Do you drive a manu...
[Closed] Do you drive a manual or auto car?
I had forgotten about the elastic band connection between the wheels and the engine. That wiffly waffly noise it makes while it is deciding if its going to go faster or not 🙂
Posted : 24/02/2011 8:25 am
The non-existent engine braking varies in different torque converter autos. Some completely de-clutch, some leave you in top, some in a lower gear. It feels really weird at first but you can get used to it and it saves fuel I think because you can roll for ages.
Posted : 24/02/2011 9:54 am
6 speed auto in my diesel BMW.
It's the older type with a torque converter, but a lock-up in each gear makes it near enough to a semi-manual box you can't tell, but without any of the disadvantages that comes with that.
If you do buy one of the fancier autos, make sure you test drive it for low speed manoeuvring, as the ones I've driven don't have any creep, and with no clutch your only choice is to give it a bit of welly and then jump straight on the brake. Bloody awful.
Having said that, the BMW one is not without its problems. Primarily, it's because none of the fancy lock-ups work when the gearbox oil temp is below 30C, so it's like a nasty, sluggish, 1980's gearbox for the first mile when the engine's cold. Not really noticable when the outside temp gets above 10C, but it takes quite a while to warm up when it's say, -10. And the fuel economy stinks when it's cold.
But that might be a BMW thing, because the fuel economy stinks anyway.
Posted : 24/02/2011 11:23 am
My DSG does, but only a little bit at first, then the computer decides to tickle the clutch but doesn't do it very smoothly, so it'll start to surge forward or backwards. Manoevring in a car park is a question of learning how to get on the brakes quickly enough to control it - can be done, but it's an art.
No harder than learning how to use the clutch yourself mind. But also no easier.
Posted : 24/02/2011 12:09 pm
I'd be interested to hear why, since its the combo I have!
Ok, Im at a t-junction trying to turn right. Its busy i've been sitting there a while. A gap appears thats small but safe provide I react promptly and then this happens:
1. press gas pedal in an attempt to move out, car creeps forward barely moving.
2. Give it more gas, car still barely moving other cars are approaching!
3. Give it lots of gas, car drops gear revs increase turbo kicks in and now we have wheelspin! The car ends up making a drama out of what should be a simnple manouver.
The 2.0tdi engine is ok, the DSG gearbox is ok but they combine horribley.
Posted : 24/02/2011 12:16 pm
Yeah Horatio - that is the one downside of my DSG. Like I say there are supposedly ways round it but I've not been able to make them work.
Posted : 24/02/2011 12:22 pm
Changing from a manual to an auto there will be a moment where you go for the clutch. If it turns out ok it is amusing to see the looks of 'Why the emergency stop?'!
My Volvo is an auto. It kind of suits it as it's got a shed load of power. Would I swap it for a manual? Hell yeah!
Not sure I agree it's that much better in traffic, tend to use my left foot to brake in an auto and I find it gets more tired than normal sitting on the brake instead of the clutch.
Posted : 24/02/2011 1:27 pm
horatio - Member
I had a A3 TDi S-line with DSG as a courtesy car a while back and had exactly the same issue. It made pulling out a real chore - it just crawled out ad then lurched forward when the power came in, htne as soon as it had come it was gone...one of the reasons I don't like diesel much, too short a powerband for me. guess you just adapt to it in the end
Posted : 24/02/2011 1:49 pm
 Tim
In traffic - auto, to save the clutch and left leg 🙂
everything else - manual
I like changing gear
Posted : 24/02/2011 1:52 pm
That's NOT a diesel thing, it's the way they've set the DSG up on that particular car.
But let's not get stuck into this again eh? Just use higher gears, that's all you need to know.
Posted : 24/02/2011 2:02 pm
Having to sit with my foot on the brake at traffic lights.
My merc auto has a neat feature. Just press the brake pedal a bit firmer as the car stops and it applies the parking brake. Leave in D and when the lights change press the accelerator to move off - simples.
Most of the time auto is fine but I did nearly bin it on the snow last winter on a slight downhill country road. I realised that if I touched the brake I would be in the hedge so I used the tiptronic to change down from 4 to 2 which still involved a fair bit of fish tailing but I managed to save it. Without tip I would have been in trouble.
Posted : 24/02/2011 2:15 pm
[i] tend to use my left foot to brake in an auto [/i]
Why would you do that?
Posted : 24/02/2011 2:18 pm
VW Auto-hold FTW.
Can't see why that would be better than using the brakes properly. Why brake two wheels instead of four?
Posted : 24/02/2011 2:29 pm
 br
[i]Can't see why that would be better than using the brakes properly. Why brake two wheels instead of four? [/i]
tbh in snow I disconnect the traction control and use the manual side of the auto gearbox, - the idea is you can still steer with the front, but slowdown with the rear 😕 it works
Posted : 24/02/2011 2:34 pm
 Keva
six speed manual in my car. driven plenty of autos, much prefer manual by miles.
Kev
Posted : 24/02/2011 2:38 pm
 LoCo
My E class merc. had an auto box which was ok, all my Vw's and BmW's have had Manual which I prefer.
Posted : 24/02/2011 2:41 pm
Manual here. I'll happily put up with the boring clutchwork round town to enjoy the cross country stuff. Cars are already too civilised without them taking yet more control away from the driver.
I'd be interested to try a flappypaddle effort at some point.
Its amazing that in the 21st century most drivers are still having to change gear using two bits of bent metal
Ever looked at the front mech on your bike? The rear ain't much better. For all the hubgears, and hammeredschits, derailleurs are still the best option most of the time.
Posted : 24/02/2011 2:51 pm
tbh in snow I disconnect the traction control and use the manual side of the auto gearbox, - the idea is you can still steer with the front, but slowdown with the rear it works
If you say so 🙂
Posted : 24/02/2011 2:52 pm
[i]tend to use my left foot to brake in an auto
Why would you do that?[/i]
Why not? Not having a clutch frees up the left foot meaning it's doing nothing. Means each foot has one job. Probably not much of an advantage but why have a lazy foot getting away with a free ride while the other has to work hard???
Posted : 24/02/2011 3:30 pm
In response to the original post, it depends on your driving conditions.
From my experience:
Majority of UK driving suits an auto. Roads are flat and congested. Can't enjoy driving so why bother with a manual. Zoom around in direct control of the perfect gear as much as you want you'll soon be tucked up behind a slower moving vehicle.
Would consider a manual if majority of driving didn't involve traffic and the roads were hilly purely for the engine braking.
Posted : 24/02/2011 4:30 pm
Page 3 / 3
