a lump hammer
Posted : 06/01/2020 11:05 am
 Bear
Buy the SDS one and you can still hit the end with a hammer...
Posted : 06/01/2020 11:57 am
Hid the end of the hardened sds chisel at your peril, i still have the shard stuck in my wrist bone from 30 years ago hammering a Kango chisel unbelievable pain for the size and no mess just a wee incision
Posted : 06/01/2020 12:25 pm
Ha! I was considering buying an SDS bit and just using that, so I'll consider myself warned redmex.
Teej, the Ansell tile removal tool Tallpaul linked to doesn't quite look like the instrument of brute force and ignorance I'm hoping for...
Posted : 06/01/2020 12:42 pm
Bear with me - Kango do a wide chisel with a long hex shaft.
This would allow you or someone to do some blacksmithing and put a bend in it to your requirements.
A bit pricey though.
Posted : 06/01/2020 5:35 pm
Teej, the Ansell tile removal tool Tallpaul linked to doesn’t quite look like the instrument of brute force and ignorance I’m hoping for…
If it's brute force and ignorance  ceramic  tile removal you're after then the best tool for the job is a flat bladed garden spade.
Posted : 06/01/2020 5:38 pm
Everyone needs a Mutt in their life.
https://www.screwfix.com/p/roughneck-mutt-pro-steel-blade-with-d-handle-8-x-4/25947
Posted : 06/01/2020 5:48 pm
Perchy, dogbone, I reckon you're onto something there, cheers! I will check if any of my spades are flat bladed and if not get one of those Roughneck Mutts ordered (who can resist a bit of marketing like that 😀 ? ).
Posted : 06/01/2020 6:05 pm
Something like this do the job ?
Posted : 06/01/2020 9:12 pm
I just grabbed the top edge of the kitchen tiles and pulled them off in sheets.
He tiled himself he proudly told me when I viewed the flat.
Posted : 06/01/2020 9:45 pm
Thanks tonyplym, that is what I had in mind. Lots of options now.
This is for concrete render, not tiles. Unfortunately it's not coming off without a fight...
Posted : 07/01/2020 9:57 am
This may seem a silly question but why not just get an SDS drill and chisel? I did that after getting 1/4 way through stripping a wall of plaster with a lump hammer and bolster, it took the same amount of time to the remaining 3/4 with the SDS.
Posted : 07/01/2020 10:43 am
SDS breaker and chisel.
Unless it's all completely boss then you'll be there for ever trying to get it off by hand.
Posted : 07/01/2020 10:51 am
Unless it’s all completeley boss then you’ll be there for ever trying to get off by hand.
This is my thoughts exactly. Was going to point out you can just smash up tiles with a ball ended hammer then remove them in pieces, but I'm pretty sure this won't work for concrete!
Posted : 07/01/2020 11:00 am
+1 for an sds for concrete render. And maybe a scutching chisel
Posted : 07/01/2020 11:05 am
 diz
Finbar if your anywhere near south Lancs or Merseyside you are more than welcome to borrow an SDS drill and chisel.
Posted : 07/01/2020 11:06 am
I was going to see how far I can get without an SDS drill - I got a few square feet off the other day with just my little bolster chisel - but yes, an SDS drill will be necessary at some point. Thanks for the very kind offer Diz, but I'm in Sheffield.
While I have all you tool experts on one thread, what would you recommend in the world of SDS drills please?
Posted : 07/01/2020 11:24 am
Hiring.
Unless you're going to use it regularly then you'll get a better tool  for less cost.
Posted : 07/01/2020 11:26 am
I didn’t know these were a thing:
https://www.screwfix.com/p/roughneck-mutt-pro-steel-blade-with-d-handle-8-x-4/25947/blockquote >
Now I do I MUST have one. Plenty of trees and shrubs to grub out in my new garden, this will be just the thing
Posted : 07/01/2020 11:47 am
I got a cheap Bosch one from Screwfix for about £100, did the job for chiselling off plaster, not sure how it would fare with concrete render but I'll be finding out over summer as the stuff on the house bridges the DPC. Didn't hire as we were renovating so it came in handy for many other things.
Posted : 07/01/2020 11:51 am
This Titan Sds drill is what I have.
https://www.screwfix.com/p/titan-ttb631sds-6-3kg-electric-sds-plus-drill-22-piece-accessory-kit-230-240v/4172G?tc=RT4&ds_kid=92700022888075453&ds_rl=1241687&ds_rl=1245250&ds_rl=1244066&ds_rl=1249796&ds_rl=1245250&ds_rl=1249484&gclid=Cj0KCQiA9dDwBRC9ARIsABbedBOi8kOK8kinnbEnfI75xblrRpKk3hk0aTUF8pULBTenZ3ktyYFmzFsaAnmyEALw_wcB&gclsrc=aw.ds
It's an absolute beast of a tool. It really is massive and heavy but it could get through the Hoover dam. It comes with quite a few bits in the case for 80 notes. Don't think it has a cranked chisel though.
Posted : 07/01/2020 12:25 pm
6.3kg? Jesus - my arms would fall off after 15 minutes 😀
Posted : 07/01/2020 12:33 pm
Both our builders had the titan SDS ^^, and they use them a fair amount and rate them highly. I borrowed one to lift some kitchen floor tiles and they're heavy but do the job with grunt to spare - took me the same time to get two up by hand as it did to do the rest using the SDS.
EDIT - not sure whether they had that particular version - from memory there are two, one lighter than the other. I used the heavier of the two...
Posted : 07/01/2020 3:51 pm
I got a Titan SDS drill a few months ago for some tiles and render.
Special offer at Screwfix at about £60.
It absolutely walked through the job, beast of a machine.
Posted : 07/01/2020 7:19 pm
ive used one of these https://www.toolstation.com/roughneck-gorilla-utility-bar/p88642
Posted : 07/01/2020 8:24 pm
6.3kg? Jesus – my arms would fall off after 15 minutes 😀
You're not wrong. It's a weapon! 😁
Posted : 07/01/2020 8:26 pm
+1 for the Roughneck Mutt. We've got a whole army of them in work for separating things. They're quite tough but one has been bent, not a ****ing clue how mind.
Posted : 07/01/2020 8:30 pm
No household should be without An SDS Drill, So much better for drilling masonry than pissy little battery drills and far safer/less tedious than a bolster and hammer.
Posted : 07/01/2020 8:40 pm
Ive got that same drill, used it to put 150mm hole saw through concrete. Think we found its limit. Interestingly i thought the torque limiter would kick in but it just ground to a halt!
It does make light work of anything more normal though!
Posted : 07/01/2020 9:24 pm
Such a blokey thread this is my tool is big etc, nobody has yet mentioned sds max. The basic sds shaft usually shears but get a German Wacker with Bosch sds max chisels that builds your forearms
Posted : 07/01/2020 9:46 pm
It'll cost you 15-20quid to hire one
Posted : 07/01/2020 9:50 pm
