DIY wooden Composte...
[Closed] DIY wooden Composter - Tips Please
5 Users
I have some spare wooden slats and posts that used to be in fence that I built to contain Jnr FD in the garden.
Rather than taking all the now unused wood to the tip, I have come up with the idea of building a Composter from scratch.
Can anyone show me any good designs for such a thing, also should it be just 1 bin or 2? What I have read so far says that you should have gaps between the slats etc (but the distance of gaps is a bit of guess work), and the composter must be directly built over spoil to allow worms up. I was ideally wanting to place it on a pebbled area, but I guess I could remove all the pebbles if necessary.
Any info greatly appreciated. Ta
Posted : 15/08/2014 10:17 am
I'm planning to do similar at some point this year. Here's the [url= http://www.todayshomeowner.com/how-to-build-a-compost-bin/ ]online guide[/url] I'm thinking of using.
Posted : 15/08/2014 10:43 am
Make it with the slats vertical so stuff can settle down. Have two or three bins. Worms will find their way in. Fit a lid of some sort.
Posted : 15/08/2014 11:18 am
Remember you'll want to empty it from the bottom, so spade access via a hatch would be good.
Posted : 15/08/2014 11:26 am
I made one from a bunch of pallets - heat treated ones, not chemically treated. We have three bays, kinda like this: [img] [/img]
Except they have slots on either side at the front, so we can drop in spare boards to make a front wall, like on this one:
That way you can raise/lower the height of the front to make it easier to add material, or when turning the compost (shovelling from one bin to another).
On some of the pallets I knocked the slats off using a pry bar and a lump hammer, and put them back on a bit closer together plus an extra slat or two, to reduce the gap sizes.
I use some spare bits of corrugated iron for a roof. Works a treat. Having at least two bays/bins means you can turn it over easier, as you're not turning it over into itself, you can just shovel from bin 1 to bin 2, so it gets well aerated as you do it. You can then start afresh in bin 1 with uncomposted materials while bin 2 finishes off. Having a third bin means you can be a bit less organised with regular turning, or just have three bins at different stages of decomposition.
Posted : 15/08/2014 11:38 am
